Question about Gateway (5502134) CD-RW/DVD-ROM (Combo) Burner
When i wanted to burn something its telling me to hook up a burner. but my comp has a burner in it. i just burn something the other day. what happened?
  • Gateway Master
  • 27,725 Answers
Make sure that the dvd burner is getting enough power test all leads that are attached to the dvd burner including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or the drivers may have been corrupted or you might have a virus run your antivrus program you might have to physically unplug the leads for this cd/dvd burner then plug them back in this should activate the found new hardware wizard or you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click you will have options to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps
Posted on Apr 01, 2011
My Ge Force will burn audio but not DVD.I have tried with Ashampoo,Record Now and Express Burner.The burning programme tells me there is no disc in drive
Hi Brian.
I think you are a little confused.
Your GeForce FX 5500 is a graphics card
All this does is allow you to see your desktop on a monitor and play some games.
For burning discs you need a cd/dvd burner. This is a cd/dvd drive that you can use to read and write cd's and dvd's
You say that your program is telling you that there is no disc in the drive. (Your CD/DVD burner drive)
You can burn audio discs so this tells me you know that much and you have blank cd's so my two things I need to tell you are these..
1. To make a DVD or Burn a DVD you need a BLANK DVD disc in your burning drive. Maybe you have mistakenly placed a CD in the drive instead?
2. Your Burner drive may not burn DVD's only CD's?
Check on the door to the drive that opens to allow you to place discs into it. It should say something like DVD multi recorder or Compact Disc re-writeable. If it does not say DVD on it anywhere your drive is not capable of burning DVD movies and therefore you will need to purchase another burner.
I hope this helps?
Sep 08, 2010 | Nvidia GeForce FX 5500 Video Card Graphic...
Can i burn a music cd on a supermulti DVD burner
Yes you can. It will burn CD or DVD.
Get some blank CDs. Insert one into the burner.
You should see a window asking what you want to do.
Select what best matches your task at hand. It should call up yer burning software. Tell it what you want on it and click on the Burn button.
Oct 15, 2009 | Computers & Internet
I CANT BURN AN AUDIO CD, IT KEEPS TELLING ME TO CONNECT TO A BURNER? CAN YOU HELP?
If you are burning using software you have to tell it which device to use as a burner first. Usually there is a drop down menu of some sort for it, explore your burning software a little more. Most Drives can burn Cds these days, I'm sure it can.
Dec 10, 2008 | Acer Aspire 4720 Notebook
Burner wont detect blank cds
You need to change the Lance of your burner after that you can burn any disk. you can contact to any hardware repairing shop or vendor to repair it.
Nov 23, 2008 | Memorex (320232340 (32023234) CD-RW Burner
How do I burn dvd's from dvd's
for this ,you will need NERO or some other dvd burning software on your comp.
download the software & burn dvds as per instructions in software.
Apr 19, 2008 | HP dvd740i DVD±RW Dual Layer Burner
Jvc dvd burner cu-vd20 help!
Yeah, it's a piece of garbage, worked one day and the next I get an unfixable I/O error, teaches me for not getting the LaCie, and you can't use it for cds either!
Apr 01, 2008 | JVC Everio Share Station DVD Burner Burner
Window media player
This would be Known As A conflict, ( With I.Player )
Why Don,t you try installing Another CD Burning Program. Neros Not The Only One.
Try Roxio Easy CD/DVD Creator, Or Look On The Internet For Burner Software For Download.
Posted @ 20.57PM ( G.M.T ) :)
Mike @ Compurepair.
Mar 02, 2008 | Samsung (sw-248f) CD-RW Burner
Dvd rom
not necessrilly some dvd rom drives play only dvds an cds but don't burn them. it may burn cds but there is a 90% chance your drive can't burn dvd's
Nov 17, 2007 | Dell (1G055) CD-RW/DVD-ROM (Combo) Burner
Cd burner
You may want to double-check the "error" message. Normally, when you insert a blank CD-R or CD-R/W you'll see a pop-up message that says something like, "you've inserted a blank CD. What program do you want to use to put something on it?" And then it will give a list of programs like Windows Media Player, Nero Burning ROM, Roxio, MyDVD, etc. The last two choices are "Open a writeable folder" and "Do nothing." The next to last, the open folder, option is the CD recording option for Windows. Once you've put copies of that data into the new window click on the "burn these files to disc" link on the left side or located under the File menu at the top of the window.
Now, if it truly is telling you that you have to insert a blank CD, then you may have one of two problems. Either the CD you're putting in is NOT actually blank or the drive is having problems recognizing the media. To test the first scenario, try the disc on another computer. If it's truly blank, then try uninstalling the CD burner from your Device Manager located in the Windows control panel. Double-click on the System icon > Hardware tab > Device Manager > click on the (+) symbol next to DVD/CD-ROM drives and then highlight your Sony CD burner > right-click and in the menu choose Uninstall. Reboot your system and let Windows redetect the drive and reinstall the drivers (You may want to have any install discs handy, just in case Windows asks for them, but not likely).
I hope that helps!
Nov 08, 2007 | Computers & Internet
HL-DT-ST- DVD-RAM GSA-H22N
I Have A : HL-DT-ST- DVD-RAM GSA-H22N DVD Burner That Works Fine With (CD Burning/ Reading) & (Data Burning/ Reading) But I Have A Very WIERD Problem With The DVD : Here I Go, When I Use Any Program To Burn DVD Like Nero, DVD Shrink Etc.. (It Appears That) The Movie Is Burning Well, Because In The Burning Process It Doesn't Says Something Like:Bad Disc, Not Succefully Burned Or Any Sign That The DVD Burner Is Damaged , Also When It Finish Recording You Can See The Data Burned In The Disc By The Lines It Forms BUT !! I Don't Know WHY The Fu$%@@ , When You Test The Movie In Any DVD Player , Comp OR Whatever THE MOVIE DOESN'T WORK.
Aug 01, 2007 | LG GSA-H22N DVD±RW Dual Layer Burner
Gateway (5502134) CD-RW/DVD-ROM (Combo) Burner Logo
95 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
