Question about Konica Minolta magicolor 2480 MF All-In-One Laser Printer
Transfer roller jam ? - Konica Minolta magicolor 2480 MF All-In-One Laser Printer
2 Suggested Answers
SOURCE: Paper jam at transfer roller with no paper jammed
Had the same problem after cleaning the rollers also. Technical help was rubish. In the end I found some clues n fixed it. There is a flag between the rollers n if it gets stuck and or in my case the spring behind it came off, then the sensor thinks there is a constant paper jam. Undo one screw and get inside n check the spring n flag. I done this. placed sping etc back in place, put it all back together n bingo. Be carefull not to drop the screw inside and make sure the cog is properly engaged or you will get a funny noise. I can provide pics etc if needed.
Posted on Jul 30, 2009
Magicolor 2400w paper jam error at transfer roller
In correctly installed transfer belt. and or roller reseat both. do the internal l machine prints demo page etc. jam if not check the print properties and paper setting of the machine in the draws they must match one could be set to letterhead paper the other normal both have to match.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Feb 10, 2014 | Minolta magicolor 2400W Laser Printer
Tip
Attention To Solve Paper James Of Transfer Roller
Sometimes you may be able to solve the common problems yourself in your laser printer if you know a little about the structure inside it, such as paper jams due to improper positioning at the transfer roller. Before the printing process at the fuser assembly, the paper has to pass through the transfer roller inside a laser printer that is used for transferring toner from the cartridge drum onto the printing medium. It works with opposing electrical charges to pull the toner particles.
Paper jams usually occur at the image transferring process, if the paper get stuck at the transfer roller, just open up the side cover and pull out the paper gently, don't touch roller surface without gloves when hold the ends of the roller, as the sweat and oil of your hand can pollute and damage the surface material.
on May 05, 2017 | Office Equipment & Supplies
HP4+ print quality was perfect, but printer was jamming, so I replaced all the roller parts in the Maintenance Kit, which corrected all jamming! All the paper rollers and the transfer roller is now...
Run the 1/2 test.
Load paper in the manual feed tray.
Print anything that requires more than 2 sheets.
As the paper enters the printer open the top cover.
Remove the toner cartridge.
Look down at the paper.
If it looks like the problems you described, change the toner.
If it looks good, reinstall the old transfer roller and rerun the test.
If transfer roller doesn't fix it, you have a bad fuser. Put the old one in and repeat.
Jan 09, 2011 | HP LaserJet 4 plus Printer
Oki C5500 printer keeps jamming
Open the tray and find yout imput roller. You can remove this roller and put it back on the other side. Normally this is caused because it is worn. The inside of the roller is like a new one.
Jan 11, 2010 | OKI C5500n Printer
Konica minolta MEDIA JAM TRANSFER ROLLER
yes 2 things. 1 bad sensor. 2 bad paper. change paper brand and type. use hammil mill 20# long grain brightness90 and above to test. if this works you need better paper. if not you have a bad jam sensor and need a tech to repair ir.
Dec 30, 2009 | Office Equipment & Supplies
Media jam, transfer roller
Replace the offending transfer roller.
Dec 20, 2009 | Konica Minolta magicolor 2300DL Laser...
Magicolor 2400w gives paper jam error at transfer roller, after I cleaned the printer -laser head.
My 2400W was standing a long time without being used, and when I wanted to use it, it made a very faint image and showed "paper jam at transfer roller". Also, the image stayed on the transfer belt, but never got transferred to the paper. I tried a lot of things, nothing worked, but the message from weirdal1968 above pointed me in the right direction.
I eventually scratched / scrubbed / cleaned the copper pad on the left side of the optical imaging drum - this copper pad probably receives the bias voltage for the imaging drum from a springy stainless steel wire. There was some visible darkening of the copper pad where the stainless steel wire touched, this is what I cleaned. And then, presto, problem solved - the image came out great, and no more "paper jam at transfer roller" error message.
Oct 12, 2009 | Minolta magicolor 2400W Laser Printer
HP 2600n Ironing transfer paper jammed around top roller
It is probably stuck permanently, and the fuser will need to be replaced. I believe the "fuser replacement" instructions are in the manual.
Jun 05, 2009 | HP Color LaserJet 2600n Printer
I think the transfer roller is damaged
Yes - it probably is the transfer roller. the P# is RG0-1025
Jun 09, 2008 | Canon PC-D320 Copier
Konica Minolta magicolor 2480 MF All-In-One Laser Printer Logo
195 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
