Question about Homelite Mighty Lite Lawn Trimmer
I was given a Homelite 25cc string line trimmer, but the string does not spin fast enough to cut the grass. Any suggestions.
  • Homelite Master
  • 7,482 Answers
Check your fuel filter if you have one, normally they will be located in the fuel tank.
If the mower/weedeater is over a year old, then I recommend that you buy and install a new carburetor repair kit,because the diaphragm will get hard and that will cause it to be hard to crank.
Sounds like you will need to clean the carburetor or replace your carburetor internal rubber parts like the diaphgram and O rings.
Be sure to use compressed air to blow out all the fuel and air passages.
Be careful when blowing out the passages, because there are sometimes small rubber type seats in the bottom of some of the passages.
Sometimes you can get by with priming the carburetor or using starting fluid and letting it run a few times like that and it will flush the gunk out of the jets,but most of the time you will need to rebuild the carburetor.
Keep in mind that the float for the carburetor must be level when you go to reassemble the carburetor or follow the instrucitons you get with the carburetor kit.
When you clean your carburetor and remove the jet screws, you will first need to lightly seat the jet screws.
But before you lightly seat the jet screws count the number of turns it takes to seat the jet screws from their original position.
Be sure to mark the turns down on a piece of paper.
That way when you put the jets back in, you know to lightly seat them first and then turn them back out to their orginal position before you started.
This is a FREE answer,Please rate me
Posted on Apr 09, 2011
TB35EC trimmer stalls when given gas, trimmer head is not spinning fast enough to cut grass
check proper fuel---partial clogged fuel filter --exhaust carboned--carb needs repair or replacement--needs tune up
May 30, 2017 | Fast Garden
What do i need for replacement string? Can i go heavier or stay with the smaller string? This is for mastercraft 20v grass trimmer. thanks
the size of the string is critical in electric driven trimmers
it does have mass and the thicker string will over load the motor
stay with the recommended string size and keep to the recommended distance to the grass being cut
string line cutters work on the principle that the tip speed of the string is what does the cutting and that means that the first 1/2" of string cuts the grass
the rest back to the hub acts like a brake as it is dragged across the grass and slows the cutting speed and loads the motor
remember that the machine is designed to trim edges and not to cut down growth-- that is a job for heavier duty units
May 13, 2016 | Garden
Homelite trimmer, gas, string - y is the string wrapping itself around the head of the trimmer?
The line on my new 26cc Homelite would also feed out by itself. That started me thinking the line was wound backwards. I wrapped the line in the opposite direction as was shown on the bump feed reel and now the dang thing works although the bump feed needs to be "bumped" pretty hard to work. Is it possible that the reel was manufactured with the (string direction) arrows pointing the wrong direction? The new 26cc unit is also underpowered compared to my older 25cc trimmer.
Jul 20, 2010 | Homelite Factory Reconditioned 26cc...
I need a replacement head for my 25cc crafstman weedwacker gas line trimmer. I need the whole piece that screws into the bottom of the weed wacker. It is the whole part that spins when the wacker is...
You can find a complete trimmer head replacement at Hyperparts.com. Go into the Lookup By Application section and select the make and model of your trimmer to see a list of the heads they offer.
Jun 28, 2010 | Craftsman 25cc Gas Line Trimmer
Strimmer starts ok but strimmer head does not spin fast enough to cut grass
It sounds like the square end in the handle has rounded some and let cable slip
May 01, 2010 | Homelite Mighty Lite Lawn Trimmer
It looks like its working fine, but it doesn't cut the grass. Looks like the string is spinning with the turn instead of against it, if that makes any sense.
If the string is spinning it should cut no mater which way it is turning. maybe you aren't getting the trimmer close enough to the grass.
Apr 17, 2010 | Black & Decker String Trimmer Cordless 12"...
How do you refill the string on the homelite electric, straigh shaft, 13 in Trimmer?
Is the sting the cutting line at the bottom of the trimmer? If it is pull the spool out. At the bottom of the spool there is an arrow pointing in the direction that the line should be wound. When you first put in the line be sure to place the cutting line in the grove (V shape) and then when you put enough line around the spool. Thread the end of the line thru the hole on the side of the spool. Slide the spool over the shaft of the trimmer and it will click in. When the line is short just tap the spool lightly on the grass and it will feed out more line.
Good Luck.
Jan 06, 2010 | Homelite Garden
String trimmer cutting attachment doesn't turn fast enough
Take the shaft off at the motor,see if any thing is worn there.Also,take head off of end of weed eater,check for grass or any build up in there.
Aug 29, 2009 | Troy Bilt Tb70ss Gas Trimmer
Installing new line on my string grass trimmer
Cut two separate pieces of string, about 7 ft. each.
Stick the end of the line in the hole on the inside of spool.
Wind clockwise onto spool, putting the line that is closest to the ground on first.
Once you have winded this piece on, lock the last 4 inches of line through the slits on spool.
Repeat process for second piece of line, locking the last 4 inches in slot opposite the other locked in piece.
Put the spool on the trimmer, feeding the end of lines through either hole on trimmer.
Before you push the spool all the way on, pull the strings out of the locked position.
Jim
Jul 03, 2009 | Homelite Mighty Lite Lawn Trimmer
Homelite trimmer runs, but can't run attachments very fast.
Doesn't sound like piston and ring problem. Sounds more like the flex shaft that connects to the engine may have an end that is worn not allowing for the extra load when you connect the attachments. Check the ends of the top flex shaft.
Jun 18, 2009 | Husqvarna 28cc Gas Line Trimmer
Homelite Mighty Lite Lawn Trimmer  Logo
77 people viewed this question
Top Homelite Garden Experts
roeb
Roland W VanLue
Roland W VanLue
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
