Question about Marantz BD7003 Blu-ray Player
Hi, I am trying to see a new Blu-ray movie on my Maratnz BD7003 player, but the disk will not be read. I am getting disk read errors and no loading of the disk. The store replaced the disk, but suggested an update of the firmware. The new disk has the same problem, I guess an update of the firmware is required. However, any reference to Marantz sites for firmware updates is constantly bouncing. See for instance: http://www.filme-bluray.de/001181-marantz-bd7003-und-bd8002-firmware-update/ Any suggestions where I could find firmware for this player? BR Wim
  • 1 more comment
  • w_guijt8 Apr 01, 2011
    Hey Drew,
    Great! Thanks! I will start with this.
    While having done some work with old(er) BD's I get the impression there is an issue as well with the drive. It looks like I need to clean the drive as well.
    Any recommendation which tools work best here?
    BR Wim
  • w_guijt8 Apr 05, 2011
    Hi Drew,
    Thanks for sharing!
    I had searched for DVD DR or DVD Doctor at first, but that seems to be out already.
    However, last Saturday I was able to buy a cleaning DVD, with less brushes compared to your fancy product, and it did the trick!
    Thanks again for your support, I really appreciated it!
    BR Wim
    Yes, for sure was the solution provided helpfull!
    I did receive quite some valuable tips and the material I was searching for.
    All of this resulted in a situation in which my problems were solved.
    Thanks, Drew!
  • 325 Answers
I have packed you the user manual for your player and the fireware upgrades needed. In the manual it explains the process of how to upgrade your firmware with the files I have supplied.
Please visit this link, download the file and continue with the user manual for the upgrade process!
http://www.mediafire.com/file/7ccrtr9mczyh4ub/Firmware%20and%20User.zip
Thank you and have a nice day...please rate if this helped you :)
Posted on Apr 01, 2011
  • 2 more comments
  • Andrew P.
    Andrew P. Apr 01, 2011
    DVD DR. is rated for both bluray players and dvd players so it is a disk to buy and keep around. It costs nearly $30-$40 but it's worth the recovery of the bluray player.
    Hope it goes well for you!
  • Andrew P.
    Andrew P. Apr 05, 2011
    Here is the link to the cleaning disk. The ratings are not the best, however I have had many successes with this disk and highly recommend it.
    http://www.buy.com/prod/digital-innovati...
  • Andrew P.
    Good work!
    Please don't forget to accept the solution and rate!
  • Andrew P.
    Thanks w_guijt8 glad it worked out for you!
Error message when my Blue Rays reads dvds
It's a software issue. you need to ring the manufacturer to get files and instructions on how to upgrade your machine so it can play the newer blu ray movies. Quite a common problem.
Feb 25, 2014 | LG BD550 Blu-Ray Player
Vizio vbr133 player . player starts to load disk and then reads no disk. tryed with different disk still reads no disk. error code HON7E
I was getting the same error and I could not get regular dvd or blu ray discs to play either. I dug out my old cd player lens cleaner and put it in and it started playing. I let it clean the lens for a couple minutes and now it is playing my movies again.
Jan 01, 2013 | Vizio VBR133 3D Blu-ray Disc Player
Loaded new blu ray disk today and the player will not recognize Display says "can not operte this disk" tried two new and the same response....no problemes before
try updating the firmware of the bluray. This is one downfall of blueray is that for newer bluray movies it requires new frimware to process the video :)
Dec 27, 2010 | Sony BDP-S350 Blu-Ray Player
Region code unlock
Turn on without disk and wait for "No Disk" on front panel display. On front panel,press and keep pressed Pause, while you enter 3,1,4,1,5,9 on remote. Release Pause immediately after the "9".
The word COdE is displayed on panel. Press number of region, or 0 for all regions. Then press Pause on panel again.
Nov 04, 2010 | Marantz BD7003 Blu-ray Player
I am trying to play Date Night in my blu ray. I can play any other blue ray I got besides this one. All I get is the update your bluray screen then it goes blank! It doesn't try to read the bluray it just...
Remove the disk. Go into the player's setup menu. Disable BD-Live. You may also need to clear the player's memory (maybe called cache, but depends on your manufacturer and model).
Now insert the disk and it should load right away and play normally. This is happening because new disks are trying to use the internet to connect to a server to download new features for the disk (that's BD-Live). This would be cool, except that in some cases it causes this freezing problem where you can't even watch your movie.
Firmware updates don't seem to fix it--at least not yet. So far this seems to be a combination of a coding issue on the disks and perhaps firmware that doesn't know how to deal with the new code. Please post a reply if it works for you.
Sep 29, 2010 | Sony BDP-S550 Blu-Ray Player
DVD Player Not loading Movies
optical sensor is burned out or the spindle is not spinning the disk to read it.
Nov 06, 2009 | Coby DVD-224 DVD Player
Blu-ray disc not playing movies
Try resetting the machine. Take the movie out, close the tray, press and hold both the stop and power buttons simultaneously until the machine shuts down completely... then turn it on. It will ask you for the first time settings again... beware that mine stated like that and the freezing movies until "No Disk" came up and now nothing will be read. I an taking it to Sears for an exchange (hopefully). I am disappointed with the performance so far. It's a SONY ****!
Jan 29, 2009 | Sony BDP-S300 Blu-Ray Disc Player
DVDM 1805
it sounds like you might need to clean the laser eye, try that and get back with me
Dec 10, 2007 | Denon DVM-1805 DVD Player
Marantz BD7003 Blu-ray Player Logo
212 people viewed this question
Top Marantz Televison & Video Experts
 Grubhead
Grubhead
Are you a Marantz Televison and Video Expert? Answer questions, earn points and help others
