SOURCE: Ford 2n tractor. Engine turns, but very slowly. Is
you can get a replacement for that starter at most auto parts stores. there is nothing on the N series tractors you can't buy on line, even complete engine rebuild kits and fenders. look for antique tractor parts suppliers. is it a 6 volt or converted to 12 volt?
SOURCE: My 1994 ford rangers clutch pedal just lost all pedal
There are two types of clutch actuators. (Mechanical & Hydtraulic)
A. For mechanical type,- Check the clutch cable as
this could be cut from wear and tear. This is easy
to replace. You can find this connected to the
pedal and the clutch lever near the transmission.
B.For hydraulic operated - Check the level of the
hydraulic oil at the cylinder of the hydraulic
actuator under the hood. This actuator is
directly connected to the pushrod driven by the
pedal. If the actuator is leaking, you have buy
a repair kit (Hyraulic clutch repair kit for Ford
Ranger 1994 MOdel.) These items must be
repaired to activate your pedal.
SOURCE: Ford Mustang '95 Electric Seat
you have to replace the seat frame rail asy. It comes with new motors. I would check the switches for proper power & operation anyway, but having owned & repaired this myself , I am sure you need the whole assembly. P.S. this is a somewhat involved replacement. remove the seat, remove the rail/motor assembly & replace. reinstall to seat then to car
SOURCE: My 2008 model Ford fusion (diesel) car has
i think you just need a new master cylinder thats all not a big job to change it ,also try squirting the spigot bearing carrier with some engine oil if you get it onto the shaft as the slave cylinder is inside the bell housing on this model andf it could just be that the thrust bearing is sticking to the housing due to wet conditions and dust and dirt inside the bell housing
