Question about Vulcan EF3 Deep Fryer
Pilot light on thermostat click main burner doesn;t come on
Don't know if the pilot has been cleaned or the thermopile has been changed. The pilot being lit can be good to keep valve open but not strong if enough to open main burner. If after checking all the above, make sure you have gas flow from the valve, if so replace thermostat.
Posted on Apr 07, 2011
Electronic ignition clicks really fast wont light and finally shuts off What is the problem with our Duke E101GV
The ignition module is energized solely by the thermostat output. When the tstat satisfies, all power is removed from the module. The pilot and the main burners go out.
When the module trials for ignition, it must prove pilot flame and then turns on the main burner. If it doesn't sense the pilot for some reason, it also disables the pilot solenoid valve.
If the pilot comes on and stays on, but main burner doesn't come on, there's several possible problems:
  • Faulty ignition module
  • Faulty main burner solenoid valve
  • Faulty wiring between the module and valve
  • A gas blockage at the main burner
All this under the assumption that the main burner is correctly installed.
https://techtown.partstown.com/thread/1710-i-have-a-duke-e101g-convection-oven-that-is-not-firing-not-sure-what-the-problem-is-it-takes-a-long-time-to-get-to-temp-but-when-food-is-put-inside-it-seems-to-never-make-it-to-temp
Apr 20, 2018 | Cars & Trucks
Any idea why my Atwood water heater will shut the main burner and the pilot light off at the same time? Sometimes runs for 20 minutes, sometimes 2. I hear a clicking sound, then they both shut off.
The thermostat shuts off the main burner.The pilot light gas is controlled by the thermocouple which the side of the pilot flame has to envelop. If the flame is too small or too far away from the flame, it shuts the gas off to the pilot. The thermocouple generates a small voltage which keeps the pilot gas open. It can over time fail itself, so look at replacing it. The thermostat sounds like it's failing too.
Apr 27, 2016 | Water Water Heaters
I have an imperial fryer. Pilot is on but main burners don't ignite. Pilot looks normal & thermostat clicks when turned
Number 5 is your thermopile/pilot generator. It is a pilot generator that does 2 things. It holds open the valve with a safety magnet and it operates the safety valve solenoid whenever the control stat calls for heat. Overtime they get weak and will hold the pilot but not operate the valve solenoid. I would replace that pilot generator.thermopile and party on!
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jul 30, 2012 | Imperial IFS40 Deep Fryer
My dv35 wall furnace pilot light on main burner will not light
lightly tap on the area where the wires are connected. the valve will stick at times. try that.
Oct 30, 2011 | Empire DV-35 Heater
Pilot light goes out
The Tstat has a capillary that looks like a thermocouple but it isn't, its a bulb with liquid that expands and contracts based on temperature. A pilot can go out due to a high limit switch being week or getting to hot and that can be shaped like a thermostat capillary or can be simply a disc with a button if even there is a high limit on your stove. There likely isnt. So see the next suggestion.
I suggest lighting the pilot, turning on the main burners while watching the pilot. If the pilot shrinks in size, then check your gas pressures before and after turning it on and seeing if there is a wide variation. I would suggest the pilot is dirty or the pressure regulator is faulty.
Dec 19, 2009 | Grilling
Pilot is lit but burners will not light?
There are several things that could cause this problem. The 1st thing to try is to expose the terminals on the thermostat. With a small piece of insulated wire find terminals R and W and touch from red to white and hold there. You may see a small spark but don't let this alarm you.Now have someone go see if the burners start up when it is jumped out.If it comes on, then the thermostat is faulty.If not, i would need to know if this unit has a standing pilot(lit all the time) or an electronic module. If its an older furnace with a standing pilot, see if the pilot flame is a nice blue flame with no yellow tent to it.I have seen many times where bugs,flys,ect, will die in the pilot tube and cause the flame not to get hot enough or surround the flame sensor and this will keep the burners off.If it has a Ignitor module for the pilot, and it clicks and lights the pilot and burners fail to light, the module could be faulty. Also, if the thermostat is good and you have a meter, the main gas valve (MGV) needs to be checked for 24volts at the Hot and common terminals.I am almost positive it is the thermostat, but I would have to be there to trouble shoot it. I hope I havent confused you more.Dont let the voltage at the t-stat scare you.
Good Luck, Sincerely, shastalaker7
Oct 29, 2009 | Heating & Cooling
Oven pilot light is on, but burners will not light. pilot light burns larger when trying to turn burner on. Do I need a new thermostat?
The thermostat is doing it's job if the pilot gets bigger. When you turn on the thermo, it does 2 things: Makes the pilot bigger and supplies gas to the oven safety valve in the oven. The bigger pilot heats up the bulb from the valve and the stuff inside expands and turns on the main gas. The oven cycles when temo is reached by making the pilot smaller. The most common problem is that the pilot doesn't get big enough to satisfy the valve. Take out the pilot burner ***'y. (7/16" wrench for the nut). Replace the pilot burner. The part is probably a 5414S030 if the valve bulb is located parallel to the ***'y.
Sep 30, 2009 | Magic Chef 31000 Gas Kitchen Range
Pilot will light but main burner will not light
if burner lights after jumping valve you have something wrong in thermostat loop. disconnect the 2 thermostat wires on gas valve and use multimeter on continuity setting. if all wires ,connectors and components are good,you will get a tone.since you have jumped out each component in thermostat loop with no success ,i would suspect a bad wire or oxidation on a terminal .
Sep 24, 2009 | Teledyne Laars Laars Lite 2 Pool Heater...
Vulcan EF3 Deep Fryer Logo
158 people viewed this question
Top Vulcan Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Paul Carew
Are you a Vulcan Kitchen Appliances - Other Expert? Answer questions, earn points and help others
