Question about Creative Labs I-Trigue 3220 Computer Speakers
Suddenly, my speakers won't make any sound. this morning they worked perfectly, and i've checked the input is fine (it works well when i plug headphones in the volume control) and if i plug my ipod, still no sound comes out from the speakers but headphones still work. My guess is that it thinks headphones are always plugged in, as my tv icon indicates. but of course im not sure. please help :/ PS: my model is creative I-TRIGUE 3220
  • Creative Labs Master
  • 27,725 Answers
If you are having problems with your sound
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
hope this helps
Posted on Apr 01, 2011
Suddenly no sound is coming from the tv
Unplug set and or a box if used for a while and plug back to let units reboot.
Look in menu to see if speakers are switched on or off.
Look to see if a DVD etc connected to a rear input has sound or not.
May 29, 2012 | Toshiba Televison & Video
My RCA XL100 is hooked up to cable and works perfectly fine. We've had it for ages and the picture is clear, sound is beautiful, and it gets along fine with my universal remote. There's just one...
Some of their very old sets the video input was located on channels in the 90's; Try scrolling down from 99 to 90 to see if you locate the video input; this is just the way they did things in the older sets.
Before you rate this solution let me know what you find first.
SD TECH
Jul 08, 2011 | RCA Televison & Video
Tv sound wont work
Make sure that all scarts and sockets are plugged in tightly. Try different inputs, try connecting a DVD player or another piece of equipment to the sockets in turn. Also, if you`ve got a sky box, remove the scart plugs one at a time and reconnect it immediately so that you know where you took it from. Check if there`s a switch on the back for external speakers, Make sure it`s switched to internal. Some of the TV`s have the switch for internal and external speakers in the menu`s. Make sure that any switches whether mechanical or electronic are switched to internal. Ian
Jul 24, 2009 | Philips Televison & Video
The right speaker stopped working..i tried unplugging it and plugging it back in and nothing!
1. Check that the speaker input cable or input jack is not damaged. Do this but plugging in some other speakers or headphones into the computer and plugging the speakers into a MP3 player or cd player.
Do that to verify a hardware problem
Jul 09, 2009 | Cyber Acoustics A-3780 Computer Speakers
Left Speaker Stopped Working
I think I had a similar problem. My speakers were brand new and after a while I lost my front left and rear left speaker. I'm not sure about you guys but after fiddling around with the settings it worked after I changed the "S/PDIFoutput sample rate" from 48 to 96 khz. I have no clue what I did, but it worked for me. I am running logitech something or rather speakers with VIA HD audio deck drivers
Apr 24, 2008 | Altec Lansing VS4121 Speaker
D900 Audio Problem
take it and have it check the speaker may need to be replaced
Apr 11, 2008 | Samsung SGH-D900 Cellular Phone
My iPod stopped playing through speakers- but only at work...
Esmurfette
First things First!
1) check on other speakers to see if your iPod work fine
2) check connector for loosing electric connectivity.
3) check with your headphones to see if your iPod play music well.
4) Check, power on the computer spk. you got. or the input that is working right.
Good Luck
Jan 29, 2008 | Apple Logitech Inc MM50 Portable Speakers...
Right speaker doesn't work
I had this very same problem and I had my system for about 2 weeks. I have seen a lot of similar posts on this site so it seems that this problems happens a lot. For some reason my right speaker just stopped working so i came to this site for help. I looked at alot of posts and nothing fixed the problem. when i switched the right speaker to the left input it started to work so I knew the speakers were fine. So i finally decided to unplug everything and restart my laptop. Once my laptop rebooted I plugged the sub back into the wall after about a minute of it being not plugged in. Then I plugged all the the wires and volume control back into the sub and turned the switch back on. Make sure the volume control is down when you plug everything back in. Then plug the wire into the device, which in my case was a laptop, and start to play some tunes. Right away everything was working perfectly fine again and no problems ever since...for me atleast.
HOPE THIS HELPS
Mar 13, 2007 | Logitech Z-2300 Computer Speakers
Creative Labs I-Trigue 3220 Computer Speakers Logo
281 people viewed this question
Top Creative Labs Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Mohamed Ismail
Mohamed Ismail
Are you a Creative Labs Audio Player and Recorder Expert? Answer questions, earn points and help others
