Question about Apex Digital LD4088 LCD TV
Waiting on a remote(since we purchased TV in DECEMBER!) Missing from box!! Stuck on home mode or store mode - soooo frustrating with no remote!!
    Novelist:
  • 159 Answers
HI, it is possible to operate most of any flat screen t.v.'s function using buttons on t.v. These are marked as follows: + and - are for volume and when in the menu for either moving up/down or to the left and right, the < and > are to change the Channels ( also used in menu mode to scroll either up and down or to the left and right ), then you should have a button marked INPUT, maybe A/V this switches between your sources ( the t.v.'s tuner,cable,sat,p.c. input,dvd,aux,hdmi,and so forth,then you have a power button and last but not least the MENU button to adjust it. also if you have a remote for a cable/satellite box with a manual it may be able to operate an APEX( pretty common actually ) if no manual for said remote-cable/satellites customer service have been know to help quite readily. I hope this has been of some help, good luck, Prodzilla
Posted on Apr 01, 2011
  • ogradysgetaw Apr 05, 2011
    Thanks for the reply. The button on the side of the TV cannot get it off the "mode" it is on. I have tried the remote for the satalite and the dvd player and both don't work - we have also tried a universal remote but it cannot work until it is off this retail/home mode? I have tried customer service at APEX and they are useless I am still waiting for a remote because one was not in the box when we purchased back in December?!?!? We couldn't take back to store because we are in Canada and we purchased in the US.
    I have asked them for their help to get it off this mode without the remote and they said that it can't be done?!?!?
    Any other thoughts???
    Thanks so much!!
  • prodzilla Apr 07, 2011
    Hi, Provided you can turn the T.V. off, then you can try a RESET-even if there's no button or little hole to press in-it may be possible to try a variation of key inputs(buttons-usually two at a time)I'd suggest when tv is off ( again probably will work best if T.V. was switched off) press and conintinue to hold the Power button. , then move on to repeating the process and adding a second button( we assume it will take more than one try, the t.v. manufacters do not make it impossible-only difficult for operation without their remote ( Encourages new remote purchases) too) while tv is off press an hold in lets say the Menu button then press powere button until t.v. turns on,. also their may be a small switch somewhere actually ( in fine print?)marked display mode: demo/normal. Just get creative: these T.V. are pretty crash proof unless they're broke. Nearly anything you do can be " UNDONE " by unpugging for a long enough period of time. :) So that about wraps it up. It may take a few try's but being 'Stuck " in a mode sounds like just a progaramming matter with some trial and error involved. I hope was more helpful, Podzilla
My Element 40" Tv is stuck in stand by how do I
hi have you changed the batteries in the remote, if the remote is ok there's a fault with the tv, could be a swollen capacitors shorted diode or poor solder joint,or a bad mainboard , thanks
shaun
Mar 08, 2017 | Element ELCHW402 40 in. LCD HDTV
Tv is stuck on Video 1 and the remote is missing.Won't respond to the cable remote except on and off. HELP
Try pressing tv first on your cable remote then the video/source/input button on the cable remote. If there is no button on the television itself to switch video inputs a temporary fix for now is to connect the cable box to the video 1 female parts on your television. Buy the cables to do that if you don't have a spare set lying around. You can purchase a remote for your television with the model number from http://www.replacementremotes.com or even a Sanyo remote from a thrift store should be able to allow you to switch inputs.
Aug 21, 2011 | Sanyo Televison & Video
The store demo mode is stuck on my insignia tv. the user guide says go to menu and then setup and select plug & play. however the plug and play option is grey and it wont let me select it.
Are you using an HDMI cable? Go to input and select TV. Then you should be able to access the Plug & Play option and be able to turn off the Demo Mode.
Jan 03, 2011 | Insignia 42" Flat-Panel Plasma HDTV
How to remove "in retail store mode with settings" message
Question What should I do if my TV is stuck in Retail mode? Answer Your TV may have been set to Retail Store mode, which is mainly used on the shop floor.
For home use, we recommend that you set the TV to HOME mode, which will allow you to change the settings.
To change to HOME mode follow the steps below.
  1. Press the 'MENU' button on the remote control to access the main menu.
  2. Move the cursor down to select INSTALLATION and move the cursor right.
  3. Move the cursor down to select PREFERENCES and move the cursor right.
  4. Select LOCATION and move the cursor right.
  5. Move the cursor up/down to select HOME and press the 'OK' button for confirmation.
  6. Press the 'MENU' button to exit the menu.
Sep 29, 2009 | Philips 42PFP5332D 42 in. Plasma...
Box was working, tv now back to analog
Sounds like the converter didn't make it. The symptoms you describe sound like the converter was working and then died. You may want to bring it back to store were you got it.
Jun 18, 2009 | Insignia Digital-to-Analog Converter for...
Control lost
the sad truth is.....you cant. all is not lost though, you can purchase a universal remote for $5-$7 at your local walmart. Anywhere you can purchase a tv you can find unirversal remotes.
Apr 19, 2009 | Apex Digital HT-150 System
SHARP LC-32SB24U. AV MODE KEEPS GOING BACK TO DYNAMIC FIXED .
I have the same tv and i just fixed it! mine was a display model at wal mart so it was set to reset to Dynamix (fixed) after 30 minutes of no remote activity
THE FIX: switch to TV MODE and select the EZ SETUP from the option menu
when you get to the TV LOCATION option select HOME
The STORE option resets the TV after 30 mins of remote control inactivity in case someone messes up the picture settings in case someone playing with it while it was on display at the store
Jan 18, 2009 | Televison & Video
Daewoo Plasma PD46C10
I am an AV dealer in NJ and we always use remotes my universial master and they solve the problem 95% of the time. My favorite to use is the MX-850 because it's PC programmable and has most all the codes. You can also program macros which life easier. www.universalremote.com is the site to check out.. we sell those too.. Sometimes e-bay has them soooo cheap I can't match.. Good luck
Oct 31, 2008 | Televison & Video
Apex Digital LD4088 LCD TV Logo
135 people viewed this question
Top Apex Digital Televison & Video Experts
Jaime Hernandez
robert landry
Are you an Apex Digital Televison and Video Expert? Answer questions, earn points and help others
