Question about Bosch TDA2445 Iron
How do i clean my bosch sensxx cosmos iron - Bosch TDA2445 Iron
  • Bosch Master
  • 43,501 Answers
Here is a tip that will help you with cleaning the sole plate of your iron...
Cleaninga Steam Iron Soleplate
heatman101
Posted on Apr 02, 2011
Bosch Sensixx B25L
see the instruction from your manual:
Check the owner's manual for your iron to learn the manufacturer's suggestions for cleaning, what water to use, and storage tips.
Soft-water systems add minerals that can harm an electric steam iron and your clothes so don't fill the iron with softened water. Instead, use filtered or distilled water.
2) if the iron does not heat a( test the power cord for open or defective b) and thermostat for adjust c) test the thermal fuse d) test the heating element for open.
God bless you
Jul 31, 2012 | Bosch Irons
Brown water spitting out of bosch steam iron
Brown water and white scale are often the result of the water you use in the iron...
If you have scale, white vinegar will clean that...
For brown water, empty the iron, rinse out the insides with bottled water,
and then use the bottled water instead...
Also check out this tip...
Cleaning a Steam Iron White Scale and Brown Water
heatman101
Feb 03, 2011 | Bosch TDA8340 Iron
I have an bosch sensixx b5 iron and the calc clean sign keeps flashing what can i do .i have lost theinstuctions
Here you have how to solve this issue. It has been obtained from the device's manual.
2. calc'n clean The "calc'n clean" function helps to remove scale particles from the steam dispenser. The iron includes a system to warn when the dispenser needs periodically cleaning. When the "calc 'n clean" symbol lights up on the navigation display the dispenser needs cleaning. Fill the water tank. Plug in the iron and select the temperature setting . After the necessary warm-up period, unplug the iron and hold it over a sink. Position the steam regulator to the "calc'n clean" position and keep it in this position. Gently shake the iron. Boiling water and steam will come out, removing any scale or deposits that might be there. When the iron stops dripping, position the regulator to the position. For improved descaling, heat up the iron again fully and press the steam button several times in quick succession. Then wait until the remaining water has evaporated from the soleplate of the iron. Once it has been cleaned, the cleaning warning must be cancelled on the navigation display. To do this, simply press and hold the on/set navigation key for more than 5 seconds, with the iron plugged in. If you do not do this, the cleaning icon will remain lit. 3. anti-calc The "anti-calc" cartridge has been designed to reduce the build-up of scale produced during steam ironing, helping to extend the useful life of your iron. Nevertheless the "anti-calc" cartridge cannot remove all of the scale that is produced naturally over time.
Jan 25, 2011 | Bosch Irons
Instructions for calc n clean HAVE TODAY
Hi
I too had the same problem. I emailed Bosch (via their website and gave them the model number and they have emailed the instructions.
This should have been with the iron in the first place!
Aug 09, 2010 | Bosch Irons
I have a bosch iron and it needs to be calc cleaned how do i do it?
hello my name is gilles to clean your iron get yourself a bottle of clr it is a mild acid pour a litte in with water let you iron sit for 1/2hour or so then drain your iron out by turning it upside down then you should be ok thanks from gilles
Mar 15, 2009 | Bosch Irons
Bosch sensixx 2400w
The cleaning process is to fill up, heat to max, then hold steam lever across to "calc and clean" position whilst shaking gently over a sink.
Manual is available to download from Bosch.co.uk.
Aug 27, 2008 | Bosch TDA8340 Iron
Bosch TDA2445 Iron Logo
370 people viewed this question
Top Bosch Irons Experts
Colin Stickland
Colin Stickland
cwradio73
Gil Shultz
Are you a Bosch Iron Expert? Answer questions, earn points and help others
