Question about Samsung Freezers
Our RL33SBSW fridge/freezer leaks water from the freezer department. What do we do?
2 Suggested Answers
mgprice
  • 744 Answers
SOURCE: water pools at bottom of freezer, freezes and water leaks out
Hello, this sounds like you have a blockage in the drain tube, remove bottom shelf from fridge and remove the styrofoam..you may see ice build up...melt ice with hair dryer/heat gun...you will see a pan below evaporator...melt ice in pan...dry water up in pan with paper towel...now you should see a hole in pan that leads to drain tube...pour some hot water in pan..wait a couple minutes..mop up water and repeat this step 2-3 times....once you have done this find some flexible curatain wire or electrical wire..poke down the hole until you see the water drain..now it is clear..put back panel back and you are good to go. The reason you see water in the Freezer is because the water has been leaking into the freezer instead of running into the drain hole...Please feel free to comment again if you need any further assistance. Mike
Posted on Aug 31, 2009
Why ismaytag bottom freezer leaking water?
Try clearing all vents - inside (make sure vents not covered - in fridge and freezer) and outside (gently vacuum - the coil areas in the back and bottom of fridge)
Sep 05, 2014 | Maytag MBF2258XEW 21.9 cu. ft....
Kelvinator fridge freezer
  • If your refrigerator leaks water, you have a problem with either a water line or a drain line. If your refrigerator has an automatic icemaker or a water dispenser, the water supply line could be broken. Automatic icemakers have a drain line that runs down to the drain pan beneath the fridge. Mold build-up inside the drain line can lead to a rupture that allows water to escape .A broken drain line can also lead to water leaking from your refrigerator.
Dec 16, 2013 | Freezers
How to access drain hole for maytag model mf12269vem3
please check your ice maker to make sure it is not jammed up water can leak into fridge
Nov 01, 2013 | Freezers
GE side by side. Water leaking from bottom of freezer door. Fridge is cold. Freezer is fine. Ice maker fine. Only problem is the leaking water
It means that the freezer door is not closed will see the rubber frame it maybe broken some where or twisted .
If it's broken it must be changed but if it's twisted you can use some medical cotton roll it by your hands like a pen and insert it behind the frame.
I hope that help you. so sorry for my bad English.
Feb 12, 2013 | Freezers
Water leaking from underneath. Not currently
This could be a blocked drain.Behind the fridge is a hose/pipe running from the inside of the fridge down to the compressor where the water will then evaporate.If this pipe is blocked,the water will push up back into the fridge.Try to blow the hose clean from inside the fridge.This should solve your problem.
Regards
Andre Nagel
Mar 13, 2010 | Freezers
Water pools at bottom of freezer, freezes and water leaks out
Aug 31, 2009 | Freezers
Fridge constantly dripping wet
water inside, too much condensation from humid air entering fridge from bad seals. replace the seals. could also be that the condensate drain is clogged. if it's leaking from the bottom of the fridge, make sure the tubing is still inside the condensate pan underneath the fridge.
Aug 24, 2009 | Whirlpool Freezers
Water leaking from underneath the unit
hi thanks for the question is there water inside the fridge or freezer if not then the leak is coming from the drain tray at the back make sure the drain hose is located in the tray not outside the drain tray thanks the appliance doc
Sep 27, 2008 | Freezers
Water Dripping Inside
Sounds like a blocked defrost drain. By "American" I presume you mean side-by-side.
I had a similar problem with a freezer-on-top style Samsung. The solution to that was to defrost the freezer, remove the false backing plate in the freezer (required removal of the ice cube tray. the panel just pops out with a bit of pulling). The drain hole beneath the freezer coils was blocked with ice. This drain passes down into the fridge and then out the back of the fridge into the evaporation pan next to the motor. There is a collector pan under the freezer coils, this and the drain hole were filled with ice. When the freezer goes into its self-defrost cycle the water collects here and then overflows into the fridge.
I removed the ice with hot water/vinegar mixture (so it doesn't re-freeze immediately) and simultaneosuly used a bit of chiselling with a screwdriver to clear the drain plug. I did this from inside the fridge working up the drain hole into the freezer. The whole job took about an hour.
Aug 24, 2008 | Freezers
Open Questions:
ca. 2010 GE fridge with Samsung ice maker. I have to hold the reset on the icemaker every few days to keep making ice or it quits. What's the fix? When it works, there's a loud popping every 3 seconds for about 2 minutes, then a few minutes later ice harvests into the bin. With my hand against the outside of the fridge next to the icemaker, I can literally feel each pop. I originally thought it was the ice release heater failing that caused cubes to pop loose hard, but I couldn't find anything wrong electronically when I took things apart and examined the board and connections in the icemaker. I may have missed something mechanically that's causing some part to flex and then suddenly give against the wall inside every 3 secs as the clock cycles through the beginning of a harvest? What might that be? But after reassembly it now has the added feature of harvesting a few times and then stopping altogether. We run flat out of ice if I forget to press and hold the reset button for 10 secs. every few days. Apparently the clock is cycling incompletely or something now. Could a cog be missing/broken/out of alignment in the clockworks, such that when it gets so far along it slips, but can be reset? How about the lift arm? Could it be out of position inside such that something it's connected to isn't properly repositioning when the arm drops back down? Or could all of this be related to a faulty control board elsewhere in the fridge?
Apr 19, 2017 | Samsung RS261MD 26 cu. ft. Side by Side...
Freezers Logo
67 people viewed this question
Top Samsung Freezers Experts
Dan Webster
Dan Webster
Jay Finke
Jay Finke
ray gallant
Are you a Samsung Freezer Expert? Answer questions, earn points and help others
