Question about TruTech PVS2119 19 in. LCD Television
I have to connect my Presario CQ60 computer to my t.v. via a VGA port to view netflix movies. I have no S-video port on the computer. With the VGA I get netflix video but no audio through the t.v. speakers. How do I get audio through the TruTech speakers?
    Novelist:
  • 159 Answers
Hi, on the back of your t.v. near the V.G.A. input should be marked another small hole for P.C. AUDIO INPUT or something to that effect, it actually is nothing more than a headphone jack that you connect to P.C.'s LINE OUT/HEADPHONE jack-it's easy to find, the sound on your computer will stop when you plug in a " MALE TO MALE 1/8 INCH STEREO " cord into it. This will give you sound on your T.V. Good luck I hope this helps, Prodzilla.
Posted on Apr 01, 2011
How do i get the netflix app on my soniq tv please
That really depends. Just saying you have a Soniq TV is not much help because the different models have different capabilities. Is it a "Smart TV", if not does it have a HDMI port ? If not, does it have a DVI or VGA port. In order to install an app on the TV, it needs to be a smart TV, if not you can do it using a Chromecast or Roku device plugged into a HDMI port or a computer connected to either a HDMI, DVI or VGA port.
What is Smart TV
How it works Rent Buy Stream Movies TV Shows News
http://blogs.cuit.columbia.edu/ikr2107/files/2014/08/video-display-ports.png
Feb 12, 2017 | The Computers & Internet
Unable to Connect Laptop to Samsung LED TV
VGA is analog - HDMI is digital
if u have a cable w/o a converter it won't work unless your video card supports digital signal output through VGA port function. Please consult with your laptop's user manual for more information.
Dec 10, 2013 | Compaq Presario Notebook
Rgb connection stopped working on laptop
Instructions
    • 1 Decide if you want to watch the television on your computer or use the TV as a larger monitor. If you want to view the contents of the TV on your laptop, you need a video card connected to to the computer. These cards can either be inserted through the express PCI card slot on the laptop, or via USB cable. Make sure the video tuner card supports component video.
    • 2 Connect the DVI-to-component cable into the DVI port if you want to use the TV as a large monitor for your laptop. However, if you have a VGA port, plug the VGA-to-component cable into the VGA port.
    • 3 Plug the RGB component cables into the component side of the DVI- or VGA-to-component cable. If you want to watch the TV on your computer, insert the RGB cables into the TV video card.
    • 4 Plug the other end of the RGB component cables into the TV. If you are using the TV as a monitor, plug the cables into the "Component In" ports. However, if you are sending the TV signal to the computer, plug the cables into the "Component Out" port (the other end of the DVI- or VGA-to-component cable that you connected to your computer in Step 2).
    • 5 Power on the TV. If you are using the TV as a computer monitor, press the "Video" button until "Component Video" appears on the screen. If you are watching TV on your computer, launch the television viewing software that came with the TV tuner card. You can now see the contents of the TV on your computer.
Jan 10, 2013 | Dell Computers & Internet
Emerson lc320em2 how do we hook it up to netflix
The Emerson LC320EM2 is not a Smart TV. To display Netflix content, you can connect the TV to your computer via the VGA port on the TV. Then use the TV as your monitor; this may not work with HDCP content. To do this, turn off both the TV and the computer before connecting the devices. Then turn on the TV and set it to the VGA input (PC) before turning on the computer. (Note: you may have to enable the port in the BIOS on some laptops.) If your computer doesn't have a VGA port, try a DVI to VGA adapter. (This may not work with some video cards that only have digital signal output. Look at the port and make sure that the cable/adapter doesn't have more pins than the port.)
Alternatively, get a set top box with Netflix support. (Some Blu-ray players, the Roku box, Apple TV, or the WD Live Hub all have internet connection options and support Netflix. All will support a wired ethernet connection; some models will require a dongle to connect to a wifi network.)
Once you have the set top box, connect the TV to the box via a HDMI cable (purchased separately for most units). Connect to your internet connection and then log into Netflix, These steps will depend on the unit; please add a comment with your source of the Netflix content.
I hope this helps.
(I have an LG Smart TV; it is slow to find the wireless network when started. So expect some wait time before you can sign into Netflix.)
Aug 23, 2012 | Emerson Televison & Video
We are trying to set up a dual monitor system so that we cn watch movies via the pc [not laptop] we have plugged in all the cables but still zilch
if you want to set up a dual tv monitor system using via pc as a source you will need a VGA splitter usually 2 or more output. now how are you going to connect the 2 monitor and PC to the VGA splitter. first make sure your tv monitor is supported by service input for PC unit. then prepare the accessories needed. the VGA splitter and VGA cable. vinceisaac_30.jpg vinceisaac_31.jpg sample image for VGA splitter VGA cable or connector how are you going to hook up the splitter and VGA cable to the tv monitor and PC
  • you need 3 vga connector and 1 splitter to connect a dual monitor system.
  • connect one end of the vga connector to the pc unit and the other end to the input port of splitter.
  • now the 2 remaining vga connector connect to the output of splitter either of the port, then the 2 end wire you must connect to the input port ( pc service port ) of the 2 tv monitor. make sure you set up the right input either with the remote or at the tv unit to recognized the pc source.
  • you almost done the connections now at this point plug the tv monitors, plug the dc adapter supply of the vga splitter and lastly turn on the pc unit to view movies. i hope it will help you just ask me if you have further questions thanks for choosing the fixya.
Jun 05, 2011 | Televison & Video
How do I get my GT5428 to connect with my TV to access Netflix?
You must be a NetFlix subscriber.
1.Then click on this link http://www.microsoft.com/windows/windows-media-center/netflix.aspx to download NetFlix for Windows Media Center.
2. Open the Windows Media Center
3. Click on Task
4. Click on General
5. Click on Automatic Download Option
6. Configure the time
7. Click on Download Now, to download the latest guide listing
8. You can now select on the videos you like to view.
Mar 01, 2011 | Gateway GT5428 PC Desktop
I want to connect my computer to my Vizio TV to watch movies via netflix on my TV screen. If HDMI on TV end, what connection do I need to connect to the back of computer?
What "video-inputs" does your TV have:
* composite video (single cable for video, two cables for LEFT/RIGHT audio)
* component video (RED/GREEN/BLUE cables for video, plus RED/WHITE cables for stereo audio)
* DVI or VGA input
* HDMI input
* S-Video (similar to PS/2 keyboard/mouse, in size, and "round" shape)
What outputs does your computer's video-card have:
* composite (post-and-ring)
* S-Video
* DVI
* VGA
* HDMI
Just match them up.
Feb 24, 2011 | Computers & Internet
How do i connect this compaq presario model to my sony tv?
you need to have a cable converter, VGA to component/rca output
Jun 05, 2010 | Compaq Presario CQ60-220US PC Laptop
How can i connect my compaq presario cq60-215dx to my tv?
In most cases the answer is "YOU CAN'T DO THAT".
The output from a computer is not a signal that a regular TV can interpret as an image, unless your TV has an input similar to a computer's VGA or DVI port AND the TV's manual says that you can do that. Otherwise, you're out of luck
Mar 27, 2010 | Compaq Presario CQ60-220US PC Laptop
Connections to tv
The tv must have a VGA port, and you need a VGA RGB video cable, then you can connect your computer with your tv, and then do the same you do when you conenct a projector to your tv and that's it.
food luck
Apr 19, 2009 | Compaq Presario R3000 Notebook
TruTech PVS2119 19 in. LCD Television Logo
131 people viewed this question
Top TruTech Televison & Video Experts
Radames Pagan
Radames Pagan
Jason Morris
Are you a TruTech Televison and Video Expert? Answer questions, earn points and help others
