Question about Conair HC500 Hair Trimmer
Took apart my Conair HC500 to clean the blades and now can't reassemble?
    Genius:
  • 1,739 Answers
The Instruction Manual for your product can be found here:
http://www.conaircanada.ca/pdf/en/ibs/en_HC500C.pdf
Posted on Apr 25, 2011
Replacement blades for conair hair clippers hc114wv
I have a Conair HC114WVR and I took the blades off to clean the hair out. It's not that old, but when I put the blades back on they vibrate to a point of grinding. I can't figure out what I need to do to get them back on straight.
Jan 25, 2014 | Health & Beauty
I took the blades off my table fan to clean them and once i put the fan back together and turned the fan back own the blade spins and everything but no air is blowing out
I think that you may have put the blade on backwards. try taking the fan apart and reversing the blade around and reassembling the fan.
Dec 10, 2012 | Hampton Bay 24002 Ceiling Fan
I used the clippers to cut my dog... once finished I took it apart to clean out excess lubed parts and reassembled...I have done this many times before with no problems... I begin cutting and the blades...
Check your blade latch is working properly. If you took your clipper apart and your blades are not cutting it is one of 2 things. Your blade drive is not assembled properly or your blade latch is not holding the blade on the clipper. If you took your blade apart, check the blade alignment. The cutter blade needs to be slightly behind the comb blade.
Mar 11, 2011 | Andis AGC2 Hair Trimmer
I can't find the manual of my Conair GMT 170X. I took the blades apart to clean and lube and now I don't know how to put the spring assembly back together with the blade. Please help
their is 2 long wires with a l shaped hook on the the smalles blade that goes on the bottom the points of those wires go in the holes in the bottom of it which is a white thing with 2 groves in it make sure the blade is facing away from where the screws go the take the plastic pad and put it in the 2 holes of the top blad the set it on their facing the same direction the push down till its flush the put the 2 screws back in
Dec 17, 2010 | Conair GMT 170 CS Beard Trimmer
Andis Ultra Edge Pet Clipper Assembly Help
I took my andis ceramic edge blade apart to clean. Now my clipper will no longer cut my dog's hair
Aug 13, 2009 | Andis Health & Beauty
Conair GMT200 Assembly
Hey dude i had the same problem n_n. Attach the screws in place and try to screw one by one gently. Soon this pressure will keep the spring tighten (instead your finger's pressure) then it will be easier to reassemble the component. I know you'll fix it n_n.
May 20, 2009 | Conair GMT200TD
Cleaning Conair Simple Cut haircutter
Go to a Sally Beauty supply and purchase a can of the blade wash. It is relativly inexpensive. You dip your blades into ths special wash and it cleans the blades and keep them sharp and is safe. DO NOT take the heads apart, Let the pros do that but blade cleaner you immerse them in and trust me it is what we pros use.
Jan 20, 2009 | Conair HC91CS 10 Pc. Haircut Kit Hair...
Took unit apart to clean and need reassembly diagram please
the thick racket sit on top of the lil gold bracket
Dec 02, 2008 | Wahl 8550
Health & Beauty Logo
1,219 people viewed this question
Top Conair Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Julia Tatspaugh
Level 1 Expert
Andrew Taylor
Andrew Taylor
Are you a Conair Health and Beauty Expert? Answer questions, earn points and help others
