Question about Dell Dimension 3000 PC Desktop
Every time i start my computer date and time is not set. What is the problem?
    Scholar:
  • 84 Answers
Your BIOS battery is dead. Without your BIOS battery, the clocks don't "remember" the time and date that have been set on your machine. If you're handy, you can try purchasing a BIOS battery online or from a computer shop and replacing it yourself. The battery is on the motherboard and is fairly simple to remove and replace compared to other repairs. If the prospect of opening up your machine is a little unsettling, you can take your machine to any computer shop and they should be able to replace it for you. A reputable shop shouldn't charge very much for it. Some may even do it for free as it only takes a few minutes if they have the right battery on hand.
Posted on Apr 01, 2011
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 85 Answers
Your cmos battery is dead its located on your motherboard its a cr2032 button sized battery. If you decide to replace it unplug your pc the press power button (to drain extra power) and pop the old battery out of the socket and put the new one in. [also you may need to set the date in the BIOS if it wont in windows]
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 157 Answers
It sounds like the battery needs to be replaced. It's not that hard to do, I have provided the link to the user's manual, and the battery replacement is on page 73 for you. http://support.dell.com/support/edocs/systems/dim3000/en/OM/j6758A04.pdf
Hp Compaq nc6220 Laptop. there begin booting one msg "163-time & Date not set". how to resolve this problem.
go to your BIOS setting
There set the current date and time
[while starting the computer , there will be screen showing options keys for bios setting (it will probably be esc or f12 or f2 or f11)]
Jul 19, 2011 | HP Compaq nc6220 Notebook
The time/clock on my computer is 2 hr.s slow.
click start control panel date and time you can make your adjustments to the date and time from there or right click on the date and time and you should see Adjust date and time tab hope this helps
May 27, 2011 | Computers & Internet
Computer start but monitor goes in power safe mode . What can I do ?
Typically, this happens on a computer which is a few years old, since its batteries will have run out after such a long time.
The motherboard battery is used to store various settings, such as date and time, when the mains power is off. When your computer detects an empty battery, it goes into a low-power mode.
The solution is to replace the button-cell battery on the motherboard of your computer:
  • open the case of your computer;
  • visually locate the motherboard (the main electronic circuit board) of your computer;
  • visually scan the motherboard for a button-cell battery (it looks like a digital watch battery, but a bit larger);
  • remove this motherboard battery from your computer;
  • restart your computer: it should now power up normally (you may get some warning messages during the start-up sequence, but ignore them);
  • set the date and time of your computer using the "Date and Time" control panel;
  • you can now use your computer normally, but you will lose date and time settings when you disconnect the computer power cord, since there is no motherboard battery present to store them;
  • take the motherboard battery to an electronics store and get a replacement;
  • install the new battery in your computer;
  • restart your computer, and set the date and time again; the settings will now be saved using motherboard battery power.
Mar 22, 2011 | Gateway 420GR PC Desktop
My pc automatically get start on plug on .and then it suggest me to press F1 to Continue. when I do this it takes incorrect date and time how to restrict it.I want to start it with start button on cabinet
There can be many reasons...
  • Your BIOS setting is not correct.
  • CMOS battery is down(Most probably).
  • both
You can open the BIOS setting page by pressing keys like DEL, F10, etc. depending on your system's manufacturer at computer startup(post screen). There are lots of wakeup options check them properly.
One of the option is "Restore last state of power Button on failure" which can turn on your computer without touching the power button. you should check these options.
And it suggest you to press F1 because your system's date/time is not configured properly. You can also set Time/date in BIOS also.
If your BIOS Battery(CMOS) is not weak or dead then after setting these values your computer should start properly.
And if your BIOS battery is dead then all the settings will be lost(date/time etc) after a restart and you will face same problem again...
Try changing the Power-button option and Date/Time in BIOS and see if problem persist....if yes then you have to change COMS battery that is on your Motherboard.
Sep 22, 2010 | Computers & Internet
How to create an application which should expire in 30 days
at the time of installation, write down the date in a secret file or database.
each time the application starts check the difference in days from the current date.
each time the application starts save in another place the application last started date.
if the user tries to change the computer date, then you will know if he has set it before the last started date or before the installation date.
Jan 15, 2010 | Microsoft Visual Basic 6.0 for PC
Set Date
Entering the Date and Time Note: When your machine is connected to a computer with the MP driver installed, even if the date and time are entered from the Operation Panel of the machine, the date and time will be read from your computer every time you start the computer, turn the machine on, or disconnect and connect the USB cable. When using your machine connecting to your computer, set the date and time on your computer precisely.
The date and time will be reset when you disconnect the power cord or there is a power failure. In this case, you can set it again on the machine. Alternatively, it can be read from your computer and set on the machine by connecting the machine to your computer with the MP driver installed.
1. Press [FAX], then press [Menu].
2. Use [ left ] or [ right ] to select <USER SETTINGS>.
3. Press [OK] two times.
4. Use the numeric buttons to enter the date and time (in 24-hour format). Enter only the last two digits of the year.
5. Press [OK].
6. Press [Stop/Reset].
Sep 13, 2009 | Canon PIXMA MP530 All-In-One InkJet...
Bios date and time problem
You need to replace the cmos battery in your computer. Theu are usually Cr2032 batteries which you should be able to pick up for about £1.
unplug your computer and open the case.
When you look at the motherboard you should be able to easily locate the cmos battery cliped onto the mobo.
Take the old battery out and insert the new one.
put the case back on and plug the pc into the mains again.
You will need to re-enter the date etc the next time you boot up, but the settings should be retained after that.
Ian
Mar 09, 2009 | Dell OPTIPLEX GX150 PIII-1.0GHz 256MB 40GB...
Time and Date Setting
There is a lithium battery in your computer that needs to be replaced. If you open up your coumputer, look for a round looking battery about the size of nickel.
Jun 30, 2008 | Microsoft Windows XP Professional With...
Faulty time settings p5rd1 vm
Hello!
That's the 2nd time i hear that kind of problem. Your mboard battery is new, and you did not press "f1" at first start.
so i guess , the cmos time is not change, try go to the bios setup and load "bios setup default." after that change the time setting on the bios. please find time setting and set it with a current ime in your area. after setting press 'F10" to save and exit the setting, the system will restart.
may this help!
best regards, melnavz
Mar 13, 2008 | ASUS P5RD1-VM Motherboard
My computer went back to older clock date as 1610
try starting your computer in safe mode and see if you can do anything productive there, like scanning for viruses or spyware. also check if you can do the following:
CTRL+ALT+DEL (open task manager)
goto Start>Run>Regedit (open registry editor)
goto Start>Control Panel>Display>Properties (change display settings)
right click on clock at tray and change the current time to correct settings
if you cannot do any of these activities, then your computer may probably been compromised by a virus or malware.
Jan 02, 2008 | Dell OPTIPLEX GX150 PIII-1.0GHz 256MB 40GB...
Dell Dimension 3000 PC Desktop Logo
434 people viewed this question
Alun Cox
