Question about Paragon Hardware & Accessories
We have a Paragon Time, Model #4001-00, TD-1744-00 at our softball field to control bathroom lights. The 2 ears or shut-off and turn-on devices were lost during some electrical work and we cannot find them anywhere in our area. So, we need new ones.
Thank you for including model number.
1) Open following link to identify timer and download manual
http://waterheatertimer.org/Paragon-timers-and-manuals.html#4000
http://waterheatertimer.org/pdf/Paragon-4000-24hr-7000-7day.pdf
2) 4001-00 series is heavy duty Nema 1 indoor 40 amp 120Volt mechanical timer with analog dial.
I don't recognize TD-1744-00
I'm not sure what you mean by 'ears'
3) Maybe you mean X2772 trippers?
Trippers are set on dial to control on-off switching.
If trippers are missing, Google search for X2772 tripper and some places still sell them.
4) If another part is missing, you might not be able to find that part, but you can photograph the problem and add a comment to this thread and include photograph so I can look at it.
http://www.fixya.com/support/r6568559-post_photograph_fixya_questions_answers
5) if you have to replace timer, some places still sell Paragon 4001-00, or replacement is Intermatic T101 or T103 timer
http://waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html#T101
Add a comment with your experience so others with same-similar problem can benefit.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Posted on Apr 01, 2011
Timer not working on 4000 series, think its 4014 single pole single switch for pool pump. pump turns on when manually turn switch on but timer does not move. I feel the normal resistance and can move the...
1) If circuit breaker is not tripped or shorted, then timer clock motor has probably gone bad.
2) Some places still sell paragon timers, depending on model number.
But model number given is for 240Volt timer.
3) The clock motor is not available that I can find.
Paragon is no longer making the 4000 series timers or parts
4) Model number given does not match wiring terminals shown in manual.
4014 is DPST 240Volt timer with 4 wiring terminals labeled 1 2 3 4.
http://waterheatertimer.org/pdf/Paragon-4000-series.pdf
5) Paragon 4000 series timer with terminals 1 2 3 is 120Volt timer.
6) Replace 120Volt timer with Intermatic T101 indoor timer or T101R outdoor timer.
Crossover wiring:
Paragon terminal 1 goes to Intermatic terminal 1
Paragon terminal 2 goes to Intermatic terminal 2
Paragon terminals 3 goes to Intermatic terminal A
7) Take a moment and rate answer:
And take advantage of fixya expert assistance live.
Aug 29, 2011 | Paragon 4001-00 24-hr Timer Control 120v...
How i can do the instalation
1) Need more information.
Heres some help to get you started, then you add a comment and fill in details so I can give accurate answer.
2) You posted under Paragon 7008-00 timer.
3) People post under Paragon when they have Tork, so I need exact model number and what voltage you have and what Load you are trying to wire.
4) Also what terminals appear on timer, since any timer can be in a box that is marked 7008.
Then add what color wires you have coming from breaker box, what size breaker, and if same breaker is going to supply voltage to timer and to Load, and what color wires are going to Load.
5) Open following link to identify timer for sure, and see manual and wiring diagrams.
http://waterheatertimer.org/Paragon-timers-and-manuals.html#7000
6) Typical wiring diagram for 7008 showing one set of NO NC terminals:
http://waterheatertimer.org/images/Paragon-7008-00-timer-wiring-350.jpg
7) 7008 timer has 120Volt clock motor. So power to terminals A and B has to be 120V.
But timer can still control 120V or 240V loads.
8) According to manual, 7008 timer has 2 NO (normally open) terminals that are OFF when timer is OFF
Timer also has 2 NC (normally closed) terminals that are ON when timer is OFF
9) Both sets of terminals reverse when timer turns ON.
10) NO and NC terminals are frequently used for continuous-operation 2-speed motors, for example.
You do not want power to both speeds at same time, or motor will burn out. So low speed is connected to NO terminal, and high speed is connected to NC terminal. This way the motors windings are kept separate, and either low speed is ON or high speed is ON.
11) Another example of NO NC terminals could be store lighting. When store closes, the timer turns off exit signs and store-room lights inside store, and at same moment timer turns on burglar alarm and outdoor lights. In this example the timer controlled 4 different circuits: exit signs, store-room, alarm, and outdoor lights. With 2-NO and 2-NC terminals, that is possible.
Apr 15, 2011 | Paragon Indoor Electromechanical Timer...
I have a 4003 osz time clock and it does not turn lights on and off. Where can I get new insides for the same box.
As of November 2010 or before, Paragon is no longer making timers or parts except Defrost timers.
4003 0SZ is not a defrost timer.
0SZ suffix appears to be 120Volt astronomic time clock that turns ON at Dusk and OFF at Dawn
4003 is DPST 120Volt 40 amp mechanical timer
Tork shows 120volt mechanical Astronomic time piece
7200Z DPST
http://waterheatertimer.org/pdf/7000Z-series-wiring.pdf
http://waterheatertimer.org/Tork-timers-and-manuals.html
MR Supply sells 7200
Intermatic mechanical astronomic clocks:
http://www.intermatic.com/products/timers/mechanical%20time%20switches/astronomic.aspx
These time clocks are Indoor-outdoor and can control 3 different 120V Loads, for example store light in front, outdoor light in back, and outdoor sign. All Loads turn on-off at same time.
Beverly Hills shows the V4547r
Intermatic also makes electronic astronomic time pieces where voltage is selectable, with many timing options (programming is detailed and complicated):
http://www.intermatic.com/products/timers/electronic%20time%20switches/astronomic%20electronic.aspx
NEMA1 is indoor box
NEMA 3R is indoor-outdoor box.
SPST means timer can control 1 Load
SPDT can control 2 120V Loads
1000 Bubs sells the ET8115C
Add a comment for more free help, for example a question about a specific model or about cross-over wiring. I have experience with wiring diagrams and experience with some different models.
Also take advantage of fixya phone service.
For a price, fixya expert speaks with you over phone while you work on timer.
Jan 11, 2011 | Paragon Vintage 24 Hour Timer Command 12...
NEED TO REPLACE A PARAGON MODEL 4001 24 HOUR TIME SWITCH WITH KNOCK OUT FOR CONDUIT CONNECTION ON TOP
Paragon 4001 is 120Volt SPST indoor timer.
I've never seen knock-outs for these timers on top because the timing mechanism is in the way.
Turn timer sideways, the timing mechanism still works.
geno_3245_78.jpgTimer flipped 90 degrees so KO is on top
Nov 18, 2010 | Paragon 4001-00 24-hr Timer Control 120v...
AMF Model No. 7008-00 How do I know if it is working or not. Where can I get more Pins to stop the bld everyday at 5pm.
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}
Paragon 7008-00 timer parts:
http://www.paragontimecontrols.com/parts_accessories.htm
http://www10.shopping.com/-paragon+timer+trippers
Paragon mechanical 7008-00 has 120V clock motor
-8 poles control 1-4 separate 120V loads, with 2 NO Normally Open and 2 NC Normally Closed circuits with max 690 Watts per pole.
Test 120V clock motor:
-Clock motor connects to two far right terminals. Black hot to pole M, White neutral to pole T.
-You should be able to hear clock motor running by putting ear against outside case.
-Clock motor will rotate wheel, if wheel is not rotating, then motor is not running.
Sep 21, 2010 | Paragon Amf 7008-00 Timer 7 Day 120 Volt...
We have an AMF Paragon 4001 timer for the light outside our building. The light goes on lately at the wrong time. We want it to be on at 7:00pm and off and 5:00am but it goes on at 12:00 at noon.
To set paragon timer: Pull large round dial straight out towards you, then rotate dial until correct time is lined up with stationary 'pointer' on front of dial
Sep 08, 2010 | Paragon 4001-0G Defrost Timer
I'm trying to set the times on a paragon amf 7 day timer
There should be 2 trippers for each day, the trippers slide on the outside of the dial and would point to the time of day you want your lights on and off. The silver trippers may be gone on that aged time clock, but are easily obtainable.
Jan 14, 2010 | Paragon Amf 7008-00 Timer 7 Day 120 Volt...
Hardware & Accessories Logo
651 people viewed this question
Top Paragon Hardware & Accessories Experts
Gene Haynes
Steve
jdthefixer
Are you a Paragon Hardware and Accessory Expert? Answer questions, earn points and help others
