Question about Garden
We bought a used nussbaum npl8000 2 post lift and we need to get assembly insrtuctions
How do I install the dimmer switch on the steering column?
the switch is actually at the bottom of the steering collum and is actuated with a rod that runs along side the collum to the signal lever.
Jul 21, 2015 | 1996 Oldsmobile Cutlass Ciera
We have no insrtuctions to assemble bed
Well here is the best place to get them:-www.alldatasheet.com I just love to help Colin.
Mar 10, 2011 | Health & Beauty
Upper rack not getting clean
The problem likely is the cutter/chopper filter.
1. Remove bottom basket. Remove top basket (Pop off 'keepers' at the ends of the slidding shelf supports).
2. Remove bottom washing arm. Unscrew (Gently but firmily) centre post. Lift arm assembly out.
3. Remove overhead conduit. One screw at back and one at top (Philips #2 screwdriver bit). Rotate whole assembly 45 deg to the right (Clockwise) and lift off of centre post It can then be taken apart to clean.
4. Remove centre post (Pull straight up) Remove 4 screws (Star T-20 screwdriver bit). Lift whole plastic assembly out. Pop off the screen (Flat blade screwdriver around the edge) and clean.
5. Remove cap over cutter/chopper. There is a single screw at left front (Under the just removed centre assembly). Remove (Star T-15 screwdriver bit) screw and cap (Needs a bit of wiggling to get it free). Remove cutter and filter ( a stainless steel disc with many holes in it). Tt is on a spring loaded pin. Pull the cutter blade foreward and lift the filter straight up. Clean thoroughly. I then ran a 'quick rinse' cycle with everything out, to clean the inside.
6. Reassemble - Good luck! This worked for me.
Jan 02, 2009 | Kenmore 24 in. 16032 Built-in Dishwasher
How to take apart the diswasher to clean it
This is a 5 step process.
1 Remove bottom basket. Remove top basket (Pop off 'keepers' at the ends of the slidding shelf supports).
2. Remove bottom washing arm. Unscrew (Gently but firmly) the centre post. Lift arm assembly out.
3. Remove overhear conduit. There is one screw at the back and one at the top (Philips #2 bit). Rotate the whole assembly 45 deg right (Clockwise) and lift off of the centre post. It can be taken apart to clean.
4.Remove centre post (Pull straight up). Remove 4 screws (Star T-20 bit). Lift the whole plastic assembly out. Pop off the screen (Flat blade screwdriver around the edge) and clean.
5. Remove cap over cutter/chopper. There is a single screw at the front left (Under center assembly just removed). Remove screw (Star T-15 bit) and cap (Needs some wiggling to free it up). Remove cutter & filter. It is on a spring loaded pin. Pull the cutter blade foreward and then the filter disc up. Clean thoroughly. Run a 'quick rinse' cycle with everything out, to clean the inside.
Reassemble.
Jan 01, 2009 | Kenmore 15129 Built-in Dishwasher
Dishes don't get clean!
The problem is probably that the chopper/cutter filter is pluged. It needs to be cleaned
1. Remove bottom basket. Remove top basket (Pop off 'keepers' at the ends of the slidding shelf supports.
3. Remove overhead conduit. One screw at back and one at the top (Philips #2 bit). Rotate the whole assembly 45 deg to right (Clockwise) and lift off of the centre post. It can then be taken apart and cleaned.
4, Remove centre post (pull straight up). Remove 4 screws (Star T-20 bit). Lift whole assembly out. Pop off the screen (Flat blade screwdriver around the edge) and clean.
5. Remove cap over cutter/chopper. There is a single screw at front left (Under assembly remover in 4. Remove screw (Star T-15 bit) and cap (Needs some wiggling to free it up). Remove cutter & filter. It is on a spring loaded pin. Pull the cutter blade foreward and lift the filter disc straight up. Clean thoroughly. I then ran a 'quick rinse' cycle with everything out.
Reassemble.
Dec 29, 2008 | Kenmore 24 in. 15932 Built-in Dishwasher
Where is the filter on a Kenmore Quiet Guard 2 dishwasher?
I have a Quiet Guard 4. Same problem so will describe my solution.
1. Remove bottom basket. Remove top basket.
2. Remove bottom washing arm. Unscrew (Gently but firmly) the centre post. Lift arm assembly up and out.
3. Remove overhead conduit. One screw at back, one at top (Philips #2 bit). Rotate whole assembly 45 deg right (Clockwise) and lift off of centre post.
4. Remove centre post (Pull straight up). Remove 4 screws (Star T-20 bit). Lift whole assembly out. Pop off screen and clean.
5. Remove cap over cutter/chopper. There is a single screw at front left (under assembly removed in 4). Remove screw (Star T-15 bit) and cap (Needs some wiggling to free it up). Remove cutter and filter. It is on a spring loaded pin. Pull the cutter blade foreward and then the filter disc straight up. Clean thoroughly as it may be the cause of your problems.
Reassimble. Good luck!
Dec 09, 2008 | Dishwashers
Dishwasher Problem...
You are right. The plastic screw needs to be removed. I have a Quiet Guard 4. My procedure is as follows:
1. Remove baskets. Need to pop off the 'keepers' at the ends of the top slidding shelf supports.
3. Remove overhead conduit. One screw at back, one at top.= (Philips #2 bit). Rotate whole assembly 45 deg right (Clockwise) and lift off of centre post.
4. Remove centre post (Pull straight up). Remove 4 screws (Star T-20 bit). Lift the whole plastic assembly out. Pop off the screen and clean,
5. Remove cap over cutter/chopper. There is one screw at the left front (Star T-15 bit). Remove screw and cap (Needs some wiggling to free it up). Remove cutter and filter (this is the water blocking problem). It is on a spring loaded pin. Pull the cutter blade foreward and lift the filter disc straight up. Clean thoroughly. I ran a 'quick rinse' cycle with everything out to chean the inside.
Reassemble.
Hope there is enough of a similarity to be helpful.
Dec 08, 2008 | Dishwashers
My kenmore dishwasher isn't cleaning the dishes very good
Your broblem is probably the cutter/chopper filter. This is located under the bottom cleaning arm assembly.
Remove the baskets.
Remove the bottom washing arm. Unscrew the centre post and lift off the arm
Remove the conduit to the top arm(s). Remove screw at top and at back. Rotate the conduit assembly 45 deg right and lift off.
Remove 4 screws (Star T-20 bit) and lift whole assembly out. Pop off screen and clean.
Remove cap over cutter/chopper. There is one screw at left front under assembly just removed. Remove it and the plastic cap (Needs some wiggling to free it up). Remove the cutter and filter. It is on a spring loaded pin. Pull in foreward and also lift the filter disc up and out. Thoroughly clean the filter.
Reassemble
Dec 01, 2008 | Dishwashers
Replacing a brake light bulb for a 2006 chevrolet equionx
I just replaced the p/s brake light:
1. Pop off the tabs that cover the screws. (flat screwdriver)
2. Unscrew both screws. (philips-head)
3. There is a metal post attached to the light assembly located towards the front of the assembly pointing in towards the center of the car. This post fits into a rubber grommet that is attached to the car. I had to wiggle and rock the assembly to get the post free from the grommet and the assembly off the car, by pulling to the right.
4. Re-assembly requires lining up and inserting the post back into the grommet (use your best Beavis and ******** sound effect now). Put the screws back in and don't forget the covers.
Jun 20, 2008 | 2006 Chevrolet Equinox
Garden Logo
77 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
