Question about Vulcan Kitchen Appliances - Others
Vulcan 2grc45 fryer can it be converted to propane
  • Vulcan Expert
  • 684 Answers
All gas operated Fryers can be converted either from propane to natural gas use or from natural gas to propane use. Contact your local supplier on your country and and ask for the conversion kit.
Posted on Apr 18, 2011
I have a Vulcan deep fryer. Converting from gas to LP. Changed out the orifices. Bought high pressure propane regulator. No smell of propane into fryer. Plug unit in and no power to electric...
Hi There. You have not mentioned that you also replaced the spring inside the gas valve suited for propane, please check. I strongly advise not to modify the unit's ignition system nor bypass safety device, this is for your own good. Check the gas valve spring first.
Nov 14, 2013 | Kitchen Appliances - Others
I have a Vulcan lg400 propane fryer I have used 4 times at outdoor catering events over the last year yesterday while using it it began what I would call backdrafting. could low propane level in bottle...
It sure did. Never use a gas fryer in low gas pressure for a long time for soot will build up inside the fire tubes.
Check and clean fire tubes, make sure that the flue is not restricted and there should be no air entering the flue.
Regards.
Nov 03, 2013 | Vulcan LG400 Deep Fryer
I have a Vulcan lg400 propane fryer it has only been used 4 times for catering events. yesterday we were using it and after a while it started what seemed like mild back drafting the flame was actually...
Hi there. Flames rolling back instead of shooting inside the fire tubes can be a result of clogged fire tubes or air entering the flue, also check if there are objects blocking the flue. Regards.
Nov 03, 2013 | Vulcan 1VK85DF Hi-efficiency Gas Fryer...
We have a 2grs45 Vulcan Deep Fryer and would like to convert it from nat gas to propane. What do we need to do?
You need to Order a conversion jet or set of Jets , if more than one from the Manufacturer of the
Deep Fat Fryer, or from your local Retailer.
Just ask for an L.P.G. Conversion Kit for the model of Fryer you have.
The ofirice in the conversion Jets will have been cut to suit the type of Gas you intend using
and so all you should have to do is change the Jet/s.
Eleanor.
Jul 26, 2011 | Vulcan 1GR45M Deep Fryer
I have a older 40,000 BTU 3 burner natural gas deep fryer. I would like to convert to propane gas. The orifice number is size 32. Do I need to get different orifices to convert? The serial number is...
Hi there.
Burner orifice size for propane gas is number 55. You have to replace all burner orifice with this size if you want to use the fryer with propane gas. Pilot burner orifice should be replaced with propane pilot orifice.The gas valve spring should also be replaced with propane spring kit. The difference between the two spring is the natural gas spring is lighter or thinner compare with the propane gas valve spring.
Regards.
Jul 13, 2011 | American Range AF40 Deep Fryer
Label says propane, needs to run on natural gas.
You need to change the gas valve,burner orfices,pilot and maybe a gas regulator.I service these fryers often as im a hobart tech.Goto hobartcorp.com,type in your model and the parts list.Any ? let me know.
May 06, 2009 | Vulcan EF3 Deep Fryer
I cant buy just the nat gas to lp gas conversion parts for a Vulc
call your gas supplier as they have reasonable sources for all of these parts. shame on vulcan.
Mar 31, 2009 | Vulcan EF3 Deep Fryer
Control valve leaking (Vulcan LG300 Propane fryer)
must change gas control valve which will repair leak also
Jul 31, 2008 | Vulcan EF3 Deep Fryer
Kitchen Appliances - Others Logo
254 people viewed this question
Top Vulcan Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Paul Carew
Are you a Vulcan Kitchen Appliances - Other Expert? Answer questions, earn points and help others
