Question about Ovens
GE profile oven model # JSP26 display panel flashed and flutters, cannot read any of it, and it will not turn the oven off/on, none of the controls on the display panel work. Had to turn the oven off with the circuit breaker.
  • Ovens Master
  • 3,361 Answers
Disconnect power to the range.
Remove the rear panel cover.
Disconnect....then re-connect all the wires on the oven control.
Replace the panels.
Plug the range in and try it again.
If this does not work the ERC(clock) must be replaced.
Posted on Apr 01, 2011
None of the control panel button work on my GE profile oven is there anyway to reset it
No you will need to replace the entire control panel to correct this, it is all one piece, buttons and board.
Nov 04, 2016 | GE Ovens
GE profile convection double oven. Model#jkp56w0w1ww 1.The touch panel on the Oven is off and none of the button works. There is not light or code in the display area. 2. The light inside the oven...
Oh, you probably got this fixed already. If it happens again, it helps to take the control panel off, insert paper towel folded up neatly and slotted into the ribbon (it absorbs the moisture which causes the ribbon to short out). Sounds crazy but it's true! I saved our family hundreds of dollars with a piece of paper towel!
Aug 18, 2013 | GE Ovens
Ge profile oven lock button won't go off
  • 1.Press the "Clear/Off" button on the control panel to reset the oven. This will clear the lock setting and unlock the door.
    2.Allow the oven to cool to room temperature to avoid turning the lock on again during this heating cycle.
    3.Reset the oven to the temperature you require to finish cooking by pressing the correct temperature control on the control pad.
    or
  • 1.If your GE Profile microwave won't turn on, unplug it, then plug it back in. A power outage may have occurred due to a power surge. Check your home's fuses and circuit breakers.
    2.Set the clock of your GE Profile microwave. Certain models will not operate until you set the clock. Select the "Clock" key and type in the correct time.
  • 3.Hold down your microwave's "Off" button. You may have accidentally hit the control-lock feature on your GE Profile microwave. Hold down the "Off" button for three seconds to turn the lock off.
  • 4.If the sensors of your GE Profile microwave are not working correctly, remove the food from the machine. If the sensors detect food-surface temperatures over 200 degrees Fahrenheit, it will not work properly until the area cools down.
  • 5.Contact GE Support if you are unable to resolve the issue on your own. Call the GE Support hotline or browse the help library on the GE website. You can also schedule a service visit on GE's website.
  • Nov 22, 2011 | GE Profile JK915 Electric Single Oven
    GE profile wall, single, Get a
    Hello,The "FO " reading you get is as a result of "Shorted Clear/Off key due to the membrane switch,control or connector".And these mean you have to check the Shorted key panel membrane switch; Check Electronic Range Control(ERC)
    Thanks
    Jun 02, 2010 | GE Profile JTP18 Electric Single Oven
    How do I find the part number for replacing control board for GE?
    WB27T10290
    I would not be so sure about that the problem is in the control board. Check switches on the door lock assemblies first.
    Jun 02, 2010 | GE Profile JTP56 Electric Double Oven
    The control panel went dark. Can only read it
    Not sure on the make but it appears that the timer clock display is failing. Replacement cost is typically £80 but without the make i cannot give you a accurate costing. Fitting would be extra.
    Regards
    Aardvark Repairs
    Nov 16, 2009 | GE Profile JTP56 Electric Double Oven
    I have a GE Profile JTP18. F7 is shown on the
    Hi. this F-7 code is referring to a Shorted Clear/Off Key due to membrane switch, control or connector. unfortunately, this is an integrated control assembly and, the entire control board must be replaced in this case.
    Replacing the control(ERC,EOC) will fix this issue.
    Jun 16, 2009 | GE Profile JTP18 Electric Single Oven
    F0 error code on GE Profile PT956 double electric oven
    you can also put a piece of paper between the ribbon cable where it joins up before the connector. It has been reported that the cable will short in this area. Try that before spending more money since most of the F-codes appear to be cable related.
    Dec 01, 2008 | GE Profile PT956 Electric Double Oven
    JTP18WD01WW no broli, no bake panel works
    my wife has arthitis in her hands and the touch screen does not work when she touches it . otherwise it works fine when i use it . is this a body temp problem .
    Nov 04, 2008 | GE Profile JTP18 Electric Single Oven
    Ovens Logo
    111 people viewed this question
    Top Ovens Experts
    ashburton
    Craig Butler
    Craig Butler
    Are you an Oven Expert? Answer questions, earn points and help others
