Question about Seagate Barracuda 7200.10 ST3250310AS SATA Hard Drive
Old computer with windows xp won't boot - how can I get the data off the hard drive by hooking it up to my new computer with windows vista?
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 85 Answers
Many ways to do this. but first you need to remove the drive. you can go to the local tech store and buy a "external en-closer" that connects to your new computer via USB. or you can install it into the new pc (remember to always be careful when inside a computer most thing get destroyed just by touching) also before you open up a pc you need to unplug it and then press the power button to drain extra electricity
Posted on Apr 01, 2011
  • 20 Answers
You should be able to put the old hard drive in the new computer and connect it as a secondary drive. That all depends on the type of interface the new computer is using. Most new computers use SATA inferface for HDD now. You're old drive might be IDE. in which case you can't add it to new computer unless it also has IDE interface on new MB. If no IDE interface on new MB, you can use USB 2.0 to IDE or Serial ATA Drive Adapter Cable from Cablestogo.com to connect your old drive via USB.
Switched a vista hd to a xp hd and windows will not open
You can't do that, it just won't work. A hard drive with XP installed on it will be unrecognizable to a PC with vista already installed on it. You can either backup your XP drive by putting it into a compatible XP computer. Or you can buy on of these, which are handy. This let's you get the data to your new PC thru a USB connection.
Mar 26, 2012 | Dell Dimension E520 PC Desktop
I have purchased an hp550 computer with the Vista operating system. i wish to downgrade to the win XP operating system. how is this done ?
Greetings.
There is no direct path to downgrade Vista to XP. You can’t simply insert the XP installation CD media into the CD-ROM drive and hope to ‘upgrade’ and replace the Vista with Windows XP usual install routine because Vista won’t allow it to be overwritten. XP will treat Vista as ’superior’ operating system and refuse to install over it. There’re actually few options available instead of completely uninstall Vista as listed below. But if you decide to downgrade from Vista to install XP, there is also a simple guideline that you can observe to ensure that the migration goes smoothly.
Option 1 – Dual Boot:
It’s by far the easier and best method to run XP instead of Vista if you have another partition or hard disk. Simply boot up any XP setup media and install XP into different partition or hard drive than the Vista installation. Once completed, you can choose to boot up either XP or Vista, and has the best of both world.
Option 2 – Virtual Machine:
Install VMware Server or Virtual PC 2007 (both free) or any other virtualization software, and then install Windows XP into the virtual machine
environment. You will get XP which runs inside Vista, with minor compromise on speed, performance and have to go through Vista first on every bootup.
Option 3 – Format the Hard Drive, Wipe Off Vista and Install XP:
For those who totally fed up with Vista and just want XP, or prefer a clean installation of OS has only this option to rely on. To downgrade to XP from Vista, you have to basically delete the whole hard disk that installed with Vista, and start anew with XP. Here’s a simple guide and procedures that you can try to follow to switch to XP. However, each system configuration is different, so you may have to adapt the steps to suit your own need.
1. Download all drivers for your system for Windows XP from the manufacturer’s website(in case if you don't have the CD/DVD installers). Copy the drivers files to a USB flash driver or external hard drive or burn them to CD/DVD.
2. Find a Windows XP installation CD (should be pretty easy to find or else you can search in torrent sites such as Demonoid to download via BT network such as uTorrent and BitComet or search and download via ED2K network client such as eMule. You can also use Volume Licensing (VL) CD, retail (FPP) disc, or system builder hologram CD provided by Microsoft.
3. You will also need a XP product key even if you legally can downgrade from Vista Ultimate or Business edition. The Vista serial number won’t works with XP. (try to search for XP product key on web).
4. Backup to USB flash disk, external portable hard disk or CD/DVD every data files and any other things such as documents, downloads, pictures, movies, programs and etc that you need and want to keep. You can also create a second partition with disk management utilities such as Acronis Director or Partition Magic, and then move the data files to the new partition.
5. Ensure that also you have CD or DVD setup media for the software applications that you want to install and use after wiping off your system from Vista.
6. If your OEM doesn’t provide you with recovery CD/DVD discs and Windows setup media discs (it’s because they’re stored in the hard disk in hidden location), you may want to burn a copy of recovery CD to CD/DVD first before you proceed, just in case the hidden partition is lost and you want to recover your computer to original state. (How-to Guide: IBM/Lenovo ThinkPad recovery CD)
7. If the system has SATA (Serial ATA) hard drive, locate the driver for SATA controller and put it in USB flash drive, diskette or CD first. If you have PATA (normal IDE) hard disk, simply go to BIOS CMOS to disable SATA or Native SATA mode if you don’t want to install XP on SATA hard drive. Else, you can also create an XP install disc with the SATA drivers integrated by using tool such as nLite.
8. In the BIOS, also set the CD or DVD optical drive as the first boot device in the boot sequence.
9. Put in the Windows XP installation CD into CDROM drive and boot up the computer by using the CD. You probably need to press a key when prompted with “Press Any Key to Boot from CD…”.
10. If you’re using SATA hard disk with driver on external media (not integrated into XP setup disk), remember to press F6 when you see the message at the status base: “Press F6 if you need to install a third party SCSI or RAID driver…” during the very initial stage of setup to load the SATA driver so that the SATA hard disk can be recognized.
11. Run through the setup wizard at per normal. However, when prompting for where to install Windows Vista, delete (by pressing D and then confirmation), create and format the Vista disk drive or partition (if you have multiple partition). And then choose to install on that just formatted partition or hard drive.
IMPORTANT: If you choose the wrong hard disk or partition with data to delete, you will lose your essential data.
Note: If the setup does not allow you to delete or format the Vista partition or drive, you will need to find a third party software that can recognize and read NTFS filesystem to clear the drive or partition first.
12. Enter any product key for XP. Vista product key will not work.
13. If you own a legitimate Windows Vista edition that allows for downgrade (See Vista downgrade rights), call Microsoft after performing the clean install of Windows XP Pro to activate the XP installation. Notify Microsoft that you’re downgrading from Vista and require to activate XP Professional or other version allowed newly installed. You won’t get a new Windows XP product key though. You will have to read out the long Installation ID plus your original Vista serial key, and Microsoft will provide an activation ID that will make the XP usable.
14. Install the drivers for your system devices.
15. Reinstall any software programs that you want to use.
16. Move back the data files and documents.
Thanks
Nov 03, 2009 | HP Business Notebook 550
My HP Pavillion crashed. The hard drive is the sp1604n. I bought a new computer but want to tranfer or copy the picture files on the old (sp1604n) drive to my new computer. The old computer was windows xp...
In your new computer go to all programs then to your user guide. Once there open the guide and follow prompts to transfer data from old computer to your new one. Some stuff may have to be reformatted do work with Vista.
Sep 26, 2009 | Samsung SpinPoint P80 SP1604N 160 GB Hard...
I have a computer where the MOBO and CPU went bad and I replaced. The old computer came with Windows Vista installed on it, no CD. Now, Windows Vista won't boot and windows start up repair is activated...
The problem is when Vista was installed on the old pc it only recognizes that pc so you will need to buy a copy of Vista and install it on the new pc. And if you don't want to loose your info you can buy a ide/sata to usb cable and hook it up to your new pc to transfer your old info across. Hope this helps.
Jul 19, 2009 | Computers & Internet
My computer running xp doesnt see my old comps drives that ran 98
hey man try to install windows xp to solve this problem if this problem is not solved then it should be ur hard disk is higher than the compatible default rate which is may be 30 or 20 GB
Jun 20, 2009 | Seagate Barracuda 7200.7 40 GB Hard Drive
How do i transfer data from windows 98 formatted drives 2 xp ones
Set up your old drive as a slave and copy the data. Good luck.
Jun 19, 2009 | Computers & Internet
Retrieving data off an external hard drive
You can and there is no need to install drivers, except the drive has any special features.
Apr 19, 2009 | Computers & Internet
BOOTMGR is missing Press Ctrl+Alt+Del to restart. Im trying to format an older computer with XP Pro. I physically took out the only hard drive in the computer and hooked it up externally to my laptop to...
The problem is caused by Formatting the HDD in Vista before moving back to the system.
Simplest fix, hook it back to the Vista system and delete the partition from the drive in disk management. Once that is done, then put the drive with no partition in the XP system and boot to the XP CD, create a new partition and install XP
Jan 29, 2009 | Computers & Internet
I have a SimpleTech 250 GB external hard drive and would like to transfer the data from the hard drive onto my new HP laptop which is running on Windows Vista. However, when I try to sync, the name of my...
U can remove the drive from the external unit and hook it up to your vista computer as a secondary drive. Boot up the vista, use windows explorer, and transfer the data from the secondary drive to either your primary or a usb stick.
Jun 25, 2017 | SimpleTech (sti-u2f36/250) 250 GB Hard...
Multibooting
nope not if its in vista u would nee dto dual boot dl alll latest drivers software for vista then mosttime it works on older stuff
Oct 14, 2008 | Toshiba Satellite A135-S2276 Notebook
Seagate Barracuda 7200.10 ST3250310AS SATA Hard Drive Logo
131 people viewed this question
Top Seagate Computers & Internet Experts
Computer Links
terminalcon
John Anderson
John Anderson
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
