Question about Kicker ZR1000 Car Audio Amplifier
Protection mode stays on constant until amp powers up.
  • 6,993 Answers
The amp will go into protection mode when there is a short in the speaker wires or the amp was overloaded. Verify that none of the speaker wire connections are loose at the back of the receiver or at each speaker. And verify that none of the wires are making contact with each other.
If it is, then remove the speaker wires and connect them again properly. After disconnecting the speaker wires, unplug the amp for 10 to 15 minutes. This will make the overload protection back to normal
Try this and let me know. I hope this would solve the issue
Thanks
Posted on Apr 01, 2011
Red power/protector light
The amplifier has gone into protect mode and will stay in that mode until the cause is corrected.
Nov 17, 2013 | Sony Xplod 800W Class AB Bridgeable...
I have a bamf 5500 series and the amp is on and working but when i turn up the volume the amp will go into protect mode and stay there untill i turn the volume back down then the amp comes out of protect...
you probably have a blown sub(s) that short out when the volume is turned up. it would be a good idea to find out which one(s) is bad and replace it. sooner or later it may make the amp go bad if not replaced or removed.
Jan 06, 2011 | Power Acoustik BAMF5500/1D Car Amp
Its in protect mode and wont go back to normal
disconnect everything except the power, remote, and ground. turn off then on. if it goes into protect mode then there's a posibility that the amp if fried. check all the speaker inputs and outputs to make sure that there are no stray wires shorting out. if it stays on then you may have a short on a speaker wire or an auxilary input wire. plug each one in one at a time until it goes into protect mode, then that's the shorted wire or it could be a shorted speaker.
Aug 09, 2010 | Nitro BMW-486 Car Audio Amplifier
Does the power indicator light stay constant when power is on or does it flash?? pioneer gm-5400t amp
should stay on . I suspect it is in protection mode . disconnect ALL input rca,s and speakers then try again to power it up. if still no good it could be blown. check fuses etc .
Jun 16, 2010 | Pioneer GM5400T 2-Channel Bridgeable...
My 450 watt fusion amp is now in ''protect mode''. how can i fix this?
Start by completely turning off the power to it and anything connected to it. Turn all levels down to there lowest volume settings. Check to be sure your speakers are not shorted. Be sure the power voltage is correct. Turn on each of the items, the amp being last. That probably will resolve the problem but I am not that familiar with the unit just trying to help. Most units have stay in protect mode until I cycle the power. Typically they monitor the speaker current hence a short would cause almost an instant protect fault.
Good Luck,
Gilshultz
Dec 01, 2009 | Car Audio & Video
My kenwood kvt 514 is in protect mode
It sounds like your amp is not grounded properly and is tryin to use your radio as a ground through the RCA's or there is a bad channel (dead short) in the amp.
Jun 02, 2009 | Car Audio & Video
Protect Mode
first I would advise you to tighten all of your ground and power connections. Then I would suggest that you expose the circuit board and start the amplifier warm up process, once the amp comes on I would use freeze spray to cool down various components in an attempt to find the component which has become thermally sensitive. Once you find the component I would suggest replacing it and the putting the cover back on the unit.
I hope this helps,
Thank you,
Shuttle83
http://www.electron-age-technologies-llc.com
Dec 09, 2008 | Infinity 475A Car Audio Amplifier
Why does my amp stay in protect mode?
The most common reason an amplifier goes into or remains in protect mode is shorted output transistors. To eliminate other possible reasons for it to go into protect, read the following page.
Troubleshooting - Amp in Protect Mode
Aug 03, 2008 | DHD NTX-2139 Car Audio Amplifier
Amp stays on all the time
hi. your amp has an internal power supply fault. problem lies in the remote turn on regulator circuit or with the pulse width modulating circuit.this fault definitely needs to be in technicians hands. cheers
Aug 04, 2007 | Infinity Reference 7541a Car Audio...
Amp staying in protection mode
No, this amp is not a heavy power consumer- matter of fact it takes very little power to run.Maybe you should check the fuses on the amp to see if they are what is recommended.Also check your fuse kit to your amp- your fuse might not be big enough.If neither works take it back where u got it.
Jan 01, 2007 | Soundstream XTA880.2 Car Audio Amplifier
Car Audio & Video Logo
63 people viewed this question
Top Kicker Car Audio & Video Experts
Tygh Duval
Tygh Duval
hoyzee1
Are you a Kicker Car Audio and Video Expert? Answer questions, earn points and help others
