Question about HP LaserJet P2015 Printer
File labels do not print on this HP laserjet P2015 - avery label 2181, the printing is left justified and the label is in the middle. We have another HP laserjet P2015 at another station, it works fine. I just installed this printer yesterday.
5 Suggested Answers
SOURCE: Just trying to print 2181 Avery Laser Labels - "Paper Size or type is incorrect"
I have had this same problem trying to print DVD lable sheets.
I spent hours trying to work it out, HP support said it was the software(hmmm)
The answer to the problem is, the printer senses the printed block colour band on the preprinted lable sheet. I am using Fellowes - Neato DVD tempate sheets which have a black, block of colour on the leading edge, I'm not sure about Avery.
I found the quick fix is, turn the sheet around end for end against the manufacturers instructions. The opposite end is plain and goes through OK. You may have to calibrate the software to compensate if the printing starts in a different position this end, my sheets are the same within about 1mm.
You could also cut the block colour off the sheet if the direction was critical, and make allowance for the starting position.
I find the printer is good apart from this problem.
I hope this helps, it worked for me.
Regards, Rob.
Posted on Mar 17, 2008
freetek
  • 5568 Answers
SOURCE: Okidata - label printing alignment
You might try setting up Word for a 'custom' label since it offers that option.
I've done some strange labels by directing Word via that feature.
Posted on Aug 26, 2008
SOURCE: Avery label printing alignment issues. Please Help!
you may need to use some free software that is available for 10.4 and 10.5 users. produced by avery it is the DESIGN PRO available for download at http://www.avery.com/avery/en_us/Templates-&-Software/Software/Avery-DesignPro-for-Mac.htm
also available for PC
a bit awkward to learn, it does the advertised job
Posted on Aug 18, 2009
SOURCE: AVery 9100
Also, what I did was to first back all of the labels out and back into the reel. Turn machine off, then back on. With the peel lever down, as mentioned above, begin to load the labels as shown. The light will blink and it will make a noise as it senses the label. It will begin to draw the label in and you need to make sure you create tension on the labels as they are being pulled in. I accidentally did this by holding pressure against the reel, and sure enough, the thing pulled the first label into place and quit frickin blinking!!! Labels printed fine afterwards!
Posted on Feb 11, 2010
How do I center the label on my printer so it prints in the middle
there should be a setting in the printer setup that gives you options on how you want the printing set up, such as maximum, border, no borders, and centered. Use the preview to be sure of it before printing.
Nov 03, 2014 | Avery Dennison Ave-2181 Filing Mini-sheet...
Why does hp officejet Pro 8600 crashes when printing avery labels?
Avery labels may be blocked on your computer so check your security settings. Other wise you may need to refresh the page, your computer or the printer. If that doesn't help you may need to double check your ink cartridges are full and correctly placed, also that the wires connecting the printer to your computer are all in properly.
Mar 01, 2014 | HP OfficeJet Pro K8600 Printer
Avery labels set
try going to driver printing preferences /paper or paper/quality tab and set your size for custom and to the 4 x 6 specific size for that sheet and the type as labels for tray 1.
Oct 21, 2013 | HP LaserJet 1020 Printer
Set up a mail merge for labels avery L7162, but the printer prints them a different size - Printer is HP M3035. It is something not set up on the printer
You will need to feed these through the manual tray and you should set the paper size and type to match this label. The avery site shows this as an A4 label sheet. If you are in North America the default on this printer is letter size not A4.You should also ensure that you have configured the print driver correctly when you go to print.
May 23, 2011 | HP LaserJet M3035xs MFP All-In-One Printer
Which labels for 6310 HP pinter?windows viista progar? 8160labels do not fit 6310 priinter
Vista wouldn't be your problem as your Operating System is unimportant in choosing labels but the program you use to print your labels is very important.
If you Use Microsoft Word, for example, you will need to choose the template for your labels. That number is on the box of labels.
In Word (for Instance) you can do the following:
<File>, <New>, <Templates> (templates are on Left side).
Choose your Type of Label and the Label number from there.
Otherwise, some label companies offer free programs, specifically for printing their labels.
AVERY labels has a free program for printing their label numbers and the Program: AVERY Wizard For microsoft Word is free.
I hope this helps as you do not say which program you use to print Labels and you also do not say which label numbers and/or label type you wish to print.
Thank You For Choosing FixYa~!
Mar 24, 2011 | HP Officejet 6310 All-In-One InkJet...
How do i transfer a list of name to #02180/02181 avery
Microsoft word has the avery stuff in it. This is from another site
Try this:
In Word versions prior to Word 2007 (Vista):
1. Click the Tools->Letters and Mailings->Envelopes and Labels menu item.
2. Click the Labels tab.
3. Click the Options button.
4. Find that label in the list box. Avery tends to use four-digit product numbers, so I'd take a look at the 2181 type and see if it fits the size and description of your labels.
5. If you find it, select it and click OK.
From there, you can make a full page of the labels by clicking New Document, or, if you want to print the same label a few times, you can print a short batch directly with the dialog box.
In Word 2007:
1. Click the Mailings tab on the Ribbon.
2. Click the Label icon.
3. Continue with Step 3, above.
Hope that helps.
Sep 15, 2009 | Microsoft Windows XP Home Edition
Labels only jam when printing from file
I cannnnoooooottt believe what I am reading! If you are going to use labels on a laserjet, you need to get thermal labels! The other cheap labels are made for inkjets, matric, or daisywheel printers. The laserjets have heat rollers that will melt plastic. It will melt the gum on the non thermal labels and get them everywhere!!
Master Rod
May 08, 2009 | HP Color LaserJet 8550dn Printer
Printer will not print labels or envelopes????
you need word or Avery label software
then you select the type of labels you have in the options and print
Dec 13, 2007 | HP LaserJet 1020 Printer
HP LaserJet P2015 Printer Logo
101 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
