Question about Dell Inkjet 720 Printer
Paper drags to the right and won't print--worked yesterday!
  • 20 Answers
Sounds like you might have a small piece of paper stuck in the paper path that is causing it to feed incorrectly. Check the paper path.
Posted on Apr 01, 2011
How can I fix a paper jam in my Panasonic 4530 ?
look inside the printer, some where in or around where the paper feeds from the area there is a piece of paper that is stuck or has ripped off inside the machine, you going have to look with flashlight follow the feed rollers and you will find paper, paper clip, a staple, dirt, something blocking the rollers or feeder from working right.
www.ask.com/panasonic_4530_paper_jam/
www.ask.com/panasonic_4530_error_code_j50/
www.ask.com/panasonic_4530_where_is_paper_jam_located/
Apr 22, 2015 | Panasonic WORKiO Office Equipment &...
Why do my pictures look faded with up and down stripes?
Check the paper to make sure you are using the correct paper type for the project. If the paper is too fibrous, the ink applied by the printer might not fully cover the print surface.
  1. In the program being used for printing, click File , and then click Pring . The Print window opens.
  2. Make sure the appropriate product is selected, and then click Preferences or Properties . The Preferences/Properties window opens.
  3. Click the Printing Shortcuts tab. Consider modifying some or all of the options in the Printing Shortcuts menu to increase print quality.
    • Print quality : If the quality of the printouts is not acceptable, try increasing the print quality. To print more quickly, try decreasing the print quality.
    • Paper type : If one of the options matches the paper type exactly, select it instead of Automatic .
    • Paper size : Make sure that this option matches the paper loaded in the product.
    To see additional options, click the The Advanced Features window opens. Consider changing the following option: Ink volume : Adjust the amount of ink that prints on a page. For lighter images (less ink), drag the slider to the left. For darker images (more ink), drag the slider to the right. The lighter the ink volume, the more quickly the printout dries.
Press and hold the asterisk (* ) and pound (# ) buttons on the product control panel.
  1. When the control panel reads *******#######, release the asterisk (* ) and pound (# ) buttons.
  2. Press the 3 , 2 , and 9 buttons, in that order.
  3. Press the right arrow button (c00420524.gif ) to select Special Reports , and then press OK .
  4. Press the right arrow button (c00420524.gif ) to select Print Cartridges , and then press OK
Aug 12, 2010 | HP Officejet J5780 All-In-One InkJet...
I want to print on photo paper I have no idea how to start,printer is a photosmart 7450
OK, Assuming you have Photo paper loaded in your printer and your photos from your camera downloaded to a photo software program. eg Adobe Photoshop/ Serif Photoplus etc.
Bring up the photo/photos you wish to print on your photo software. eg click on the open yellow folder top left and open the fotos you want.Click 'Browse' if you don't see the ones you want. ( Open as many as you want to print.)
In order to make your prints economical you can print two or three fotos on one sheet. Click 'File', 'Print multiple' and you will see format sheets in the right pane. If you only want to print two pics on one sheet click in the right pane on the two 7 x 5 sheet or, to print three pics of the same or different pics click the sheet with three frames on it. You will now see your pictures in the right hand frame and the format sheet in the right hand frame.
Left click and hold on the pic you want and drag it into one of the boxes in the right hand frame - let go.
That pic will now appear in the box selected. you can now size it to the box it is in. If it is the right way up eg portrait in top left of a three frame page click on fit to frame to maximise picture. Click and drag another pic from the left side frame to another box in the right frame. If you have chosen the three option sheet click and drag your next foto into the bottom box on the sheet. This is a Landscape box but don't worry.
After dragging your pic into it look for an icon in the function bar along the top where, when you hover your cursor over it, says - 'rotate and fit'.(It's a square with funny corner bits!) Your pic will the be realigned to fit the the box. Having all the pics you want on the sheet click the print icon. (Picture of a printer on the tool bar.) when the print box appears click on 'Properties' and open the 'Paper/quality' tab. click the drop down box for paper and select HP Photo paper - gloss or whatever you are using. The quality will automatically set to 'Best'. Click OK and OK and the files will be transferred to your printer and it will shortly start printing your pictures.
Bset of luck.
Any problems at all, just get back to me.
Cheers.
Ian
Dec 01, 2009 | HP Photosmart 7450 InkJet Printer
My printer Epson Stylus PHOTO R230 does not print
The printer does not print only dragging a paper without printing.
3 option to solve
make sure your
1. heads are working
2. flex cable connecting the heads
3. main board
Most common that i found is to replaced the main board. or replace parts of other main board if you have some extra. hope it can help.
Jun 29, 2009 | Epson STYLUS R230 InkJet Photo Printer
Paper Jam
Clean it. Follow the online directions.
Jun 09, 2009 | Canon PIXMA MP130 All-In-One InkJet...
HAS BEEN WORKING GREAT. YESTERDAY IT DECIDED TO
unplug the usb from the back of the printer. shut down the computer.
Make a copy by placing something on the scanner glass on top and pressing copy.
if it copies that means the hardware is okay.
reconnect the usb and reboot the pc. it would start printing any spooled up print jobs that got jammed when the paper got jammed.
if that dont work look at the bottom right and see if there is a printer icon at the bottom right. if there is double click on it and cancel all pending jobs.
reboot
if the copying dont work that means the paperjam killed the printer and you need a new one.
Cheers
rate if you got a fix . if not you know what happened.
Feb 18, 2009 | HP PSC 1315 All-In-One InkJet Printer
New cartridges - printer not printing
Align your cartridges to solve print quality problems such as: • Characters are not properly formed or are not aligned at the left margin. • Vertical, straight lines are wavy. 1 Load paper in the paper support. 2 On the control panel, press Copy. 3 Press Options until Maintenance appears. 4 Press the right arrow until Align Cartridges appears, and then press Select. An alignment page prints. Once this page prints, your automatic alignment is complete.
Please rate this solution.thanks and good luck.
Jan 22, 2009 | Lexmark X6170 All-In-One InkJet Printer
Paper tray default issues
you need to go into the print menu on the printer and change the paper tray size back to letter, when you have it right there will be an asterik next to letter confirming that it was programmed
http://www.websitetoolbox.com/mb/copierquestions
Dec 23, 2008 | Ricoh Aficio SP C410DN Laser Printer
Paper in all trays, but won't print
try putting paper in the bypass unit on the right end of the copier by pulling the shelf down.
Dec 14, 2008 | Kyocera Mita KM-3035 All-In-One Laser...
Photosmart C6300 pictures are printing very wet and grainy. printer is also very loud - almost as though the parts were scraping and banging.
Sounds like you have the wrong paper setting in your print properties. I would use photo or high bright 24lb paper and set the paper type in your printer properties prior to executing the print job.
Regards,
Worldvet
Nov 12, 2008 | HP Office Equipment & Supplies
Dell Inkjet 720 Printer Logo
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
