Question about Simplex Kaba Ilco Unican L1000 keyless lock
LOST CODE AND LATCH WON,T RETRACT WHEN LEVER IS TURNED.
  • 963 Answers
Navigate to this page, which show a grid of Simplex products, then scroll down to the L1000 entry:
http://www.kaba-ilco.com/access_control/literature/literature_grid_mechanical_pushbutton_locks.aspx?id=13&obj=1000
Then go to the rightmost column (TIPS) and hover your mouse over "PDFs", which will pop up a window with two choices: Changing the code, or How to reset a lost combination.
You will then be able to download a PDF file of your choosing for instructions.
If you don't already have Adobe Reader or another PDF reader program installed on your computer, there is a link at the top of the the grid chart to download Adobe Reader.
Posted on Apr 10, 2011
Exterior door stuck closed manually retract ****** remove knobs KWIKSET
You will probably need to replace the latch assembly. There is a small rivet that holds part of the latch together, and it also acts as a pivot point for a small piece that retracts the latch. If it gets bent, the latch won't retract fully, but you might be able to push it back and get the door open.
May 24, 2014 | Kwikset 740ll 3 Smt Lido Keyed Entry Lever...
Hood won t close
Check out the cable connection between the latch and your internal latch control. Till you locate the problem I would suggest tying down the hood with some sort of strap so it does not pop open at speed.
Apr 24, 2017 | Chevrolet Malibu Cars & Trucks
Door latch
see this causes and fix it. God bless you
Open Lever If the microwave door won't open the open lever might be broken. This part can be replaced separately.
Door Spring If the microwave door won't open the door spring may have broken. The door spring is located inside the door and keeps downward pressure on the door hook.
Door Latch If the microwave door won't open the door latch might be broken. The door latch is inside the microwave. The door hook, which is part of the door, engages with the latch to keep the door closed during operation. If the door latch or actuator breaks the door may not open.
Door Hook If the microwave door won't open the door hook might not be releasing properly. The door hook is installed inside the door and normally releases when the door is opened. The hook is made of plastic and will break over time. When this happens it will need to be replaced, it can't be repaired.
Button Spring If the microwave door won't open the button spring might be broken internally. The button spring can be replaced.
Button If the microwave door won't open the button might be broken internally. The button can be replaced.
Handle Actuator If the microwave door won't open the handle actuator might be broken. This is a plastic part which can become brittle over time. This part is connected between the door button and the door latch assembly.
Oct 15, 2012 | Samsung SMH9187 Microwave Oven
How to change entry code
First, remove the control cylinder with your "DF59" control key. The cylinder unscrews to remove. Next, turn the knob all the way to the right, and release it.
Step three: Enter the existing code
Step four: Using either the spanner wrench that came with the lock, or a medium-sized flat-tip screwdriver, reach into the hole the control cylinder came out of; and turn the cam inside, about 1/4 turn (as far as it will go), and then back.
Step five: Turn the knob as far as it goes, ONLY ONCE, then release it.
Step six: Enter your new code.
Step seven: Turn the knob (this time, it should retract the latch).
Test it by turning the knob again: The latch should not retract. Now enter your new code and it should retract the latch as you turn the knob. If so, you have successfully changed the code.
Dec 23, 2010 | Simplex Kaba Ilco Unican 1000 keyless...
How do I change the combination on my Unican 1000 keyless lock? thx john
The door must be open.
On models with the passage feature, make sure the passage feature is disengaged: turn knob or key should be in vertical position (A) (see figure 1).
1. Insert the DF-59 control key (B) into the combination change plug
assembly (
C) and unscrew the cylinder by turning the key
c
ounterclockwise. Remove the combination change plug to gain access to the combination change sleeve (see figure 1).
2. Turn the outside knob/lever once clockwise (all the way, until it stops) then release. The latch should not retract (see figure 4).
3. Enter the existing combination. On new installations, use the factory- set combination: depress 2 and 4 simultaneously, (release), then 3
(r
elease). You should feel a slight click as each button is depressed.
4. Insert the spanner wrench as shown in figure 2 to engage the combina- tion change sleeve (A). Gently turn the spanner wrench clockwise to the stop position (a slight click should be felt), then turn the spanner wrench counter-clockwise to the stop position (A) (see figure 3). Remove the spanner wrench.
5. Turn the outside knob/lever once clockwise all the way until it stops, then release. The latch should not retract (see figure 4).
6. Choose your new combination, write it down, then enter the new combination-depress buttons carefully (a slight click should be felt as each button is depressed).
Note: You can use one button or all five for a combination, but each button can only be used once. You can depress two or more buttons simultaneously as a step in the combination.
7. Turn the outside knob/lever clockwise once, all the way, until it stops, hold in position and make sure the latch is retracted (see figure 5).
R
elease the knob/lever.
Note: If your lock is opening on every turn of the knob or lever, except upon entering a code, this may be a ZERO CODE. Before attempting to remove the lock from the door, refer to the troubleshooting procedures outlined at bottom of this document for a zero code symptom/solution.
1000/L1000 Series FAQ
Changing the Code/Combination
hope this helps
and here is the link to the change code web site
http://www.locksonline.co.uk/files/pdf/Simplex_1000_CodeChange.pdf
good luck
please take the time to rank my advice
merry christmas
Dec 07, 2010 | Simplex Kaba Ilco Unican 1000 keyless...
86 bmw 325 hood latch broken how to open hood
try to pull the cable with pliers
Mar 09, 2010 | 2001 BMW 325
Trunk latch on 2002 Civic EX 4-Door won't close
trunk latch cable probably needs to be replaced
Jul 06, 2009 | 2002 Honda Civic
Simplex Kaba Ilco Unican  L1000 keyless lock  Logo
154 people viewed this question
Top Simplex Locks & Locksmithing Experts
Michelle Balcom
JonSnell Electronic
JonSnell Electronic
Are you a Simplex Lock and Locksmithing Expert? Answer questions, earn points and help others
