Question about Sony SRS-D21 Computer Speakers
The speakers are turned on, you can ever so slighlty just hear the bass on them, thats the only sound coming out of them ?
  • Sony Master
  • 27,725 Answers
The speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
or you might have to clean the dust from your computer dust causes static which causes your computer to overheat and all sorts of problems
be sure to wear an anti static earth strap before touching anything inside your computer
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or click start control panel administrive tools computer management device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable)
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the CPU central processing unit and your sound card dust causes static to build up in a computer causing it to overheat any many other problems
hope this helps
Posted on Apr 01, 2011
Why can I only hear bass thru speakers when playing in my car
there is a adjustment you can make . most times on the volume knob by pushing it in .you can adjust the sound .
Nov 12, 2014 | Computers & Internet
My stock stereo speakers go in and out. most of the time lately the speakers are real low and your have to turn up the volume almost to max to hear them decently. and then the bass and mid isn't working....
My speakers in my 2003 Silverado started to fail at about 5 years old. I just replaced them with all new speakers. They would come and go erratically and sounded horrible.
Sep 11, 2013 | Logitech X-530 Computer Speakers
I have a system installed and i have mtx speakers plus mtx subwoofers i want to know how could i take the bass of the speakers because it sounds horrible when loud
if you turn the bass setting in your radio down it will take the bass out, but may take some of the bass out of the subs as well, if this occurs and you still are not satified, you either have to get a car receiver with a non fading subwoofer preout, or you could get bass blockers for all the speakers you dont want the bass in
Apr 05, 2012 | MTX Car Audio & Video
My speakers only the bass when i hook them up i hear the bass but not the sound please help
It sounds like you have subwoofer system that requires satellite speakers for the high frequencies. If you have these satellite speakers, but are getting no sound, either you have connected them incorrectly, or there is a problem with the amplifier that drives the satellites.
Oct 06, 2010 | Altec Lansing 121i Computer Speakers
It comes on but no base sound and wont turn up
You have to fill in the details about what you're feeding it (the source and how IT's set up). It won't just >>create<< bass.
From the manual:
If you used the high-level (speaker) inputs and there
is no sound from any of the speakers:
• Check that receiver/amplifier is on and a source is playing.
• Check that powered subwoofer is plugged into an active electrical outlet and is switched on.
• Check all wires and connections between
receiver/amplifier and speakers. Make sure all wires
are connected. Make sure none of the speaker wires are
frayed, cut or punctured.
• Review proper operation of your receiver/amplifier.
If there is low (or no) bass output:
• Make sure the connections to the left and right “Speaker
Inputs” have the correct polarity (+ and –).
• Make sure that the subwoofer is plugged into an active electrical outlet and switched on.
• Adjust the crossover point.
• Flip the Phase Control switch to the opposite position.
• If you are using a Dolby Digital/DTS receiver or processor, make sure that the subwoofer adjustments on the receiver/processor are set up correctly.
• Slowly turn the Level Control clockwise until you begin to hear the desired amount of bass.
If you used the line-level inputs and there is no sound
from the subwoofer:
• Check all wires and connections between receiver/amplifier and subwoofer. Make sure all wires are connected. Make sure none
of the wires are frayed, cut or punctured.
• Make sure that you have configured your receiver/processor so that the subwoofer/LFE output is on.
Apr 07, 2010 | JBL PB12 Subwoofer
Bass speaker moving in out more then normal
If you can't hear the difference maybe the bass frequency which is moving the speakers is below your hearing range.
I think you may have a "loudness" button on that amp -- if you do, turn off the loudness -- this is a bass booster.
But, in general, bass speakers are designed to move in & out a lot. They have to move a lot of air to produce the bass sound.
May 09, 2009 | B&W ASW1000 Speaker
What duz level adjustment do
The level control controls the input level coming from your head unit (receiver) to the amp.
Your Sony users manual is a little vague on how to best adjust the level and other controls.
Here is one method that some installers use and works well with most amps.
Most 10" subs sound best between about 80-100hz and below, so start out by setting the LPF at about 80hz. The HPF will not be used. Next turn the bass boost and gain all the way down. Turn on the radio and set all tone controls, bass, midrange, treble to flat, usually "0" on most head units. Turn the volume up to approximately 3/4 volume level or just until you begin to hear distortion. Now, back the volume down until the distortion is gone. Next turn up the gain control on the amp until you hear the subs start to distort then back the gain down until the distortion disappears. Next turn the bass boost up again until the subs begin to distort, then either back the bass boost down or back the gain down until the distortion is gone. You may need to play around with the bass boost and gain controls to get exactly the sound you prefer.
Hope this helps.
Mar 28, 2009 | Sony Xplod 1100 Watt Max 10" Subwoofer,...
Flutterin sound in tv
try turning the bass down and see if this helps the fluttering. If it does help a little most likely it is a blown speaker. Can replace at radioshack for under 20 dollars. It is hard for me to tell since i am not there to diagnose but also can you do a balace to go completely to the right with bass up and see how it sounds. now with bass up turn the balance to go to left speakers. if you hear fluttering from one side that means a speaker or speakers from the side that is fluttering need to be replaced. i hope this helps and good luck fixing this.
Feb 21, 2009 | RCA Televison & Video
Hiss from the tweeter nothing from the sub
Trash. Don't run your bass through speakers not designed for it. Likewise (from personal experience) don't allow microphone feedback to get into consumer speakers. Bye-bye tweeters in either case.
Nov 05, 2008 | JBL EON 15-G2 Powered DJ Speaker With EQ...
No sound from my logitech z4 subwoofer
Is there sound coming from the 2 speakers?
Subwoofers are designed to only play bass, you shouldnt hear much acoustic sound coming from it at all.
The best way to test that is to play a song with a good amount of low bass, see if you hear it coming from the woofer, or can you feel the woofer vibrate?
If there is a hole in the side of the woofer box, when you are playing the song is there any air coming out of that hole to the bass line beat?
I dont know how you have your wiring set up, but if it still isnt working please check to make sure that you have the wiring plugged in properly.
If there is anything else I can do to help please let me know. I hope this fixes your problem.
May 13, 2008 | Computers & Internet
Sony SRS-D21 Computer Speakers Logo
50 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
