Question about Dymo LabelWriter 400 Thermal Printer
How can I fix this problem?
Dymo Labelwriter 400 has work al that time. 2day when I open and try 2 print a label i get the following ERROR:
Exception Epriner in module LABELS.DLL at 0002F1B6
Kind regards,
Nine
  • Anonymous Dec 17, 2008
    I have selected the correct roll number from the list but the machine will not recognise it. It stops printing before the wording is complete and stops past the perforations (1/4 way into the next label).
My printer is only a few months old. I have used up all the label roll that came with the machine and have put in a new roll (99010) which is slightly slimmer than the original one. I have selected the correct roll number from the list but the machine will not recognise it. It stops printing before the wording is complete and stops past the perforations (1/4 way into the next label). HELP!
Posted on Oct 09, 2008
Dymo LabelWriter 450 Twin Turbo - Until recently worked fine from both sides. Suddenly, no longer printing from left - prints half a label, then stops, then error message says Out of Paper, the blue light...
See if it still happens using a fresh label roll. From the Dymo 450 User Guide the common causes of poor print quality issues.
Poor print quality is most frequently caused by one of the following:
• An old roll of labels
• Labels made by a manufacturer other than DYMO
• Labels where the thermal coating has been compromised
• A dirty print head
First, make sure you are using DYMO-branded labels. Do not use third-party labels because the thermal coating on other labels has a different sensitivity than DYMO-branded labels. Also, the perforated holes between the labels made by other manufacturers are frequently not detectable by LabelWriter printers.
If the print quality becomes faint, small dots of white appear scattered through the printed characters, or light and dark patches of printing appear, you are probably using a faulty roll of labels. Try using a different roll from a fresh box. If the second roll prints correctly, the problem is with the first roll of labels.
Another possibility is that the LabelWriter print head needs cleaning. Every LabelWriter printer comes with a cleaning card. See "Caring for Your Printer" on page 17 for information about the
LabelWriter cleaning card.
Sep 13, 2013 | Dymo LabelWriter 400 Turbo Thermal Printer
My Dymo Labelwriter 400 turbo will not print. The print error comes up and does not tell me what is wrong. When I take the labels out and reinsert them the labelwriter will not load I have to unplug the...
In most cases, problems are solved by checking whether the spools are firmly pressed against the label roll: This machine can be very picky. Many questions can be answered at the following site. http://global.dymo.com/enNZ/HowTo/LabelWriter_400.html
Chris Thrash
B52Computers
Jan 19, 2011 | Dymo LabelWriter 400 Turbo Thermal Printer
Printing error print system exception error
I had this problem with the LabelWriter 450 Turbo and it was a .Net Framework problem.
1. Uninstall the Dymo Label software
2. Click this link to download .Net Framework 4.0 http://www.microsoft.com/downloads/details.aspx?FamilyID=9cfb2d51-5ff4-4491-b0e5-b386f32c0992&displaylang=en
3. Reinstall latest version of your Dymo Label software (w/o printer connected to PC)
4. Reconnect label printer when prompted by installer
This should fix the problem
Dec 24, 2009 | Dymo LabelWriter Thermal Printer
This is the error message when openning the Dymo Software on Server 2008. We have openned this same softare successfully on other 2008 Severs. Exception EPrinter in module Labels.DLL at 0000643E6
http://global.dymo.com/enGB/Troubleshooting/LabelWriter_320.html
From this site.
    • The error message: "Exception Eprinter in module LABELS.DLL at ...." is displayed.
      or
      The error message: "Access violation at address ... in module DYMOLBL.EXE" is displayedA. This problem can occur when DLS 7.x was installed over DLS 6.x, without first uninstalling DLS 6.x.
      Solution:
      Delete the file Dymolbl.ENG.
      DLS will still work, however, all default settings will be incorrect.
      The settings will need to be set correctly.
      On the DLS menubar, click Preferences and set the preferences as desired.
      The default values are:
      Default label file folder should be set to "C:\Documents and Settings\All Users\Shared Documents\DYMO Label\Label Files"
      Default address book folder should be set to "C:\Documents and Settings\All Users\Shared Documents\DYMO Label\Address Books"
      Default clipart folder should be set to "C:\Documents and Settings\All Users\Shared Documents\DYMO Label\Clipart"
      B. An incorrect printer has been selected in the DYMO software.
      Solution:
      1. Start the DYMO Software.
      2. Click on File and point to Change printer.
      3. Click the LabelWriter model connected to the PC (e.g. Dymo Turbo)
      C. Occasionally, double-clicking the print command button in the list manager is not handled properly by the software.
      Solution:
      Single-click the print command button.
      D. An incorrect driver has been installed.
      Solution:
      Run the DYMO Driver Uninstaller
      Restart the PC and install the correct driver.
      To remove and reinstall the printer driver:
      1. On the Windows taskbar, click Start, point to Settings and click Printers (& Faxes).
      The printers window is displayed.
      2. Double-click the LabelWriter icon and delete any documents waiting to be printed.
      3. Close all programs.
      4. On the Windows taskbar, right-click on Start and click Explore.
      Windows Explorer is started.
      5. Double-click the file C:/Program Files/DYMO Label/Support Files/LW Remove.exe
      6. Unplug the LabelWriter's USB connection from the back of pc and click OK.
      7. Choose Select all and then remove.
      Once the driver has disappeared from the printers dialog box, click Close.
      Restart the PC.
      8. When Windows has restarted, on the Windows taskbar, click Start, point to Programs, point to DYMO Label and click Uninstall DYMO Label.
      9. Reconnect the LabelWriter to the computer and reinstall both driver and software.
Jun 16, 2009 | Dymo LabelWriter 400 Turbo Thermal Printer
Dymo 400 labelwriter does not print unless shut down and rebooted
It could be how you have loaded the labels. If you have loaded the labels and there is a small gap between the spindle and the roll, it will print one label and give a error-printer message and stop working until you unplug it for 30 seconds and plug it back in. I would reload the labels from scratch and ensure there is no gap.
Feb 17, 2009 | Dymo LabelWriter 400 Thermal Printer
My Dymo LabelWriter 400 Turbo stops printing after it has printe
Did you change the number of copies to print prior to printing?
Jan 16, 2018 | Dymo LabelWriter 400 Turbo Thermal Printer
DYMO THINKS ITS OUT OF PAPER ....
New versions of the Labelwriter 400 (original and Turbo) do not take Generic Labels. It is an issue with the firmware Dymo have installed - it will only relabelwriter400.jpgad the genuine labels made by Dymo. currently there appears to be no work around to solve this isses.
The Dymo OEM labels have lines print on the back, if you use labels without these lines, the printer gives an "out of paper" error
The only printers in the Dymo Range that will take our generic labels are the Dymo Twin Turbo and the Dymo Duo (both the more expensive from the range).
Dymo have only made this change in the last 6-8 months, old 400's will work with cheaper generic labels
Aug 09, 2008 | Dymo LabelWriter 400 Thermal Printer
DYMO DUO LABELWRITER
The labels have a 2 yr warranty, so contact Dymo customer support and if they can't help you return the printer to the retailer you purchased from for a new printer. The Dymo LabelWriter DUO is an expensive printer that Dymo stands behind.
Feb 16, 2008 | Dymo LabelWriter 400 Turbo Thermal Printer
Dymo LabelWriter 400 Thermal Printer Logo
376 people viewed this question
Top Dymo Office Equipment & Supplies Experts
Jax Planet
Jax Planet
jdthefixer
Are you a Dymo Office Equipment and Supply Expert? Answer questions, earn points and help others
