Question about Kitchen Ranges
I need to know how to remove the front cover on the ice door model # 10656242400
  • 17,970 Answers
The front dispenser cover can be removed by inserting a screwdriver blade into the two slots on the bottom side of the cover. By gently turning the blade, the cover will snap free at the bottom and can be slid upward to be removed.
If your need some specific part replacement, try to look in this link, according woth your model: appliancepartspros.com/modelsearch_model.aspx?model_id=5416469
Hope helps.
Posted on Apr 01, 2011
I have a jenn-air jcd2389ges. The hole in the door where the ice comes down into your cup is broken. i believe the foam piece is busted
Here is a kit of the most likely parts that you are talking about=> 12001991 Ice Dispenser Solenoid and Door Kit Just disconnect the power and turn water off before beginning to ddisassemble the fispenser components seen here=> JCD2389GES Dispenser Components
1. Unplug the refrigerator power cord.
2. Remove the overflow grille from the housing.
3. Unsnap front cover at the bottom of the housing.
(using a flat blade screwdriver, and tape or pad, twist the screw driver, or pry out the bottom trim using the molded slots in the bottom of the trim panel).
4. Disconnect the front cover switch harness connector and set the cover aside.
5. Disconnect the power wire harness connector (BL/BK and W wires)
6. Disconnect the flapper door heater wire harness connector (if one is present).
7. Release the dispenser microswitch retainers and slide the switches off of their locator pins. Carefully handle the switches so they do not come apart.
8. Disconnect the wires from the terminals of the lamp holder.
9. Remove the two 1/4. hex head screws from the control bracket and remove the control bracket.
10. Remove the 1/4. hex head screw to remove the water fitting (fill spout) from the water dispenser lever.
11. Unsnap the ice guide and remove it from the ice dispenser lever.
12. Remove the air pot by sliding the rear of the air pot out of the slot molded to the dispenser housing and slip the linkage out of the flapper door mechanism assembly.
13. Unsnap the flapper door and remove it from the ice dispenser lever. While you remove the flapper door, carefully guide the flapper door heater wire and connector over the door mechanism assembly.
14. Remove the 1/4. hex head screw securing the dispenser levers pivot retainer to the dispenser housing and remove the retainer.
15. Remove the water dispenser lever.
16. Remove the ice dispenser lever by maneuvering it around the door mechanism assembly.
17. Pull the pin from the door mechanism assembly and remove the spring and mechanism assembly.
18. Reassemble in reverse order.
Need Help let me know, Thanks Sea Breeze
Jul 02, 2012 | Jenn-Air JCD2389G Side by Side...
How do you take the front cover off the door to replace the ice flapper door
Can you provide the model number to your refrigerator? With the model number provided I can look up the schematic to your unit showing how to remove the front cover off your unit. It basicly snaps off the front panel but I think if I provide you a schematic this will give you alot better visual solution to removeing the front cover. I await your reply Thanks Rick
Jul 08, 2011 | Whirlpool Refrigerators
I need to know how to remove thr front cover of the ice maker model # 10656242400 whirlpool
Please click on the link below for the section of the service manual which covers the information you requested.
http://media.fotki.com/1_p,stwkkwgwfdqkrwsxgtqsskgwtqkq,vi/rwsrrbdrxrbtwwdffsxwtrfgfwgs/1/1303472/5961857/image1335834229307956745img-or.jpg
The image will open in a new browser window and will enlarge to full size if you click on it. Basically you need to push down on the bottom centre of the overflow tray and either pull the frame outwards from the bottom or lever it out carefully with a flat-head screwrdriver or similar.
Hope this helps. If I've misunderstood which part you are trying to remove, please let me know. You can reply to me by clicking on "Add a Comment" below your question.
Regards,
BElectric
Apr 01, 2011 | Whirlpool Refrigerators
I need to remove the front cover assembly to replace the ice dispenser door. The model number is Kenmore 106.59292992. Regards... MGH
pop off the front trim with a flat screw driver or putty knife. then remove bolt holding silver clip between ice door and water. door should slide out to replace.
Nov 02, 2010 | Kenmore Refrigerators
Ice Dispenser not dispensing ice
Remove the top freezer door hinge cover and disconnect the plug there . This will remove power to the dispensor . Remove the dispensor grill , and also the 2 screws at the bottom of the dispensor front . Lift the front up and out , and remove the plug on the front . You should now see the white switch bracket . On the left side , is the ice dispensor motor switch , when usually , one of the spears holding the switch breaks off , not allowing the ice dispensor to work . If this is the case , the part number is 2180226 . Only held on by 2 screws . When/if replaceing , be sure to put the plastic spacers in the correct position next to both switches , and be careful not to break one of the spears , holding the switches .
Oct 31, 2009 | Whirlpool Gold GS6SHEXNQ 25.6 Cu. Ft....
Ice maker door stays open. How do I take off front panel to revel parts?
Remove the top freezer door hinge cover and disconnect the plug there . This removes power to the door only . Between the dispensor grate and the dispensor cover , inside at the bottom inside dispensor , insert a butter knife and push down and inward , to pop the bottom of dispensor cover outward , on each inner side . This will pop the 2 plastic clips on the cover off . Lift the cover , to pass the plastic retainer tabs . Disconnect the plug to the dispensor . There are 2 screws holding the white housing which has the switches mounted onto it . Remove these screws , and slide the housing foreward and lift . You should be able to see the complete flap door and the spring and pin , to decide what is causing the door to stay open . If you come back with the found problem , and the model number , I would be able to give you the part number(s) needed .
Sep 10, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ice won't dispense, suspect switch in door cover. how to remove door cover to check? Oddly enough, my ice maker stopped working AND the switch in the door (or other circuit problem for dispensing) failed...
Insert a small putty knife between the dispensor plate and the dispensor cover about 1-2 inches from the sides and press down and inwards . Do this carefully because there are 2 plastic "clips" at the bottom . Once bottom is free , lift upwards and the cover will come off . Remove the plug and it's free . There is a white contraption , large , that have 2 rods the micro switches clip onto and sometimes , the switch on the left , has the broken rod holding the micro switch . This causes no ice dispensing .
Aug 15, 2009 | Whirlpool ED2GHEXN Side by Side...
Flap ice dispenser on door dislocated, screw loose
model? GS6NBEXR
Have a drawing that shows the dispenser is worked on from front. I will be here if you need, Also need the complete model number, Thanks, Sea Breeze
Mar 19, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Spring on ice dispenser door came off but I can't get in to fix.
Remove the dispenser cover by gently prying starting at the bottom going round and round a little at a time to prevent from breaking it. When it's off the screws will be exposed to access the other components.
Nov 12, 2008 | Roper RS25AEXLQ Side by Side Refrigerator
Ice door for ice dispenser not shutting.
How do I remove the ice/water dispenser front cover assembly
May 22, 2008 | Kenmore 53542 / 53544 Side by Side...
Kitchen Ranges Logo
32 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
