Question about Hoover HCA330FFK Bottom Freezer Refrigerator
The freezer does not freeze the food but the refrigirator is icing up
  • Hoover Master
  • 43,501 Answers
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Apr 02, 2011
HVACRH20
  • 237 Answers
SOURCE: icemaker is not freezing ice, freezer not freezing food,
The ice maker won't work if the freezer is warmer than 17 degrees so that's not an issue till you get the freezer cold again. I would guess that your unit is stuck in the defrost cycle. This could be the defrost timer failing. See if you can find the defrost timer in your unit and advance it by hand if possible. http://www.partselect.com/PartSearchResults.aspx?modelnum=jcd2295hes&mfgmodelnum=&fkmfgid=1&hint=defrost
Posted on Dec 04, 2006
  • 5 Answers
SOURCE: Freezer not freezing properly, ice on back wall
Ice on the back wall indicates a problem with the defrost cycle. The ice builds up and starts to choke off the air flow, so your symptoms would indicate that may be happening.
Defrost problems are usually any of the three components, the heater element, the defrost termination temp switch, or the defrost timer.
Posted on May 29, 2009
SOURCE: Freezer on GE mini fridge not working
change the thermostat
Posted on Aug 30, 2009
  • 109 Answers
SOURCE: Subzero freezer has frost/ice build up on the
Check the fan and readjust temperature control to higher. Thanks.
Posted on Oct 22, 2009
beamerguy740
  • 65 Answers
SOURCE: GE GSS25LGMA refrigirator/freezer refrigirator side is freezing
Temperature control board or control switch needs to be replaced. Your frige doesn't know the temp so it won't shut off at the correct temp.
Posted on Mar 29, 2010
Testimonial: "Sounds like the fix, will check tonight and see..."
Keeps running water and wont make ice
Ice Maker does not make ice; it takes water in and the cold freezer temperature causes the water to freez. Check your freezer temperature and overall performance of the refrigirator.
Oct 19, 2015 | Refrigerators
Upright freezer not freezing food and ice forming on back wall
is the top of the freezer full where it can breathe remove something to help it breathe
Sep 10, 2012 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Refrigerator freezes food
Adjust the "freezer" knob. This adjustment adjust the amount of cold air coming from the freezer to the fridge.
Jul 02, 2010 | Frigidaire 22.6 Cu. Ft. Side-by-Side...
There is an electrically activated air dampener in the upper left back side of the refrigerator section which most likely has broken (in the open position), allowing cold air from the freezer to continue to enter the fresh foods section. Replace the dampener assembly.
Mar 29, 2010 | Refrigerators
Water at bottom of refrigirator
Find the drain line from the freezer to the evaporation pan near the motor. Often the line is visible on the back of the fridge. That line is plugged either with food residue or the collection point in the freezer is solid ice. The self defrost feature melts the frost and drains it to the evap pan. If you remove the floor from the freezer area, you will see the collection point. When the line gets plugged with food, no water drains and then freezes to block the line even worse. So, if there is ice at the collection point, remove it somehow, maybe a hair dryer, and then clear the line by blowing compressed air from the bottom of the drain hose through to the collection point.
Jun 19, 2009 | Maytag MSD2756G Side by Side Refrigerator
May 29, 2009 | Amana ABB1927DE Bottom Freezer...
Whirlpool refrigirator with top freezer
run your hand around bottom door seal see if you can feel a warm spot, if you do check that area for contamanation ie;particals of food etc if not pull the seal in that area back slightly see if seal is split.if all seems ok look at the drain hole at the back of your fridge inside it often clogs up with small particals of food if this is the problem use a pipe cleaner to clean it.if its cloged water will be seen lying at the bottom of your fridge ;if any of the above do not cure your problem turn down your fridge a little this will not affect your freezer.hope this helps you.adrian
Jan 28, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Refrigidare model # plhs267za
sounds like the air damper control for refrig is freezing in the open positon. not a really consumer freindly repair,(dropping side control panel checking damper door for ice build up, removing ice and applying a silicone lubricant(vasiline) to prevent further freezing of air damper motor. sounds easy enoug but that panel is real tricky to drop and mount back in.
Mar 04, 2008 | Frigidaire PLHS267ZA Side by Side...
Hoover HCA330FFK Bottom Freezer Refrigerator Logo
67 people viewed this question
Top Hoover Refrigerators Experts
Charles T Nevin
Charles T Nevin
Jim Goldsmith
Jim Goldsmith
Are you a Hoover Refrigerator Expert? Answer questions, earn points and help others
