Question about Nixon Lodown Tide watch
Blank screen, watch works when any button is pressed. It is almost as if it is on a powersaving or screen saver type of mode.
  • enrique_ruiz
    enrique_ruiz Jan 09, 2012
    I also have the same problem. My Nixon is a In The Know. THE LODOWN.
  • 2,334 Answers
Make, model, all numbers, please.
Posted on Apr 03, 2011
  • Les Dickinson
    Les Dickinson Apr 03, 2011
    "escapement" My answer to your questions.I am responding to your question about the watch that I need a new band to replace the damaged one on the watch. The watch is a Nike Mettle Blade Watch (black/sport red) WC0037012 or also ASIN B0013ISMHG. The band is broken right at the watch just like all the others I had read about.waknaack@gmail.com (or Grandpa trying to repair my Grandsons watch)Thank you
How do I set digital watch of UL1159
press MODE button 3 times on left screen DAY will flash press RESET MINUTE will flash, change minute what you want by pressing START.
press again RESET button HOUR will flash press START to change hour.
Press again RESET button DATE will flash change same way.
press again RESET button MONTH will flash change same way.
press again RESET button DAY will flash change same way.
After done press MODE to bring back normal time position.
Changing ALARM ....
press 2 times MODE button. Alarm HOUR will flash press START to set alarm hour.
Press again RESET button Alarm MINUTE will flash press START to change.
After done press MODE to bring back normal position.
SO YOUR TIME & ALARM GET SET. images?q=tbn:and9gctqfaospxemzn5ytb2yvmxsagwhcrw-zhdezmqvoulno244gvhvkgaae8w
Oct 04, 2014 | Kenneth Cole Unlisted Ana-Digi watch
Looking for Instruction Manual E377/E378 R/F Watch Having replaced Battery the LCD shows the correct time, date and month. But the pointers are 1hr8minutes fast
You don't say what make of watch you have but I think they work in a similar manner to mine, so try this.
Press the mode button (usually the lower left one) and observe the LCD screen. Each time you press the mode button the screen should change to a different setting mode. Keep pressing it until you find one that allows you to set the hands (on mine it is "HS"). Some experiment may be needed.
When you have found the setting you need, press the buttons on the right to move the hands forward or backward until the correct time is indicated.
When you finished, press the mode button until the normal timekeeping mode returned.
Jul 24, 2011 | Watches
I have a Nixon LowDown Tide Watch and the screen is staying blank, almost as though it is in a battery saver mode unitl i press any button and its display turns on for 3 seconds or so then goes back to...
Hey, this just happened to my nixon watch (I have the nixon housing - same setup as the lowdown) and what you have to do is simply hold in the light display button for about 3 seconds and the display won't disappear after the light times out.
hope this helps :)
Apr 09, 2011 | Nixon Lodown Tide watch
I have an ANIKE Chinese watch Sports watch the watch cannotr be adjusted according to the instructions the watch number is AK6116 does anybody have a instruction sheet on adjusting this type of watch
hold down the adjust button until something starts blinking. press set to change it to what you want and mode to go to the next thing. when you are finished press adjust to get it back to the normal screen.
Dec 02, 2010 | Bulova Watch
How do you set this watch
mcdevito75 here, 1 button should say MODE press this button then press set each function you do press MODE again to move to the next function, day, date, hour, minute etc as each function s set press MODe to move to the next, when done press MODe to stop the flashing screen.
Jun 23, 2010 | Casio G-Shock GW300CA-1V Wrist Watch
I have a g shock riseman g-9200, what does the letters PS mean(just to left of hour in time keeping mode, also is there any indication that i am getting a atomic time keeping signal?.......Thanks.....syd
PS means the watch is in power save mode if there is an indicator under the PS on your watch. this means the watch will go into a sleep mode when it is left in the dark for extended periods. change this setting by holding the top left button until a city code starts flashing, then press the bottom left button until "PSON" is flashing , you can switch between "PSON" and "PSOF" in this way by pressing the bottom right button. i, and casio recommend leaving the watch in the powersave mode though to help extend battery life. I got all this info from my G Shock manual.
Jun 12, 2010 | Casio GShock Riseman AltiTherm GW92001...
Coleman wristwatch - alarm and chime keep beeping
Hey, I had the same problem with my Coleman watch. It would alarm at midnight. I used the mode feature like the poster before me said. When I got to the alarm "screen" I used the button that backlights the watch's screen. The light came on and the alarm feature was removed. I hope this helps.
Mar 12, 2010 | Watches
How to adjust the time for casio illuminator watch instructions s-1045DV
Here is how you do it:
Looking at your watch face: the upper left button is A, upper right is B, lower left is C and lower right is D.
Get your watch into "Hand Setting mode" That is the mode witht he digital time and seconds above it.
From Day and Date window it would mean pushing button "C" six times to get to that mode.
Once in "Hand Setting Mode"
Hold down button "A" til time blinks, then press button "D" to advance the hands, to the desired time.
Press "A" to exit mode.
Press "C" to return to timekeeping mode.
Jan 27, 2010 | Casio Illuminator AQ150W1EV Wrist Watch
Can't get the Hourly chime to shut off - tried going to alarm, then hitting adjust Button - alarm shuts on or off , but not Chime
using the mode button (lower left, go to the alarm. once at this screen, hit the "12/24H" button (lower right). now hit the "adjust" button (upper left), that should toggle the hourly chime on and off. you'll see the bar next to 'SIG'. when it's lit, it's on, when it's blank, it's off.
Oct 27, 2009 | Casio Illuminator AQ150W1EV Wrist Watch
Screen goes blank
I put a new CR2025 battery in my T5e671 Timex and it solved the problem.
The screen no longer goes blank at any time.
PS:Timex manual says "remove battery strap" to replace the battery.
But it doesn't say HOW.-& I couldn't google an answer to that.
Here is how:
The metal strap goes across the middle of the battery and then goes over the edge of it on both sides.
At both edges the metal strap goes over a nylon tab.
One of those nylon tabs is notched, if you put the end of a paperclip in the notch, you can release the metal strap edge that runs under it.
Oct 14, 2007 | Timex Ironman Triathlon 51931 wristwatch
Nixon Lodown Tide watch Logo
810 people viewed this question
Top Nixon Watches Experts
Andrew Taylor
Andrew Taylor
Gil Shultz
Are you a Nixon Watch Expert? Answer questions, earn points and help others
