Question about Watches
I have a Commodore Clock Model 619. It has a chime built in. On the hour, it is supposed to match the set time. It chimes 9 times at 11, 3 times at 1:00. In other words short two chimes on on each hour. How do I set the clock to get chime amounts and hour setting to match? I am unemployed, so only if information is free.
3 Suggested Answers
gemineye61
  • 831 Answers
SOURCE: I have a Seth Thomas
Thanks for contacting FixYa.
I wish I had an aswer for you but I dont. Here is a link for a repair man that has an 800 # toll free to call for estimate.
http://clock-repair.net/site-map/seth-thomas-clock-repair/
Best regards. Jewel
Posted on Sep 14, 2010
SOURCE: timex westminster anniversary chime clock doesn't chime correct number
Take the batteries out from the base, where the chime mechanism is. Wait till it gets close (20 seconds till) to a specific hour time, like 8:00 or 9:00, replace the batteries for the chime mechanism. And then count the chimes at the hour. If they are correct, you are set. If they are incorrect, turn the time back 15 minutes before the hour and bring it right back and monitor the chimes again. Hopefully this should fix it. Please post the results.
Posted on Nov 10, 2010
NEED DIRECTIONS FOR CHIME
clocks chime the hour
what is the point of having a clock that chimes every 2 hours because you will not know how long it was from the last chime or be able to calculate the time between chimes
Dec 28, 2015 | Watches
Clock Manuals
leave it running when it gets to 12 oclock it wiil reset itself
May 02, 2013 | Watches
I have a cuckoo clock . Time is 11 and the cuckoo chimes 8 times . What do I do? It's a non mechanical clock
If the clock is chiming like this it means that the hour hand is out. GENTLY loosen the hands, place the hour hand on the hour that the clock has chimed then fasten the hands in place. Gently move the minute hand clockwise Only, and check each hour that it strikes right. If the cuckoo has a button at the back use that instead. For more information email me at yvonne.finch@gmail.com
Mar 08, 2013 | Watches
How to sync. an old Black Forest cuckoo clock.
Suppose the cuckoo is calling three and the time is showing eleven, then to synchronize, simply stop the clock till the time is the same as the bird (three) and restart the clock at that time.
If the error persisys, then pull off the hour hand, and replace it at the synchonized time.
Jul 13, 2012 | Watches
How do I set the Chimes on the Ergo Westminster Clock
The controls on the back of the Ergo brand Wall Chime Clock are different than that of the Seiko. I'm not sure who makes the movement - probably Chinese or Asian. Anyway, always take the pendulum off the hook before moving the clock about as it can damage the mechanism. On the back, there is a dial for adjusting the time setting of the clock hands, which is awkward to use, but does work, easiest to leave it alone and use the minute hand, NEVER the hour hand. There is a dial for volume. There is a switch for type of chime - Westminster or Wittington. There is the night-time shut off or volume reduction. Some models have a switch for chiming every quarter hour. My advice is make sure you have fresh batteries, and set the switches on the back for the settings you want. Hang the clock, grasp the pendulum arm and re-hang the pendulum, making sure it's hooked in properly. Now, whatever the hands say the time is, ignore it for now, and gently move the minute hand backwards, slowly, to about 5 minutes before the top of the hour, then forwards to a couple of minutes past the top of the hour. This will cause the chimes to start. Let the melody play, then listen for how many "clangs" you get. That will tell you what the clock thinks the time is. For example, if it "dongs" 5 times, and you've set it to run silent at night, the clock thinks it's 5 p.m. If it's actually only 3:15 p.m., then gently run the minute hand backwards til the hands indicate about 10 minutes behind the correct time (it'll take you several minutes to complete the process) then gently move the minute hand back to about 5 minutes before the top of the hour, then forward to a few minutes past, and the chime will start to play the melody. If you let it, it will play out the full melody, then it will "clang" one more time than your previous test. Each time you move the minute hand back to 5 minutes before the hour, it advances the chimes by one hour. Here's a tip - you don't have to let the melody and "clangs" play fully, each time, once you know how it works. If you have it set to run silent at night (pre-programmed to silence after 10 p.m. to 6 p.m.), keep moving the minute hand back to 5 minutes before the hour, keeping track of how many times you've done it until you reach 10 p.m., or not, until you get to the point where you move the minute hand back and there's silence. At that point, the auto-silence mechanism is active, and the clock thinks it 11 p.m. So, from that point, keep repeating the process of gently moving the minute hand back and forth, from about 5 minutes to the hour, to a few minutes past, keeping track of how many times you've done it. After 8 sequences, you hear it start to chime again, at 6 a.m. So, at that point, go through the back-up and advancing of the minute hand sequence 9 more times, and on the 9th time, let the melody play, and let in "clang" to determine that you're indeed at 3 p.m., which you should be. Then simply gently advance the minute hand to the correct time, 3:10, 3:12, whatever, and you're done. You'll know for certain soon enough.
Apr 02, 2012 | Watches
How to syncronize time with clock chimes? Howard Miller banjo clock.
The hands on your clock are probably friction fit, meaning that they can be adjusted, possibly even without tools. The hour hand is usually a firm slip fit over a tube, meaning that it can be slid forward and backward an hour or more as long as you hold the minute hand steady to keep the hour shaft from turning.
The minute hand may be trickier to adjust. Sometimes, it, too, is a simple friction fit, and you can pop off the hand (remove the second hand and pull the minute hand straight up off its shaft) before setting it where it should go. Other times, however, the minute hand is on a keyed shaft and has to go on in one of two directions. It's still possible that someone could have assembled your clock incorrectly, however, making the minute hand 30 minutes out of sync with your chimes.
If neither of these ideas helps you, please describe better exactly how the time isn't matching up with the chimes. That will help us better understand the underlying issue.
May 09, 2011 | Watches
I have a Seth Thomas Grandfather clock with three different chimes and chimes at every 15 minutes. The problem is it is chiming 2 hours shorter than the actual time. Example say it is 11:00, it is...
Best regards. Jewel
Sep 13, 2010 | Watches
Have a Galleria Grandfather clock thats chimes are off. How do I get them correct? Bought it at an auction and did not get any information with it. It chimed correctly in the beginning.
I suspect that the mechanism needs cleaning.
Take a look inside and if there is the slightest sign of dirt (particularly on the striking mechanism) then it should behave properly after cleaning.
May 01, 2010 | Watches
Quartz president wall clock, I need to set the chime
I have a pendulum wall clock from the president collection. If yours is the same or similar, the following may help:
*Look at the back for a slide switch labled "start" at the top and "set" at the bottom and move it to "set"
*Look for for small push buttons. They represent the hours and minutes. Push each in turn, the number of pushes to represent the time, ie, for 09:45, ignore the first(0), push the second 9 times(9)-push the third 4 times(4)- push the 4th 5 times(5). When done, push the slide switch back to "start".
If yours is the same as mine - a wall hung pendulum clock with Westminster chimes, made around 1988. I would be happy to scan and send a copy of the instructions.
John
Apr 21, 2010 | Watches
Timex westminster anniversary chime clock doesn't chime correct number
Oct 04, 2008 | Watches
Watches Logo
371 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
