Question about Smeg A1A.1 Gas Kitchen Range
I have a Smeg Range cooker A1 (electric oven, 6 ring gas hob). I have the following problem with just one of the rings - it sparks and the gas lights normally, but when I eventually let go of the knob the gas goes out. It doesn't matter how slowly I release the knob or even how long I have the knob pressed in before starting to release - the gas always goes out the moment the knob is released completely. please can you tell me what is wrong with it and how easy it is to get fixed. Thank you
  • 1,885 Answers
It could sometimes be a thermocouple that is not properly mounted against the flame or is just defective, these thermocouples are mounted for safety because it would not be good if gas flows out of gas for a long time without flame in professional gas equipment, the gas flow is often Many times higher, by the way a nice device and good brand.
I think the damage is very common here. By hand, you might also be able to take it yourself if there is technical knowledge and with the proper attention on gas sealing. look a few examples of your problem from of the link about this.
How to change furnace thermocouple
Posted on May 25, 2017
5 Suggested Answers
bigg t
  • 640 Answers
SOURCE: Low Gas Pressure on Smeg Range cooker
there should be a regulator on back of the stove where the gas line connects.you will see a plug that unscrews,remove this plug and run the unit.if this solves your problem clean the plug really good and put back on.
Posted on Dec 26, 2007
SOURCE: I have a Smeg A1-1 Cooker. The main oven door does
you have to replace the door hinge's an easy fix but you have to strip the doors apart so a good time to clean.
Posted on Oct 03, 2009
SOURCE: how do i change the volume on the oven timer? i
whilst alarm is ringing press the minus (-) button. there are 3 volumes to choose.
Posted on Feb 11, 2011
  • 103 Answers
SOURCE: I have a Smeg oven with gas hob. One of the gas rings doesn't work. When I turn the knob it sparks and the flame ignites. But no matter how long I hold it down, when I release the knob the
there is a brake in the wire the censer
Posted on Feb 03, 2015
How do i change the volume on the oven timer? i
Jun 06, 2010 | Smeg Kitchen Ranges
Electric ignition to hob seems to be jammed
Here is a tip that I wrote that will help figure out why the burner spark keeps on clicking...
Gas Range Repair Burners Keep on Clicking
http://www.fixya.com/support/r4033033-gas_range_repair_burners_keep_clicking
heatman101
May 31, 2010 | Cooktops
Smeg gas hob ignition
There is a problem with the board. It has malfunctioned onto an ignition mode. By switching it off, it shows the capacitor is holding chage untill flat.(Hence the continual sparking) Replace it.
Sep 20, 2009 | Cooktops
We purchased a Frigidaire cooker, electric oven, propane gas hob. It seemed odd that the hob rings take ages to boil a pan of water, cooking with oil is extremely difficult as it takes way too long to get...
Is this a mistake? It's impossible that nozzles didn't helped...? Just impossible.
Or was this problem posted before our chat session..?
Either ways Do Not hessitate to Contact us on fixya
Good luck with your cooker, and HAVE A NICE DINER
Jun 24, 2009 | Microwave Ovens
I have a Smeg A1 Oven which has lost it's power
The fuse is located behind the rear panel of the cooker. Depending what model this is, it may be an electronic card causing the problem?
Apr 02, 2009 | Smeg A1A.1 Gas Kitchen Range
Smeg A1 cooker built in. Wish to remove top to access thermocouple. Cannot see the fixings for the top. Any pointers please?
my smeg oven has always never worked properly, the temperature is faulty etc i now want to remove this oven and have bought a new electrical oven but cannot seem to get the smeg oven out. How do i remove this smeg oven?
Mar 20, 2009 | Smeg A1A.1 Gas Kitchen Range
Zanussi Oven Fan ''Ringing''
Your fan blade is probably touching the metal shroud around it or the blade is loose. You can check this by gaining access to the fan and visually looking at it. Please do not do this with the unit plugged in, electricity kills. I hope this helps.
Nov 23, 2008 | Zanussi ZCM900X Dual Fuel (Electric and...
COOKER HOSE
It is illegal to fit a cooker to a gas connection unless you are a registered Gas Safe Engineer . You can find one in your area if you visit www.GasSafeRegister.co.uk
or ring freephone 0800 408 5500
Jun 09, 2008 | Smeg SUK91MFX5 Dual Fuel (Electric and...
Creda cooker not working properly
my creda cookers hob and top oven is working,but my fan oven is not heating up,the fan works though.
Jan 23, 2008 | Creda C362E Electric Kitchen Range
Smeg SE64 Gas cook top
problem with hob is probably water ingress in area of ignition unit - will probably cure itself oven is a completely separate unit from hob. problem with it is that you have to re-set the clock - you have it on automatic. after power outage, oven clock always has to be reset
Apr 04, 2007 | Smeg 23 in. SE64 Gas Cooktop
Smeg A1A.1 Gas Kitchen Range Logo
852 people viewed this question
Top Smeg Kitchen Ranges Experts
ashburton
Joseph Mueller
Joseph Mueller
Your Consultant
Are you a Smeg Kitchen Range Expert? Answer questions, earn points and help others
