Question about Watches
Set alarm for model 50067 - Watches
How do I set the alarm on model wau111a tag watch
  • Pull out the crown to the alarm setting position. The crown is located on the right side of the face of the watch. Pull the crown out until "AL", the alarm indicator, is shown on the watch. Depending upon the model of your Tag Heuer Aquaracer watch, you will either pull the crown out in the first or second position.
  • Select the hours and minuets for the alarm. Once your watch is in the alarm setting position, press the bottom right button on your watch. This will enable you to select the hours and minuets that you want to set the alarm for.
  • Set your alarm. To begin setting your alarm turn the crown clockwise until the desired hour or minutes are displayed on your Tag Heuer Aquaracer watch. If you happen to accidentally pass the alarm time, turn the crown counter-clockwise the get back to the desired alarm time.
  • Save your alarm. When you are ready to save your alarm, simply push in the crown. Once your alarm sounds, to silence it press any button on your Tag Heuer Aquaracer watch.
  • Nov 06, 2014 | Tag Heuer Link Watches
    Set date on 1440 sports watch 504-t5k085
    My watch has model number 504-tsk085, labeled Timex 1440 Sports, and Timex provides the incorrect manual for it online. I wrote these instructions after careful experiment:
    Upper left button: press to switch to a stopwatch, or...
    Press and hold to enter alarm setting mode. Once flashing press again to enter time/date setting mode.
    -- you can only do one or the other without exiting the setting
    mode (time or alarm set).
    - within the setting mode you use the two right side buttons
    in obvious ways to set times/dates
    Exit setting mode by pressing upper left again
    Lower left button: light
    Upper right button (when not setting time): reveal date while pressed
    Lower right button (when not setting time): reveal alarm time while pressed.
    ALSO: WHILE lower right button is pressed you can change alarm
    on/off and chime on/off through the four possible settings by
    secondarily pressing the upper right button repeatedly.
    Mar 01, 2012 | Timex 1440 Nylon watch
    I need to set an alarm on my watch but I do not know how. I have a Baby G watch Casio Model BG169A-1AV
    press mode until you reach the alarm mode then press and hold set button until the digit blinks. note: the one that blinks can be adjusted, the 24 hr/fwd is to add, the alarm on/ rev is to minus. if your done press set button to finish. i hope this will help you.
    Jul 13, 2011 | Casio BG169A-1AV Wrist Watch
    I need instructions on setting the alarm for the Pulsar Chronograph 100M. I'm able to set everything else. Your response is greatly appreciated. THANKS!!
    I answered this for different Fossil watch post, but I believe it will be the same for your watch.
    I'll re-post the answer below.
    To set the alarm on these models of Pulsar watches, do the following:
    Looking at the face of the watch, there are two buttons and a crown on the right side. The TOP button is Button "A". - The BOTTOM button is Button "B".
    There are 3 positions on the crown: IN (#0), FIRST CLICK (#1) & SECOND CLICK (#2).
    The small dials located at the bottom of the watch face (6 O'clock) are the alarm minute and hour dials.
    First, pull the crown out to the second 'click' (position #2) ... This is all the way out. (STOP THERE! Pulling harder will harm your watch! Don't try to pull past position #2!)
    Second, set the correct time. (plus one or two minutes... time to complete this.)
    Third, with the crown still out to position #2, push button "B" (bottom) until the alarm minute and hour hands are set to the present time (same as the large dials).
    Fourth, push the crown all the way in- to position #0.
    The current time on the large dial should read the same as the small alarm 'time'. {This is the CURRENT TIME, not the alarm SOUND SET.}
    To set the alarm SOUND time, pull the crown out to the first click (position #1).
    Push button "B" until the dials of the alarm are at the time you want the alarm to sound... It can only be set within 12 hours! ... It does NOT know "am or pm".
    When the desired time is set for the "alarm sound", push the crown all the way in (position #0).
    The alarm dials will now indicate the time for your alarm to sound, NOT the current time. (this way, you know that the alarm is engaged.)
    To reset the alarm- or disable it, pull the crown out to the first click (position #1) and hold button "B" down until the dials advance and stop at the current time... it will stop at the current time- then release button "B". --- Push the crown back in (position #0) and the alarm will now be disabled.
    If the alarm dials are always moving and at the current time, you know that the alarm is disabled.
    If the alarm dials are stationary and not moving with the time, you know that the alarm is engaged and set to the time shown.
    I hope this helps.
    Nov 05, 2009 | Pulsar Chronograph Watch
    Need to turn off alarm
    A model would be most helpful here. Timex has a couple different alarm set ups.
    With most of their watch if you cycle through the modes using the mode button you will come to alarm. Depress set and the alarm will toggle on or off.
    With Dial alarm models you simply depress the alarm button (the one with the red stripe).
    Sep 18, 2009 | Timex Watches
    Lost instructions for Lexon world time clock model Planete
    to set the alarm, press and release the "alarm" button; then press and hold the "set" button until the hour begins to blink. press "adv" until
    the hour AM or PM is correct;now press and release "mode" so that the minutes begin to blink. Set the minutes using "adv"; now press and release "set". Finally,
    press and release "adv" once to bring up (or remove) the alarm icon. Then press"alarm" once to return to the main display.
    To set main display, press and hold "set" until the hour begins to
    blink; press "adv" repeatedly until hour AM or PM is correct. Now
    press "mode" so that the minutes blink, and use "adv" to get the
    minutes right; then press "mode" so that the next item begins to
    blink; use "adv" to advance until it is correct, then press "mode"
    so that the next item blinks, and so forth until you're all done.
    Finally, press and release "set".
    Aug 10, 2009 | Watches
    Set the alarm
    To turn the alarm off press and hold st/stop and then press lap/reset. To set, press the lower left hand corner button, you will see the option to set the alarm first and then the option to set the actual watch time.
    Apr 10, 2009 | Watches
    How can i set digital time and alarm in the Timex wrist watch model is- MF13-Y-S7
    Try this ,it may work for you as i m having mf13-t1
    Press MODE then then SET
    Press ALARM to increase the count and to change time t1 or t2.
    Press MODE to switch the digit place
    finally press SET and then MODE
    Note: Check for bell and sound symbols,if they are not there
    Press MODE then then SET again press SET
    Press ALARM for once or twice depending on symbols.
    Mar 18, 2009 | Timex 27191 Wristwatch
    Alarm goes off at midnight & repeats for half hour, and not set
    what you have to do is
    1. press the mode button until you get to the setting that has "AL" at the bottom right.
    2. then you press the "receive" button to switch between the four alarms.
    3. as you are going through each alarm time, you need to look in the circle at the top right. When you are going through the alarm times, if there is a mark next to "ALM", you need to press the "time memo" button so that the mark next to "ALM" is no longer there.
    4. repeat step fout for all of the alarms, and the problem should be fixed.
    Apr 13, 2008 | Casio Wave Ceptor WV57HA-1AV Wrist Watch
    Old model timex compact disc digital audio
    Hi catlady05,
    To set the digital time and date on your Timex Ironman, please follow the steps below.
    1. press and hold the "set" button for two seconds.
    2. Use the "advance" button to reach the correct hour.
    3. Press the "mode" button, followed by the "advance" button to set the minutes on your Timex Ironman.
    4. Repeat the procedure of pressing the "mode" and "advance" buttons to set the month, date, year and day of week.
    5. When you are finished setting the time and date, press the "set" button to save.
    Setting an Alarm
    1. Begin by pressing the "mode" button until the alarm screen appears.
    2. Press the "set" button and use the "advance" button to set the hour for your alarm.
    3. Repeat the same procedure to set minutes and seconds for your alarm.
    4. When you have finished setting the alarm, press the "set" button, followed by "advance" save and activate your alarm.
    5. When you alarm sounds, you can deactivate it by pressing any button on the watch.
    Hope it helps.
    Thank you for using FixYa.
    Oct 29, 2007 | Timex Ironman 53151 Wrist Watch
    Watches Logo
    11 people viewed this question
    Top Watches Experts
    Ansel Alberto
    Ansel Alberto
    Are you a Watch Expert? Answer questions, earn points and help others
