Question about LaCie 8x DVD+/-RW USB 2.0 External Dual Layer Drive with LightScribe (300820U) DVD Drive
I connected the USB cable into the Lacie hard drive. It does not show up on the desktop
  • 734 Answers
Hi There,
It's not supposed to show up on the Desktop. Go to Start>Computer and you should see the drive there.
Regards,
Selk
Posted on Apr 01, 2011
Can you get a usb to firewire cable for a lacie hard drive
well, there is this device by LaCie that allows you to connect usb and firewire stuff into the same hub
http://cableorganizer.com/lacie-usb-hub/
Apr 11, 2011 | LaCie d2 (300769) 200 GB Hard Drive
My Lacie Rugged 500 US/400/800 drive ejects automaticaly. It show connected in system profiler, but not in disk utility. when i disconnect and reconnect, it shows on desktop only after doing so 3-4 times...
It may be the cable that you are using to connect it to your computer. Are you using a USB or Firewire cable to connect? To me it seems like the cable may be damaged, and that it why it disconnects after a few seconds, like it is not getting enough power to run the drive.
If you have one to hand, try another cable. or if you can try a different type of cable (if you are using USB at the moment, try a firewire)
Also, (I have the same drive) if you are using it with an USB cable you will need the power usb adapter plugged in as well as this drive does not get enough power from a single USB cable.
Hope this helps.
Feb 08, 2011 | LaCie Rugged All-Terrain (301017) Hard...
My Lacie 1T hard drive tells me it has insufficien memory when I try to add a file it is brand new how do I reformat it?
Have you followed the steps given below accurately ? If not, do it once again please
1. Connect the power supply.
2. Connect the USB, FireWire or eSATA cable to your computer and to the drive.
3. Turn on the drive by moving the power switch to On or Auto (drive powers on/hibernates automatically). The drive will mount in My Computer (Windows) or on your desktop (Mac).
4. Before using the drive, LaCie Setup Assistant software must be launched to format your drive. It will
• Optimize your drive according toyour needs
• Copy the manual and utilities on
your drive
I Hope this is helpful
Nov 03, 2010 | LaCie Hard Disk 1TB Desktop with Hi-Speed...
LaCie Big Disk 500GB not showing up
1. the usb connector in the PC may have a broken board contact needs soldering or replacement.
2. there may be a broken USB cord to the external usb drive
3. the electronic controller in the USB case may not be working.
4. A new case may be needed with a new controller.
Jul 08, 2010 | LaCie Big Disk Extreme 500 GB Hard Drive
Lacie icon not showing up on my desktop
Try disconnecting the usb cable from the drive and take the drive to a quiet place.
Power up the drive and put your ear next to it. Listen for the internal disk to speed up and then click (which means it's ready). At this point you should have a solid blue LED on the enclosure.
If not, either the disk is bad, the enclosure's controller is bad, or the external power brick is bad (put your ear next to the power brick and if you hear a faint clicking sound, the power brick is bad and you can order a new one from LaCie for about $16.00.
You rate will be much appreciated!
May 07, 2010 | LaCie Hard Disk 1TB Desktop with Hi-Speed...
Will not show up in finder or on desktop,
Is it running? Of late Lacie have had loads of (well documented) problems with power supplies failing and also of some cases failing.
best thing is to connect it to another computer (Mac or PC) and see if it shows up there. That will either eliminate or confirm the drive (Use a known working cable though).
Oct 20, 2009 | LaCie External USB 2.0 500GB 7200 RPM 500...
My Lacie HD will not show up on my MacBookPro when plugged
Brand new? It needs to be formatted / erased with the disk utility to work with your mac.
Jul 07, 2009 | LaCie (300728U) 250 GB Hard Drive
LaCie icon won't show up on my mac desktop
1. A. Yes.
2. A No.
3. A. Replace the LaCie
Apr 24, 2009 | LaCie Computers & Internet
Is my LaCie External USB 2.0 500GB fried/dead???
You're not missing any step at all, because with SATA hard drive if its really working your computer should
automatically detect it and since this hard drive suddenly stop working there's a possibility that its already
fried but if you want you can try this hard drive again to a different computer and if still not detected by
second computer its already dead.........
Nov 07, 2008 | LaCie External USB 2.0 500GB 7200 RPM 500...
LaCie 500 GB hard Drive - does not register on my desktop
if it is a USB (or you have low disc space), it does take longer to show up on desktop and patience is required... on my iBook it takes over a minute for my Brick to show up... Whether it is USB or firewire, do try another cord (I had similar problem with my lacie firewire external... I used a different firewire cord and all was fine. If you have tried these already, I hope you find the answer... good luck
Jun 07, 2007 | LaCie (300951U) 500 GB Hard Drive
LaCie 8x DVD+/-RW USB 2.0 External Dual Layer Drive with LightScribe (300820U) DVD Drive Logo
101 people viewed this question
Top LaCie Computers & Internet Experts
Raj Patel
Tony
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
