Question about HP LaserJet 1018 Printer
Paper jam Hello when I print a document, the paper comes out from printer jamed (usually the left side), the paper seems to shift left after the printing is started. thanks a lot Marine
    Problem Solver:
  • 11 Answers
Problem with teflon sheat and pressor roller.Please replace the boath items.
Posted on Oct 11, 2008
Panasonic KX-P7110 printer won't print from the auto feed tray, shows error when printing is attempted.
Please check the entire length of the paper feed path from input to output for a small piece of paper that is stuck causing a "Paper Jam".
You are lucky that you can still print manually as this usually shuts a printer down until the jam is found and removed!
Good Luck!
Rich Lilja
Jan 06, 2014 | Panasonic KX Office Equipment & Supplies
Hello! I have a Magicolor 2300W that has been standing unused for some time and it won't print correctly. The printer feeds paper from the tray, it goes through the printer, comes out at the top - but...
1. Check the paper size your printing on and whether the Same is used by printer or not 2. Try shaking the cartridges as they may have got stuck at their places for long time 3. Try legal or a4 or letter size for paper
Jan 01, 2014 | Minolta magicolor 2300W Laser Printer
The printer is constantly sending a message- 'paper jam'
HP Officejet 7200, 7300, and 7400 Series - 'Paper Jam: Clear jam, and then press Enter' Message Displays on the Control Panel Display
Issue
During printing, the paper becomes stuck in the all-in-one and the error message 'Paper Jam: Clear jam, and then press Enter' displays on the control panel display.
Solution
Use the following instructions to clear a paper jam from the product:
Step one: Check for and remove any loose paper from the In tray
Do not try to remove jammed paper from the In tray. First remove any loose paper from the In tray to avoid worsening the jam.
CAUTION: Always try to remove jammed paper from the back of the printer first to avoid mechanical damage.
Step two: Clear the jam from the back of the printer
Follow these instructions to clear jammed paper from the back of the product. If the product is equipped with a two-sided printing accessory, skip to that section.
Remove the rear access door to clear the paper jam
1. Remove the rear access door by pressing the buttons on the side of the door and pulling it toward you.
Figure 1: Removing the rear access door
Rear access door
2. Gently pull the jammed paper out of the rollers.
WARNING: If the paper tears while removing it from the rollers, check the rollers and wheels for torn pieces of paper that might remain inside the product. If all the pieces of paper are not removed from the product, more paper jams might occur.
3. Replace the rear access door. Gently push the door into the all-in-one until it snaps firmly into place.
Remove the two-sided printing accessory to clear the paper jam
1. Remove the two-sided printing accessory by pressing in the buttons on the sides and then pulling the accessory toward you.
Figure 2: Removing the two-sided printing accessory
2. Gently remove any jammed paper.
WARNING: If the paper tears while removing it from the rollers, check the rollers and wheels for torn pieces of paper that might remain inside the accessory. If all the pieces of paper are not removed from the accessory, more paper jams might occur.
3. Press the button on top of the two-sided printing accessory to open the door.
Figure 3: Opening the two-sided printing accessory door
4. Gently pull the jammed paper out of the rollers.
5. Close the accessory door.
6. Reinstall the two-sided printing accessory.
Step three: Clear the jam from the automatic document feeder (ADF)
1. Remove the document feeder tray from the product by gently pulling it.
2. Lift the cover of the automatic document feeder by pulling it outward.
Figure 4: Lifting the cover of the automatic document feeder
Automatic document feeder (ADF) door
3. Gently pull the jammed paper out of the rollers.
WARNING: In the rare occurrence of a severe paper jam, you might need to remove the face plate from the front of the automatic document feeder and lift the pick assembly to remove torn pieces of paper from deep inside the automatic document feeder.
4. Close the cover of the automatic document feeder, and then reattach the document feeder tray.
Step four: Verify that the print carriage can move freely
Follow these steps to try to move the print carriage.
CAUTION: Do not force the print carriage to move if it is out of plain view or feels stuck. Forcing it may damage the printer.
1. With the product turned on, open the print cartridge access door. The print carriage might try to move into the access area. If so, allow it to move to that position.
2. Without turning off the product, unplug the power cord from the back of the product. Unplug the power cord from the power source. The power cord must be unplugged to allow the parts to be moved by hand and to reset the paper feed mechanism, without the risk of an electrical shock.
3. Looking in through either the print cartridge access door or the output paper tray, make sure the print cartridges are locked into the carriage and have not come loose. Also, make sure that there are no obstructions under or around the carriage to block it from moving.
4. Make sure the print carriage can move freely across the width of the product by gently pushing the carriage to the left and then to the right. Clear any obstructions found.
You may have to reach through the output paper tray to access the print carriage.
5. Close the print cartridge access door and plug the power cord back to the back of the product. Plug the power cord into the power source.
6. Press the On button to turn on the product.
Step five: Reload and test the printer
After you have removed the jammed paper, make sure the product is still functioning properly.
1. Reload the product with plain paper.
2. Peform a self-test by pressing and holding the RESUME button on the control panel until the product begins printing. A test page prints.
Step six: Service the printer
If you have completed all the steps listed above and are still experiencing a problem, service the product.
Dec 30, 2009 | HP DeskJet 3745 Printer
HP C4385 display reads Paper Jam continuously
check the paper jamed or not other wise try to reset your printer
Oct 03, 2009 | HP LaserJet P2015dn Printer
I have a lexmark x2550 printer. I was trying to print a document but the paper became jammed so I removed it. I threw away the jammed paper and tried to print the document again loads of times. Everytime i...
If its not taking the paper, it may be that the paper you are using is not the right type. Some papers are too smooth or shiny to allow the guide wheels and platten ( roller) to grip the paper. This oftemn results in no paper or only one side of the paper being caught and then it jams.
Wipe the platten with alcohol, as welol as thye guide wheels if you can see them. Ink tends to stick on them and the platten and becomes shiny ans so paper will slip. Also try a heavier grade paper to see if that rectifies the problem
Aug 10, 2009 | Office Equipment & Supplies
PAPER JAM
open the front door and remove inkl cartridge then check thr is not any paper jam .thn refix the inkmcartridge.
Mar 12, 2009 | HP Deskjet 450 wbt Printer
MF5750 All-In-One Laser Printer DOES NOT PRING indicate paper jam I check and there is no paper jamed in the printer. It starts as it will pull the paper to copy document and then indicates in the display...
It starts as it will pull the paper to copy document and then indicates in the display that the paper is jamed.
Can anyone explain what the problem my be?
Please assist me.
Jan 19, 2009 | Canon imageCLASS MF5750 All-In-One Laser...
Printing
It almost sounds as if the guide on the left side has been moved. Reload the paper so it is up against the right side of the paper tray and then move the left guide up against the paper.
Judy F.
Aug 28, 2008 | HP DeskJet 6122 InkJet Printer
Laserjet 1100 printing from wrong location
there is a tab I believe on the left front that you can flip up for the paper to exit on top or down so the paper exits down
thanks for rating
Jan 15, 2008 | HP LaserJet 1100 Printer
Paper Jamming
Could be a faulty roller, or jam you have not found yet. Check again with a torch right up insied unit. If no go, try uninstalling and reinstalling printer.
Jun 29, 2007 | Canon PIXMA MP150 All-In-One InkJet...
90 people viewed this question
Vinaya Kumar...
Vinaya Kumar...
Seeker5211
Seeker5211
