Question about Watches
When I try to refill my dunhill 70 rollagas lighter with zippo butane refiller with a nozzle the lighter becomes cold and it takes the gas, however as soon as I stop trying to put gas in the gas escapes, it comes out of the base of the lighter. I know you shots use a dunhill butane filler but the nozzle on the zippo seems to fit and for the butane to hiss out it must be taking it in?! Do you think there is a fault on the refill valve? I don't know enough about them really and I've just purchased it. Please help! I'm getting do frustrated. Thanks a bundle
2 Suggested Answers
escapement
  • 2334 Answers
SOURCE: refilling a dunhill lighter
All rechargeable lighters have a refilling nozzle (usually at the bottom of lighter).
All the good quality gas refill cans have the nozzle adapters inside sovering cup.
Brake off the nozzle adapters off the cup and try to fit them onto lighters refilling nozzle.
When found the best fit adapter, put it onto gas refill cans nozzle and holding the lighter and can upside down connect all nozzles together and push together.
As these nozzles are made for mass production lighters, tey do not fit perfect and some gas leak will occure.
Anyway- few seconds will be enough to refill any lighter.
In case if your lighter do not refill by explained action, the refill nozzle in your lighter is damaged or faulty.
Hope it does help.
Do not forget to rate, please.
Posted on Jan 23, 2009
I have a model 35002 triple torch Colibri gear lighter and I need instructions on how to refill it with butane.
There is a small nipple on the bottom of the lighter. That is where you put the canister on to refill.
Dec 12, 2015 | Colibri Watches
I have a dunhill lighter pat. #3910750 des. pat. #235456. When I fill it with butane, it leaks out of the top of the lighter. What is causing this?
Sounds like the valve that regulates the gas flow is sticking in the open position even when the lighter is not in use. Try spraying a light machine oil like WD40 on the gas jet aperture and any other moving part whilst your at it. Wipe excess oil from the lighter and leave for several minutes for the oil solvents to evaporate. Light the lighter a few times in rapid succession to enable the oil to penetrate. If the oils done it's job the gas should no longer leak.
Jan 02, 2014 | Watches
Lighter was dropped and the gas reservoir leaks continuously
Gas leaks in a lighter most commonly come from one of two places: the refill port, where you charge the lighter, and the exit port, where the gas exits to be burned.
To confirm where the lighter is leaking, try immersing the refill port in some water. If the lighter is charged and you see bubbles, that's the source of the leak. If you don't see a leak there, try holding the top of the lighter briefly under water to see if it bubbles there. Because electronics may be present at the burn port of the lighter, you want to make this immersion as short as possible. You also want to let the lighter dry completely before attempting to light it again, so you don't accidentally short-circuit something. If you're really worried about shorting it out, you can dab a bit of a soapy solution on the burn port with a Q-Tip instead of immersing the whole lighter tip in water.
Imagine the refill port like a bicycle valve--when you push down to open it, gas can flow in (or out). When you release pressure, that port is supposed to close up again completely. If it is not closing correctly, you can try to look for a piece of something--a shard of plastic or metal, a tiny grain of sand--that is preventing it from closing. However, because this valve is pretty well protected, it's less likely to be the source of the gas leak than the burn port.
The burn port is opened and closed by a mechanical switch. Possibly, a little door flaps open or you push a lever. Each of these triggers opens the burn port, and letting go of the control is supposed to let it close again. If you dropped the lighter on its head, it's possible that the linkage controlling things may have gotten bent or even broken. In that case, the gas port may no longer be closing properly.
The bad news is that once you have diagnosed your gas leak, you don't have a great many repair options. It may be possible to repair a bent or disconnected control at the lighter head, but it is rarely cost-effective to do so unless you simply have to unbend or re-align existing parts. Repair of the refill port, because it likely requires replacement of the gas storage tank, is also usually not cost-effective.
May 08, 2011 | Watches
Vintage Maruman GL 67 butane lighter - gas valve is leaking. is it possible to get replacement or repair? It's Japan made.
I just found my old maruman dl-6 lighter, but it won't start. How do I put fluid into it? on bottom it say gas is that where fluid goes and what type.
Apr 14, 2011 | Watches
I have a gold Dunhill lighter which belonged to my partner who passed away a few years ago. Whilst he was still alive I sent the lighter away to be cleaned etc, the shop I sent it through has now closed...
If you go to their web site http://www.dunhill.com/en-cn/catalogue/lighters/ at the bottom of the page you will see find a service center and find a store.
Click on one of these and you should be able to find the information you want.
Apr 04, 2011 | Dunhill Watches
Fixing a dunhill lighter with a small leak, can I pack this or do I need to take this in to a shop? many thanks, Jayson
I have a Dunhill Rollalite petro lighter and the wick is barely protruding out of the nipple / port. Everything thing I've read states to use tweezers to extend it but how is it done when there's nothing to crab? Are the wick replaceable and if so how is it done port how to extend it? Thanks
Feb 08, 2010 | Dunhill Facet DQV911AL Wrist Watch
I've inherited a dunhill lighter and want to identify it, can you help?
I suggest that you go to the Dunhill web site (www.dunhill.com) and go to the bottom of the page where you will see a menu in small type.
Click on "contact" and you can choose the nearest center. They should be able to answer your question.
Feb 01, 2010 | Watches
Refilling a dunhill lighter
Hope it does help.
Jan 23, 2009 | Dunhill Watches
Dunhill cigarette lighter spare parts needed
Hi, Dan, I have 2 Dunhill ighters that work but they leak butane. Making them unfit for use. I would like to have them repaired/rebuilt. I believe they are 1960-70's vintage so, the lack of parts will definately be an issue here. Please advise. Thanks Glenn ghelfne1@nycap.rr.com
Jan 30, 2008 | Watches
Watches Logo
281 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
