My display problem in layer - Computers & Internet
  • kingnite Apr 01, 2011
    Please provide the exact error and when you are getting it.
  • Computers & ... Master
  • 27,725 Answers
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up a computer hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they are probably old and faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error
also
click start control panel administrive tools computer management device manager scoll to ports(com&lpt)right click to scan for hardware changes or scroll to monitors + to expand plug and play monitor right click where you have options to update driver,disable.uninstall,scan for hardware changes or select properties where in the general you have the option to troubleshoot also in the driver tab you have the same options as when you first right click on monitor
also
click start control panel,display,desktop you can select a different desktop from the drop down list also settings you can change the settings for more or less pixels or from the drop down list pick the appropriate level of color range or troubleshoot also select advanced then general dpi normal size,larger size or custom settings
always click APPLY after making any changes
hope this helps
Posted on Apr 01, 2011
Where can I find 2 layers long clothes rack?
Here are some examples for 2 layers clothing racks:
http://www.alibaba.com/countrysearch/CN/2-layer-clothes-rack-supplier.html
Apr 28, 2013 | Retail Supplies
My 99 cl has a check engine code of P1297 it says the ELD circuit low input. What does this mean and how do I fix it?
Improve the Fixya.com experience for everyone by voting!
This is just a fancy way of saying your instrument panel lighting is based on diodes.
Electroluminescent display: (More than you really want to know)
Electroluminescent Displays (ELDs) are a type of display created by sandwiching a layer of electroluminescent material such as GaAs between two layers of conductors. When current flows, the layer of material emits radiation in the form of visible light. Electroluminescence (EL) is an optical and electrical phenomenon where a material emits light in response to an electric current passed through it, or to a strong electric field.
Mechanism EL works by exciting atoms by passing an electric current through them, causing them to emit photons. By varying the material being excited, the colour of the light emitted can be changed. The actual ELD is constructed using flat, opaque electrode strips running parallel to each other, covered by a layer of electroluminescent material, followed by another layer of electrodes, running perpendicular to the bottom layer. This top layer must be transparent in order to let light escape. At each intersection, the material lights, creating a pixel.
Since you have a low reading, I'd check the wiring for a corroded ground or frayed wire,
All the best
Ben
Jun 05, 2011 | 1999 Acura CL
How to mix two images ? specially at border of picture.
1. Open the first image.
2. Open the image you want to merge or mix with the first image or border.
3. Press Ctrl + A to select the entire image.
4. Press Ctrl + C to copy the selected image.
5. Click in the title bar of the image you opened first.
6. Press Ctrl + V to paste the second image over the first image.
7. If the Layer window is not displayed press theF7 function on your keyboard.
8. Make sure the top layer is highlighted or click on the layer to highlight it.
You should see the border around the image. If you want to hide part of the top image at the bottom lower left of the layer window you will see rectangle with circle which displays add layer mask when you hover the mouse cursor over it. Hold the Alt key and click on the Add Layer Mask Icon. This will hide the top image until you select the brush with a white color and paint the layer mask layer. The Layer Mask is the black rectangle next to the layer image which must have the white rectangle around it when painting with the brush. If you do not see the top image mixing with the bottom image make sure the black rectangle is selected or click on the black rectangle to select it. If the layered image is selected you will be painting it white and alter the image. If you revile part of the image when painting the mask you can hide it by changing the brush color to black and painting the reviled layer to hide it again. Layer masks are very powerful which you will need to look up in the help files for more information to gain full power of the tool.
Jan 20, 2010 | Adobe Photoshop 7.0 for PC
White oval spot in center of screen on garmin 2720 gps
The touch screen is made up of several layers. A thin plastic layer, a micro thin metal layer, microdots for insulators, another thin metal layer, and a final plastic layer. All of these layers amount to the thickness of a sheet of paper. This whole stack is bonded to a thin sheet of glass and placed over the actual TFT display.
If the touch screen is still working the moisture probably isn't between the layers. My guess is moisture got through one of the gaskets and made it's way in between the touch screen assembly and the TFT display.
If you want to clean it:
Remove the six screw holding the case together.
Split the cases and pull the patch antenna out of it's slot.
Remove the four silver screws holding the display assembly into the front bezel.
Unhook the small ribbon cable that goes to the infrared receiver under the red lens.
Pull the display assembly out of the front bezel. It won't come all the way out because of cables.
Use a razor to cut the plastic tape holding the touch screen bracket to the TFT display.
Unlatch the 4 conductor ribbon connector nestled between the 2 big white wires.
Use a penknife to unbend the metal tabs keeping the touch screen from coming loose. I usually just do the ones by the IR receiver.
Now that the touch screen is in your hand you can carefully clean the moisture from between the two assemblies. The gaskets are tricky to install again but it can be done, maybe you'll see where they were leaking.
Jan 18, 2009 | Garmin StreetPilot 2720 GPS Receiver
Garmin 2720 touchscreen won't work, must use remote control.
I'll start with a comment I made on another post:
The touch screen is made up of several layers. A thin plastic layer, a micro thin metal layer, microdots for insulators, another ultra thin metal layer, and a final plastic layer. All of these layers amount to the thickness of a sheet of paper. This whole stack is bonded to a thin sheet of glass and placed over the actual TFT display.
It's amazing that you can see through all these layers and only lose 20% of the light. What's not so amazing is that those thin metal layers are prone to damage. I've seen several with no apparent damage that didn't work, and several with visible scratches that worked fine.
I usually start by installing (or reinstalling) v7.2 firmware and then attempt to recalibrate the screen, sometimes that works. Next I would try re-seating the 4 conductor touch screen pigtail in it's ZIF socket nestled between the big white wires on the display assembly. The last resort is to buy a broken 2600 or 2700 series Garmin and salvage the touch screen. Actually the real last resort is to have Garmin fix it for a flat $250. Good luck.
TyTn II unresponsive touchscreen
Try to calibrate the touch screen. Also clean it with a soft cloth. But calibrating it should help the film when you tap the screen.
Apr 16, 2008 | HTC TyTN Smartphone
Touch screen won't calibrate on garmin 2720 gps
The touch screen is a 4 wire resistive type made up of several layers. A thin plastic layer, a micro thin metal layer, microdots for insulators, another ultra thin metal layer, and a final plastic layer. All of these layers amount to the thickness of a sheet of paper. This whole stack is bonded to a thin sheet of glass and placed over the actual TFT display.
It's amazing that you can see through all these layers and only lose 20% of the light. What's not so amazing is that those thin metal layers are prone to damage. I've seen several with no apparent damage that didn't work, and several with visible scratches or cuts that worked fine.
I usually start by installing (or reinstalling) v7.2 firmware and then attempt to recalibrate the screen, sometimes that works. Next I would try re-seating the 4 conductor touch screen pigtail in it's ZIF socket nestled between the big white wires on the display assembly. The last resort is to buy a broken 2600 or 2700 series Garmin and salvage the touch screen. You could send it to Garmin for a flat $250, but that makes no sense at all.
If you get another screen (Garmin won't sell you one), Here's how to replace it:
Unlatch the 4 conductor ribbon from the ZIF connector nestled between the 2 big white wires.
Use a penknife to unbend the metal tabs keeping the touch screen from coming loose. I usually just do the two by the IR receiver.
When you reassemble, don't get frustrated with the gaskets, they're tricky but it can be done. Tom
Sep 30, 2007 | Garmin StreetPilot 2720 GPS Receiver
Computers & Internet Logo
11 people viewed this question
David Payne
David Payne
