Question about Garden
I want to replace the blade on my 10"compound miter saw but the bolt for the arbor is frozen up. I have tried everything and of course now the bolt head is stripped. I am assuming the bolt loosens to the left as most do but is there any chance the bolt loosens to the right ? It is a Delta model 36-220 type 2 . Help !!!!!
    Sergeant:
  • 259 Answers
Yes sometimes the bolts are left handed thread. What you can try is find a metric socket that starts to go on to the nut and tap it the rest of the way on the nut with a mallet then try to unloosen the bolt.
Posted on Apr 01, 2011
I have the blade bolt off of my ryobi miter saw but the blade wont come off of the spindle
tap the blade on the back side to loosen it off. The wood sap has probably dried out and is acting like a glue on the back flange washer.
Feb 13, 2013 | Ryobi ZRTS1342L Factory-Reconditioned 14...
Can't unscrew arbor nut on my MS250 Delta Miter Saw. Tried everything to turn it counterclockwise with no success.
The arbot bolt on your saw has reverse threads or righty-loosey, lefty tighty. You should be turning it clockwise as you are looking at it or in the same direction the blade turns when cutting. The arbor bolt on these saws are reverse thread so that they are self tightening while the saw is in use.
Feb 08, 2012 | Saws
I'm having problems replacing the blade on my Hitachi C10FC2 miter saw
it should have lock button some wear on it push it in. this will keep the blade from move. so you and take the blot off
Jan 18, 2011 | Hitachi C10FCE2 10" Compound Miter Saw
How do I replace a blade on a Delta 36-585 miter saw
There should be a wench on the mecnine that fits the bolt. the bolt turns in the oppiste derection as a normal bolt its called left handed thread this keeps it from coming lose during use. There is a buttom you need to press to lock the shaft then lossen to bolt lift the blade gaurd replace the blade note the washers that go up against the blade and make sure you install then in the same order as they were removed
Dec 17, 2010 | Delta SM100M 13 Amp 10" Compound Miter Saw
How do i get guard out of way to replace blade..DW718
Make sure the saw is unplugged, manually move the blade guard up to it's fullest extension, push the arbor lock to make sure the arbor and blade do not spin (on front of saw motor housing), then wrench the nut holding the blade to remove. Remove the old blade, install new one and reassemble in reverse order. You can take the guard off completely if you choose, but it is not necessary. I hope this helps and good luck!
PLEASE REMEMBER TO VOTE AND LEAVE A TESTIMONIAL. THANK YOU
Mar 30, 2010 | Dewalt 12" Beveling Sliding Compound Miter...
I've been using dewalt miter saw dw715 for several years and it's been working great. I just moved and today I used the saw in the new place, on an uneven concrete tiled ground. After several cuts, I...
This is common IF the blade clamping nut becomes loose... the blade will free wheel on the arbor after the motor stops. It can tear up the arbor so investigate this possibility immediately.
Feb 19, 2010 | Dewalt DW715 Heavy Duty 12" Single -...
How do i change the blade on my delta 10" mitre saw
Exploded diagram for your SM100M miter saw is here.
User manual is here.
Page 20 covers blade change operation.
Make sure you unplug your saw! You need to remove a screw from the cover and rotate the cover to the rear. Use a hex wrench in the motor shaft to keep the saw blade from turning, and loosen the arbor nut with a 1/2" wrench. The arbor is reverse threaded, so you'll turn it clockwise to loosen, then counterclockwise to tighten it up after you have swapped the blade.
Rotate the cover back after that's done, and replace the screw.
If this was useful, please vote. Thanks.
Nov 23, 2009 | Delta SM100M 13 Amp 10" Compound Miter Saw
I am looking for a repair manual for my 10" ryobi
Takes a bit of navigating to reach it, but I'll try to help you get there.
Start at this page HERE.
Click "Repair Parts Catalogue"
Click "I HAVE READ THIS PAGE & AGREE TO THE TERMS PROVIDED".
Click the "Model" tab located at top left of page.
In the box labeled "Model Name/Number" type in the following without the brackets [TS1342] and click the "Search" button to the right.
One (1) Result should be found. To the right is a list of two available drawings.
The one you seek is "General Assembly"
Hope this helps,
Dolf-
Oct 15, 2009 | Ryobi ZRTS1342L Factory-Reconditioned 14...
Changing the blade to our compound miter saw when hex slot is rou
ok a couple things to try...
Firstly to hold the blade arbor still if it doesnt have an arbor/spindle lock button, try wedging a piece of wood between the blade and the saw table (might have to lower the cutting head and hold it down. Next try again with the hex key... Make sure it is the right size one, i.e. the one that came with the saw. If the hole is really rounded out, you are in a bit of a bind, however, the next option is to get a grinder and try and slice a groove across the nut so you can fit a large screwdriver or a flat piece of steel in th slot in the nut you just made for leverage and try and work the nut off that way. Either way, be sure to get a new blade nut if and when you get it off to make sure the problem doesn't occur again. See how you go.
Jun 20, 2009 | Sears Craftsman 7-1/4 in. Circular Saw...
How do I replace my mitre saw blade?
It should still easily fit a 5/8" blade. The arbor shape shouldnt have any effect on the type of arbor hole needed on the saw blade (only round arbor holes are made on saw blades. You will probably find the arbor securing nut has a shape that fits into the flat gaps between the saw blade and the arbor when fixed. So grab a 5/8" round arbor saw blade and give it a go. It should work fine.
It is the arbor nut that secures the blade onto the arbor via friction which holds it on.
Please rate this solution on FixYa!
May 29, 2009 | Ryobi ZRTS1342L Factory-Reconditioned 14...
Garden Logo
75 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
