Question about Kitchen Ranges
I have repeater gr500 motorola uhf band .i want link two repeater togather .and how to prpgram it .thanks
  • adham_ali90 Apr 03, 2011
    hallo
    1- repeater gr500 motorola.
    2-uhf band frequncy 455.1000+the repeater and the remotebase frequncy as you like.
    3- the distanse between two repeater 30 klom.
    4-i use basestation inside the repeater .and the remotebase (gm160 )motorola
    if you want any information tell me to send
    thanks.
  • 1,555 Answers
Kindly first let me know is that GP500 or gr500 secondly what is the channel you are using and what is the distance between two repeater station. Further, what is the units utilised for reception they must be multiple but kindly let me know the make and model.
Posted on Apr 01, 2011
How to I syncronize all my radios so they work together
Karen-
Contact Motorola Solutions
Get Support
Mark
Motorola Mobility Support
Jan 09, 2015 | Motorola 4 Magone Bpr40 Uhf
Can I reprogram my tk-2400 with my PC?
No. It is programmed from the Factory on a chip. Preprogrammed. No software will change it, no hacks. Many Motorola radios like that too. It is two watts, Vhf of Uhf, you did not say. If your existing frequencies are Business Band and in the same frequency band (Vhf or Uhf) you can get it to match those.
Oct 13, 2014 | Kenwood Radio Communications
How do I know if my Motorola CP185 is UHF or VHF without taking it to a dealer for programming?
Hi christo,
Yes the serial No. usually indicates the frequency band the radio works on, but not always, because a lot of radios nowadays can operate on both VHF & UHF, so not being familiar with your model, I can't give you a definitive answer.
I do have the feeling, for what it's worth, that it is in fact a UHF band radio, but don't take that as gospel.
Anyone else reading this post is most welcome to assist in helping a friend out, we would much appreciate your input, thanks.
Hang in there my friend, there will be an answer soon.
Cheers, Peter
I'll look into it further as well....
Jul 11, 2012 | Motorola CP185 (16 Channels) Two Way Radio
How to reprogram two way radio, its a motorola gp 339 and its set to 5 channels from when i brought it, can i reset it or reprogram it to normal uhf channels?
In order to reprogram this Motorola GP339 you need to have a programming software, radio interface box and programming cable for this radio then you can read and change frequency in it. To reprogram to UHF channels this radio must be in UHF band. Good luck!
radcom907
May 14, 2010 | Motorola GP300 Compatible 2 Way Radio...
Looking to build a two way radio system.
You will have to have a vehiclular repeater that is in another band than the mobile so if your portable hand held radios are on UHF then I would advise a VHF high band repeater set up.
It will have to be a cross band setup meaning it will recieve UHF and transmit on VHF and also the opposite direction.
It will have to be programmed with CTCSS or PL of some kind to avoid interference and don't forget it will need to be FCC licensed for those frequencies if it is in the Business band.
Some mobile radios can be wired up through a mini controller and run that way if it is compatible.
Apr 28, 2009 | Motorola For SP50 7.5v 1500mAh NiCd...
Radios comparable?
First, select the radio frequency band which would best suit your needs. (ie: VHF, UHF or 900 MHz) If you are talking in and around concrete and brick you would want to select the UHF or 900 MHz.
Second, with your frequency band chosen, narrow down the field of radios which have the features you like. (ie. number of channels, amount of wattage, text messaging, or plain jane, etc.)
Third, compare apples-to-apples. If you decide a 1 channel, 4 watt UHF radio would suit your needs, compare all brands with this criteria.
Fourth, look at the MIL SPECs of the radios you've selected. This will tell you much about their durability. (Some of the low cost radios will show up as lacking in this area.) The MIL SPECs are available for every radio on their product literature, and most likely on the internet.
Fifth, look at the size and weight of the unit. A radio might look great on paper, until you find out it is the size of a brick.
Sixth, look at repairability. Once your radio is out of warranty, is it repairable, and at what cost.
Seventh, look at battery, antenna and belt clip replacement costs. In two years you will need to be replacing those rechargeable batteries.
Hopefully, this will get you started. If you have questions, repost here, or talk to a radio dealer or two. IMHO most schools use UHF 4 watt models, or the newer 900 MHz (license-free) digital radios with success.
Sep 04, 2008 | Radio Communications
Motorola frequances
Google search indicates that the Motorola GP300 is a portable
walkie-talkie UHF Transceiver. The exact model gets no hits.
The UHF frequency band ranges from 300MHz to 3GHz,
or 1 meter down to 10 centimeter is wavelength.
This includes some analog cellphone bands.
The actual capability of the transceiver
(i.e. The channels or sub-bands) probably depends on
a finite set of crystals installed within the transceiver,
and licensed to a particular end user/agency.
Your first step is to contact Motorola, and to get the
user manual, complete with full specifications.
Once you know, what the capabilities are, you will have
a better idea of what you want you can or want to listen to.
Also be careful not to transmit in somebody else's band
(any band without a license, pretty well), or
you can find yourself in a pile of legal trouble.
Even eaves-dropping on some other person's
conversation may be illegal in some circumstances.
Hope this gets you started
Martin
Apr 24, 2008 | Computers & Internet
What's the channel frequencies for a common 22 channel motorola 2 way vhf radio?
Not sure what you want.....VHF band ius approximatly 130mhz to 175 mhz..... in that VHF band there is a commercial VHF band aprox. 155 mhz to 175...... the amateur radio vhf band is aprox. 135 to 150mhz.
With amateur radio, any freq in that range can be used...... with commercial radio the FCC cangive a company any freq. in that range also.
If you are looking for FRS/GMRS frequencies they are UHF freqs not VHF.
So I'm not sure exactly what you want......sounds like you might want to program in FRS freqs into an Icom amateur radio. If thats  the case you will need an Icom that will do UHF freqs.
Oct 12, 2007 | Unwired UFR650 (14 Channels) 2-Way Radio
Kitchen Ranges Logo
144 people viewed this question
Top Kitchen Ranges Experts
Oloyede Monsuru
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
