Question about Ricoh Aficio BP20N Laser Printer
I am looking for thresdhold when the Ricoh aficio sp c420dn printer sends out the toner low message. Is it 15%? I cant find this anywhere. There are other Ricoh models also.
  • Ricoh Master
  • 4,338 Answers
Ricoh sense toner in the following methods:
Toner Near End
To detect the toner near-end, the machine uses:
Pixel count (memory chip on the AIO)
AIO rotation distance (memory chip on the AIO)
Toner End
To detect toner end the machine uses:
Output from the TM sensor (center)
After near-end, it is estimated that 200 pages (A4, 5% coverage) can be printed until toner
end occurs.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Posted on Apr 01, 2011
My Ricoh Aficio SP C420DN Laser Printer shows color tone SC366 and some time SC365, any ideas?
You just have a problem with colour PCU (SC 365 - magenta, SC366 - cyan). The main reason is that toner density is abnormal. Sometimes, when you replace toners, printer receive to much toner for a short time, and after that you have an abnormal toner density (higher). You can check in service mode (hold up and down arrows for 6-7 sec, release them and press ok button) following thing :
choose 2. engine
then with arrows choose 3. process
then choose Vt display,
for each color by default there should by somewhere arround 2.4V. If you see for some colors, for example 0.02V, then this is a problem(to much toner). In this case the only thing that you can do is to restart printer and try to print enough pages, filled with problem color. Usually you can print max 3 pages. Then restart printer and try another 3 pages. Print until the you will be able to print at least 4 pages continuously.
Good luck and remember that this is a technical problem and you should ask someone qualified for the job. I am sure that 80% of service engineers can't repair this issue. But I can.
Apr 17, 2015 | Ricoh Aficio SP C420DN Laser Printer
I know how to replace it But Where can I find the waste toner bottle in Aficio MP 8001
In the manual (free download) here: Aficio MP 6001 6001 SP 7001 7001 SP 8001 8001 SP 9001 9001 SP download page I can't find any entry about waste toner, only the waste toner can't be reused, but no entry where to find the container. Sorry
Feb 09, 2015 | Ricoh Aficio Mp 8001 Copier - 910k Copies...
What could be the problem on ricoh printer sp c420dn its given me error code sc 364
Probably you have just replace some of the toners (black). The toner density is too high. Restart printer and try to print full A4 black page.
Aug 30, 2014 | Ricoh Aficio SP C420DN Laser Printer
What the solve Ricoh Aficio c420dn error code sc304
Check your charge roller. . Try replacing the charge roller.
Jul 06, 2014 | Ricoh Aficio SP C410DN Laser Printer
Color Laser Printer Pink Tint
have you tried cleaning the charging wire and the transfer belt
Feb 17, 2014 | Ricoh Aficio SP C420DN Laser Printer
I have ricoh laser printer aficio sp c420dn showing error code SC270
sc270 is an error with the shutter on the laser unit. Turn the machine completely off and then back on -- if the error doesn't clear, the shutter sensor or motor will likely need to be replaced.
Feb 16, 2011 | Ricoh Aficio SP C410DN Laser Printer
Ricoh Aficio SP C420dn Printer. The printer at
sc491 is a high voltage output error. Combined with your jamming issue, it sounds like a possible electrical problem somewhere. A good first step is to turn the machine off and unplug it, then take off the covers and reset any connections or cables you can get to.
If the problem persists, you should have a service technician take a look at it because it might need a board replaced.
Apr 27, 2010 | Ricoh Aficio SP C410DN Laser Printer
Ricoh Aficio SP C410DN toner error.
Did you follow the instuctions to shake gently then remove all tags prior to placing the toner? Is it a toner/drum unit. look underneath if theres a green drum. After market toner will not work.
Aug 16, 2009 | Ricoh Aficio SP C410DN Laser Printer
Ricoh Aficio SP C410DN "set toner cartridge correctly"
It sounds like the part the toner bottle slides under to lock in place is broken. you could try and fold some paper and tape it to the toner to hold it down.
Mar 26, 2009 | Ricoh Aficio SP C410DN Laser Printer
Ricoh Aficio BP20N Laser Printer Logo
308 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
OfficeServiceAjnc
OfficeServiceAjnc
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
