Question about Bissell Vacuums
Not sure it's seated properly. No water is coming onto floor or recovery tank. -Bissell Prpheat 2X 9200
  • 29 Answers
SOURCE: Cleaner Solution Not Dispensing On Bissell 9200 Pro Heat Cleaner
I haven't had this particular issue (yet... knock on wood!) with my Bissell, but remember that the shampoo will not dispense with no water in the tank (the most common cause of this issue because sometimes you think it has water but it doesn't) or water not flowing through the machine due to clogged sprayers-- another issue-- but since you're getting water on the floor that is not your issue-- or with the handle locked in position. If none of that fixes it, try removing the shampoo container, stand over a sink, and push your finger up inside the grommet where the shampoo container mates with the Bissell. Shampoo should dribble out. If it doesn't, unscrew the grommet (holding the container upside down of course so the shampoo doesn't gush out) and use your finger and running water to try and the grommet cleaned out.
If this isn't helping, it may be that your soap pump or soap dispensing trigger switch are defective.
Posted on May 29, 2009
57 varieties
  • 1653 Answers
SOURCE: Unit is seated properly but water/fluid will not
You need to check that the motor drive belt is OK and turning freely to drive the water pump - under the flap on the right side at the front as you look at the front of the Bissell. If this is OK have you filled the cleaning bottle with fluid etc? If so you may have an airlock in the pipe from the bottle to the motor. You can also have a blockage from the pump to the dispenser nozzles and can test this by taking off the top cover and taking the plastic tubes off them to see if water comes out of the tube. You can also do the same for the tube from the tank to the pump to see if water is getting to the pump OK. Also make sure that the mix valve setting (on the left side - looking from the front) is not turned to the off position. This could also be blocked and need cleaning or replacing.
Posted on Oct 03, 2009
SOURCE: Repair manual for Bissell 2X ProHeat 9200 Carpet cleaner
http://ec1.images-amazon.com/media/i3d/01/A/man-migrate/MANUAL000074560.pdf
Bissell Manual
Posted on Feb 24, 2010
SOURCE: Bissell Steam Cleaner
my cleaner is not spraying or sucking up the water?
Posted on May 13, 2010
heatman101
  • 43501 Answers
SOURCE: bissell proheat 2x carpet cleaner 9200 How do i
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
teyet
Posted on Sep 30, 2010
My bissell proheat 2x dual dirtlifter is not succioning very well then the carpet smells
We have several parts here for the Proheat 2X,
Proheat 2X Shampooer Shampooer Parts
It may be a clog in your tank, preventing the water being sucked back up. Check your tank and tubes for clogs or damage. Make sure the brush is still rotating and the belt is not broken too.
800-775-6586
GoodVac com
Feb 26, 2015 | Bissell 2X Proheat 9200 rug cleaner
Bissell 9200-T ProHeat 2X will not spray I have gone through the priming process it will work for a few seconds and quit. I have had it open and checked a few tubes but not sure what to do next. This...
ARE THE TANKS SEATED PROPERLY AND THE AUTO-LOAD GASKETS
IN PLACE?
Check the bottom of the Water Tank and the Formula Bottle to make
sure each has a red (or black) auto-load gasket attached and facing outwards
and that the ventilation tube is not submerged as it allows air in so the solution
can flow.
May 28, 2011 | Bissell 9200 Upright Vacuum
I HAVE A BISSELL PROHEAT 2X HEALTY HOME, IT WORKED JUST FINE THE LAST TIME I PUT IT UP. YESTERDAY, I NOTICED THE FLOW GAUGE WAS NOT SPINNING, SO I CHECKED AND SURE ENOUGH NO WATER WAS COME OUT. I CHECKED...
Have you made sure that the tanks are seated properly and the red
(or black) auto-load gaskets are in place.
sure each has a red auto-load gasket attached and facing outwards.
You should be able to press the x-valve in the center of the auto-load
gasket so water or cleaning solution comes out.
May 17, 2011 | Bissell 9500 ProHeat 2X CleanShot Upright...
The water in my bissel pro 2X heat will not spray water
front tank is warped and not seating properly or solenoid bad. solenoid most probable.
May 05, 2010 | Bissell 9500 ProHeat 2X CleanShot Upright...
Bissell 9200 ProHeat -the water tank won't fit on the base
sume time the rubber gromit comes of the base of the water tank and gets stuck in the base there the water tank fitts to the base if this is why take out of the and refit it to water tank and of you go
Jul 23, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
Bissell 2X Proheat 9200 - uses lots of cleaner.
May be that the cap and valves on the bottom of the tank is not shutting like it should and letting too much to come out. You may have to replace them.
Mar 10, 2008 | Vacuums
Vacuums Logo
12 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
