Question about Car Audio & Video
After exiting freeway and at the light off of ramp, when light turned green, car would not go forward. engine did not shut off, and all electrical remained on. I shut the engine off, turned the surity off and on, started back up, and car moved forward at that point. coincidence that it seemed like the security, or something more sinister? running fine now, but dropped off at mechanic to have a look.....
  • cleedusb Apr 01, 2011
    great, hopefully not a painful repair! I will pass on info to mechanic, thanks....
  • 2,427 Answers
Well its not your security system.. more than likely its the harness that connects to the park neutral switch and sensors on the transmission, sort of swung a bit loosened up and shorted, when the vehicle came to s stop the solenoid sent the signal disengaging the system but didnt when you presses the accelerator. cutting off and on reset the system and so fixed it.
to make sure it dont happen again get the electric accelerator your car got looked at, as well the cables connecting t your transmission. once everything is tightened up you'll be fine. Was it anything more serious u would have needed a tow truck.
Posted on Apr 01, 2011
I ask a question on what is the drive cycle to reset obd for toyota2005 rav4
Step One: How to Prepare Your Vehicle
  • Have the fuel tank between 30 and 70 percent full. Some systems, especially the EVAP system, need to have a specific level of fuel in order for the tests to be trusted. If the fuel tank is near empty or completely full, many of the basic tests will not run at all.
  • The vehicle must also have a good alternator and a strong battery. If you have to occasionally jump-start your vehicle, all of the memory from the powertrain control module (PCM) is erased, which includes the data that accurately tracks the results from various stages of the Drive Cycle. Also, if the battery is weak or undercharged, some of the most important tests will never run.
  • The vehicle must sit overnight, or for at least eight hours, in an environment that is less than 90° F. The engine temperature needs to match the air temperature in order to establish an accurate baseline for the testing. If the outside temperature is over 90° F, the fuel is too volatile and the EVAP system won't even try to run its tests, though some of the other emissions systems may run their tests.
  • The keys must be out of the ignition and all of the doors must be closed while the vehicle sits over night because many of the onboard computers "boot up" when the keys are in the ignition. Also, many of the onboard computers still run until all of the doors are closed after the vehicle is shut off and the keys are removed.
Step Two: The Cold Start
  • Start the vehicle and let it idle for two to three minutes in Park or Neutral. While it is idling, turn on the head lights, heater/defroster, and rear defroster for a three to five minute warm-up phase. Let the idle speed settle down to near the normal speed.
  • Next, put the vehicle in gear and drive through city streets at about 25 mph. Go up to about 35 to 40 mph a few times before slowing down to stop. Don't roll through the stop; be sure the car is really stopped, just like you learned in driving school. Accelerate from each stop in a normal fashion-not overly conservative, but not like you are competing in a drag race either.
Step Three: A Short Freeway Trip
  • After the vehicle has been cold started and driven for a few miles on city streets, the next step is to take it on a short freeway trip.
  • Enter the freeway on-ramp and allow enough room with respect to other vehicles so that you can do a 1/2 to 3/4 throttle acceleration up to freeway speed.
  • When you have accelerated up to around 60 mph and have safely merged into the flow of traffic, stay in the slow lane and maintain a steady speed of 55 to 60 mph for a minimum of five miles. Please use the cruise control to help you maintain speed.
  • Find a nice, long off ramp to exit from the freeway. As you exit, take your foot off of the accelerator and let the vehicle coast down until it stops under its own power as you complete your exit from the freeway. Do not use the foot brake and do not shift gears until the very end of this "coast down" phase.
  • Step Four: More City Driving
    • After you have completed the freeway trip, drive through the city streets for a repeat of the second part of Step Two.
    • Go up to about 35 to 40 mph a few times and then maintain a city speed of 25 mph before slowing down to stop. Again, don't roll through the stop and make sure to accelerate normally.
    • Pull in to a parking place and let the engine idle for one to two minutes and then shut it off.
    Step Five: Have your Readiness Monitors Checked and Verified
    • Drive your vehicle to your regular shop and have them re-check your readiness monitors, present codes, and pending codes. They should do this as a courtesy and for free.
    • If all of your monitors are "ready" and there are no present or pending codes, then your vehicle has been properly repaired and is ready for an emissions inspection and for normal driving.
Feb 21, 2017 | Cars & Trucks
Oil light and battery light came on and sounded like car shut off. 07 Hyundai accent
The timing belt is supposed to be changed at 80,000 miles. Dont let it come apart on you. Intake and exhaust valve damage can occur if not corrected. Sounds like its missing teeth allowing timing to walk
Aug 13, 2017 | Cars & Trucks
Transmission doesn't downshift when accelerating on freeway
the most likely problem is the sending unit the throttle pedal is connected to. But check that all the linkage (if there is any) on the tranni is functioning
Mar 12, 2014 | 1999 Kia Sportage
Ford diesel excusion A/C won't cool
Any performance testing re auto A/C requires consistant engine revs highway revs eg 1800 exit ramp eg idle stop start 800revs leading to much reduced A/C compressor speed and therefore performance output .Also all testing its desirable to close the bonnet to control design air flow through the engine bay .Also check under dash passenger side air flow pos a filter on return air duct or something sucked up into paper etc .good luck!
Apr 21, 2012 | 2003 Ford Excursion
2001 nissan altima doesnt acclerate
shut the car off and look at the throttle body, have someone step on the gas pedal if the throttle body does not open up then the cable from the pedle to the throttle popped off or broke
Mar 26, 2012 | 2001 Nissan Altima
Was driving my 2005 Mazda 6 in the curve of an exit ramp and just at the end of the ramp just before being able to exit onto the highway, the car cut off. We tried to start it, but it wouldn't crank. ...
This is likely to be electrical related.
Your vehicle's On-board diagnostic (OBDII) computer will have stored the applicable fault codes.
Have your computer scanned by your local Mazda dealership (or approved agent) for these codes, which will immediately identify the circuit/component causing this condition.
Cheers,
Jun 14, 2011 | Mazda MAZDA6 Cars & Trucks
2003 Dodge Neon SXT Clutch Problem Less Resistance
check clutch resevoir for brake fluid if none theres a leak if not clutch in need of repair!!! :)
Jul 06, 2009 | 2003 Dodge Neon
Engine suddenly revs when stopped & @ idling
sounds like one of the metal arms connected to the engine may be getting stuck some how. have someone get in car and press on gas when car is off while you watch engine to see what is moving, then check those arms to see if there is any possible obstructions or knicks or something on them
Jun 16, 2009 | 2004 Mazda 6
When im under a half tank of gas car is shutting off
THE ISSUE IS THE FUEL PUMP IS SUCKING AIR, DO YOU HAVE ANY DAMAGE TO THE BOTTOM OF THE GAS TANK? THAT MAY HAVE KNOCKED LOOSE THE INTERNAL BAFFLE THAT PREVENTS THIS ISSUE
Sep 05, 2008 | 1994 Oldsmobile Eighty Eight
Car Audio & Video Logo
18 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
