Question about Philips Televison & Video
I have a TV 60PP9202/17F, the convergence the Red to the Green does not work.
  • Philips Master
  • 8,617 Answers
Install the convergence repair kit. The Phillips DPTV305- DPTV345 convergence repair kit from www.tvrepairworld.com is the correct kit for your model. The kit contains the two ICs and the 12 resistors plus the CD with repair instructions.
Posted on Apr 02, 2011
2000 PANASONIC TV WITH RIGHT SIDE OF PICTURE THE GREEN AND RED COLORS ARE ABOUT A 1/4" OFF FROM EACH OTHER
trysetting the convergence on the tv itself,if that doesnt work you have a bad convergence amp maybe just 1 of them,you have 2 1 for greenand red 1 for green and blue,hope that helps.
Jan 17, 2013 | Panasonic Televison & Video
Blue will not focus causing "shadows". Magic focus will not solve the problem.
This tv have a problems call convergence,it dead.The tv convergence board the 2 STK convergence ICS and some or all it resistors are dead.These parts must be replaced to solved convergence problems.The shop will cost u $300-350 for parts and labors.
Jun 17, 2010 | Hitachi 53FDX20B 53" Rear Projection...
Hi. My Sony Videoscope XBR's Convergence Allignment
I happen to share this same problem. The alignment of the gridlines on the standard convergence panel are completely abnormal, and if I attempt to auto-adjust the TV, it flashes different colors on the sides of the screen , and then turns off the convergence settings.
Feb 01, 2010 | Sony Televison & Video
Convergence is off - Blue and Red are fine Green will not line up
On most units, the Green is constant and the Red and Blue are adjustable. Here are 2 links on how to manually adjust the convergence. There is a menu option using the remote control. Once there, you will find step by step procedure on how to adjust the convergence. Hope this helps answer your question. All the best!
Greg
http://www.fixyourowntv.com/menumitsubishi.php
http://www.ehow.com/how_2034880_perform-convergence--tv.html
May 23, 2009 | Mitsubishi WS-65809 65" Rear Projection...
Zenith IQD61w20/35 convergence problem
Goto www.TvRepairKits.com - they are experts in this model. There are a few key steps that have to be done during the repair - if not - it will not work.
Apr 19, 2009 | Zenith R57W46 57" Rear Projection...
Green autoconvergence
The master convergence needs to be set in the service menu. You can't do this yourself.. you'll need a technician.
Mar 26, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Screen hazzy and issue with blue convergence
bad convergence would cause show to look as if it was supposed to be a 3-d movie, if a bulb was going out then people would look purple blue -green,or some other off color, so likely the green bulb is going out from the color of the people you described.
Feb 06, 2009 | Philips 60PP9202 60" Rear Projection...
Red and Green
check video IC or tv convergence sometimes yoke
Aug 12, 2008 | Mitsubishi WS-65809 65" Rear Projection...
Can't control red convergence on VS-45607
The STKs are three channel ICs they each control horizontal and vertical of one color the third channel controls part of green and the other half of green is controled by the other ICs third channel. Its customary for the Ics to fail and only have one channel bad in the IC. However its recomended to change both because of the bad Ic having green it can actually weaken the other IC and that one will fail shortly.
Aug 03, 2008 | Mitsubishi VS-45607 45" Rear Projection...
Converging green?
jaymz, you can`t move the green, the green tube is always mounted in the middle and is not adjustable from the convergence menu. red & blue should be converged one at a time on top of the green, once you have accomplished this the crosshatch grid will be white and that means your done :)
Nov 30, 2007 | Philips 43PP9202 43" Rear Projection...
Televison & Video Logo
114 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
