Broken ON switch. How do I open the case? There are two stubborn tabs, one on each side of the keyboard
  • 1 more comment
  • JDTec
    JDTec Apr 01, 2011
    What model?
  • rastaboy2000 Apr 01, 2011
    That didn't help me open the case at all. Maybe you are looking at/thinking of a different machine? The problem is getting the tabs on either side of the keyboard to release.
    It's a Gateway NETBOOK. Model LT2107. I managed to re-align the ON button without getting the case open, and now it's working again.
  • 2,427 Answers
  • remove the battery
  • remove screws under battery
  • turn laptop back over and open up the screen a back further than normal.
  • use a bladed screwdriver and pry the cap off (the piece with the buttons onto just above the keyboard)
  • there you go you should have access to the power button now.
Posted on Apr 01, 2011
  • 1 more comment
  • Rishi Roshan Ali Apr 01, 2011
    whats the make and model of your laptop ??,,
    remove the top panel above the keyboard. this will expose 2 screws holding the keyboard from the top. Remove the screws then slide he keyboard toward the screen and pull up
    give me the make and model I'll see if i can get some pics to help you out.
    ok this isnt your exact model but the principle is the same
    http://www.insidemylaptop.com/take-apart...
    follow those instruction
Yamaha psr700 speaker cover removal
Assuming this is a PSR-S700 then you need to undo all the screws under the keyboard and open up so you can see inside under the speaker grill. You will see the grill has tabs that poke through the casing and these are then twisted to keep it in place. Straighten these, push tab through casing going from side to side and then the grill will eventually work free. You do not want to do this too much as the tabs will eventually break with wear.
Jun 18, 2016 | Yamaha PSR-S500 Digital Keyboard
Replace keyboard
Yes Bruce, Absolutely!
1) http://www.youtube.com/watch?v=vqQ3kdtUNFc
2) The Keyboard Cable STAYS attached to the Keyboard.
It removes FROM the motherboard connector.
The Keyboard Cable is a FFC. Flat Flex Cable.
General example of a FFC,
http://en.wikipedia.org/wiki/File:Flat-Flex-Cable.jpg
NOTE that there is no connector attached to the cable.
Just exposed flat contact pins.
These contact pins MUST line back up, as when the cable was originally installed.
For this reason I suggest making a mark (Sharpee?), on one side of the cable, and a matching mark on the same side of the motherboard connector; BEFORE removing the Keyboard Cable from the motherboard connector.
Gives you a reference as to which way the new Keyboard Cable goes, when installing the new Keyboard.
Twisted, flipped over,....going to Florida for vacation; the new Keyboard Cable MUST go back same position, as the old Keyboard Cable.
What he is depressing are 3 spring Detent's above the Keyboard.
Approximate locations;
A) Above the F2 and F3 keys
B) Above the F7 and F8 keys
C) Above the Prt Scr and Pause/Break keys.
Small rounded tabs. Along the lines of this Asus K53u laptop example,
http://www.insidemylaptop.com/how-to-disassemble-asus-k53u-laptop/
Look at Step 6 and Step 7 photos.
I use a flat tip Jewelers screwdriver. Be gentle so you do not scratch the plastic.
Start on the Right side, gently depress the Detent, and at the same time use a fingernail to gently lift up on the upper right side of the Keyboard, a little.
Now go to the middle Detent, and finally the Detent on the Left.
Lift the Keyboard on the LCD screen side up, JUST A LITTLE.
Then slide up towards the LCD screen, Just a Little.
There are plastic tabs formed out of the Keyboard on the side facing you. If you bring the Keyboard straight up, you chance breaking those tabs off.
Tabs cleared, roll the top of the Keyboard, (LCD screen side), towards you.
Be gentle as the Keyboard Cable is STILL attached; you can only go so far.
The motherboard connector is a type of ZIF connector.
Zero Insertion Force.
It is composed of two pieces, but does NOT come completely apart.
Three styles are used, two currently to my knowledge.
Yours is the Flip Up type.
The bottom part is rectangular in shape, and is the larger piece.
It is stationary to the motherboard, and is called the BODY.
The top part is also rectangular in shape, and is the smaller of the two parts.
It is movable, and is called the Locking Bar.
IF, the Locking Bar comes off of the Body, it is broken; or the hinge pins in the Body the Locking Tab hinges on; are broken.
This = MOTHERBOARD REPLACEMENT, and why I am being so detailed.
Be G-E-N-T-L-E with this connector.
(You'll be OK, I'm just giving you a 'heads up')
Locked; or can be said as Closed; position,
http://www.irisvista.com/tech/laptops/Toshiba-Satellite-L645D-L640D/big/laptop-disassembly-13.jpg
Unlocked, or can be said as Open; position,
http://www.irisvista.com/tech/laptops/Toshiba-Satellite-L645D-L640D/big/laptop-disassembly-14.jpg
About 10 minutes, and you should be clicking keys away!
Just from a quick search. Suggest perform your own, and suggest from a reputable dealer also,
http://www.laptoppartssolution.com/servlet/the-552/Acer-AOD257-dsh-13450-keyboard%2C-Acer/Detail
For additional questions please post in a Comment.
Regards,
joecoolvette
Dec 14, 2012 | Acer Aspire One D257-13473
Open the asus ul50v case
No hints. Just a disassembly pictorial guide that is real close,
http://www.insidemylaptop.com/how-to-disassemble-asus-ux50v-laptop/
Okay, maybe a few...............(lol!)
1) Always remove ALL power remove the AC adapter (Charger), and Battery.
2) Use a multi-compartment container for the various screws you will remove. Label each compartment for the area the screw/s come out of.
SOME screws look VERY similar to other screws.
Advise DO NOT mix them up.
As you can see viewing down the various photos in the pictorial guide, the Top Cover, along with the Display Assembly, is removed.
Has to be removed in order to access the Power Button Board.
In order to remove the Top Cover, the Keyboard is one of the items to remove first.
Look at Step 4.
The Keyboard Cable STAYS with the Keyboard. It removes from the motherboard connector.
Again,....Removes FROM the motherboard connector.
It has NO connector on the cable. The connector is on the motherboard, and stays on the motherboard.
The connector on the motherboard is made of two pieces.
It DOES NOT come completely apart!
If it is in two pieces it is broken, and you are looking at motherboard replacement.
Hence why I am being so detailed. Do not break it!
The motherboard connector has a larger bottom rectangular piece, which is the BODY.
It has a slimmer rectangular top piece, which is the Locking Bar.
The Locking Bar is wedge shaped. When locked into position in the Body, the wedge shape wedges the Flat Flex Cable, and locks it in.
The Locking Bar is Brown. All you will actually see are two tabs of it.
One tab on one side, and one tab on the other side.
Use your finger/thumbnails, and ease the tabs towards the cable itself.
(Away from the Body of the motherboard connector)
If you look close at Steps 4 and 5, you can see the brown tabs of the Locking Bar have been moved forward, and away from the Body.
The Locking Bar ONLY MOVES about 1 to 2 Millimeter's.
[2mm is a little larger than 1/16th of an Inch. 1mm is a little larger than 1/32nd of an Inch. Use a tape measure to compare, or another measuring device ]
I just searched to find a replacement Power Button Board. No luck on this end, hope you have better.
Regards,
joecoolvette
Jul 01, 2012 | ASUS UL50Vt Notebook
How to open casing and upgrade the RAM in Gateway LT2811u?
A) No, the case does not lend itself for easy access to the Ram Memory.
B) 'Other site' is full of beans. Impossible to replace, or upgrade the Ram Memory? Must not be a professional product support website, and does not have computer techs.
1) Work on a table. If the table is on a carpeted floor, refrain from swinging your legs. Observe Anti-Static Precautions.
[ Anti-Static Precautions:
Your body carries Static electricity. Static WILL fry out (Short Circuit), the delicate hardware components inside a computer.
With a desktop computer you can relieve your body of Static by;
Computer on a table, computer unplugged from power, computer case open.
TOUCH an unpainted surface, of the metal frame of the open computer case.
This action will relieve your body of Static.
IF, you leave your computer in the middle of working on it, be SURE to Touch the metal frame again upon your return.
No such luck when working on a laptop/notebook/netbook/tablet.
An ESD wrist strap should be worn, and it's alligator clip connected to a good ground source.
{ Average cost of a Electro Static Discharge wrist strap, is around $3 to $6.
Example,
http://www.radioshack.com/product/index.jsp?productId=2103245
(It isn't just a piece of wire connected to an alligator clip, and to your wrist. The wrist strap has a metal plate which contacts the skin of your wrist. The metal plate is connected to a 1 Mega Ohm resistor, which in turn is connected to the wire going to the alligator clip,
http://en.wikipedia.org/wiki/Antistatic_wrist_strap )
I connect to an unpainted surface, of the metal frame of an open, Empty desktop computer case ]
It may be argued that you are just replacing Ram Memory, and an ESD wrist strap is not needed.
In this instance I will agree.
There is a metal static shield under the Keyboard, and next to the Ram Memory. The Processor is under the motherboard. (To the right of the Fan Assembly, when looking down from the top)
Also, ram memory modules ('Stick') are coated with a see-through plastic coating, on the Body of the module.
(Refrain from touching the gold plated contact pins on the bottom)
I would place a clean towel on the table, to protect the table, and the Netbook, lay the closed netbook upside down on it. (Bottom side up)
2) Remove ALL power. Remove the AC adapter (Charger), and Battery.
3) Turn the netbook over, open it as far as possible.
Remove the Keyboard
4) Removing the Keyboard:
At the top of the Keyboard, (LCD screen side) there are 4 Tabs to release.
They are from Right to Left;
Above the DELete key, F12, F8, and F4 keys.
If you look close you will see four thin rectangular pieces of plastic, above the noted keys.
These are depressed down.
I c-a-r-e-f-u-l-l-y press down on them, with a flat tipped Jewelers screwdriver.
Start on the left side with the release tab above the F4 key.
Once depressed the Keyboard will be released from this tab.
Go to the next tab, and so on.
Once all release tabs are released, the top of the Keyboard should pop up, a little.
S-T-O-P!
The Top of the Keyboard is lifted s-l-i-g-h-t-l-y up. Do Not raise it too high.
There may be side tabs also. These will pop loose once the top of the Keyboard is raised up slightly.
There is also a Keyboard Cable attached to the Keyboard.
It is Not needed to disconnect this cable, and I STRONGLY advise against it, as the plastic tabs of the connector on the motherboard, will break VERY easily.
Leave the Keyboard Cable attached.
The Back of the Keyboard may have plastic tabs protruding from it.
This is why the Keyboard is only raised to a slight angle, also.
With the Keyboard in an approximately 45 degree position, move it forward a little, then roll it over, and lay it down.
(Top of Keyboard lays down)
The bottom of the netbook has a Door. This Door is removed for access to the Ram Memory, and Harddrive.
Keyboard removed there are 5 screws marked with Door next to them, to remove.
Push on Door Release (Pretty hard) to ease the Door out.
Then go around, and gently pry the Door off.
Each ram memory module has a spring clip on the side. Each side.
The top of the clip is gently moved to the outside, just a little.
The top of the spring clip has a 'bump', or protrusion, which fits in a Side Notch, on the Ram Memory module.
Once both spring clips are eased out, the Ram Memory module will slightly spring up.
DO NOT remove a Ram Memory module in a straight up position!
You will bend contact pins down in the ram memory slot on the netbook, and damage the contact pins on the Ram Memory module.
The Ram Memory module is brought out in a 45 degree position.
It is installed back in the same position.
Handle the Ram Memory module by the Body. The body is coated with a see-through protective plastic. (The gold plated contact pins are on the bottom, of the Ram Memory module. The rest of the module is the Body)
When the protrusions of the spring clips are fully seated in the Side Notches of the Ram Memory module, the Ram Memory module is fully seated in the ram memory slot.
(Note*
The spring clip protrusion, and the Side Notch, are not a perfect fit.
A little leeway is allowed )
The Gateway LT2811u Netbook PC uses DDR3 Sdram ram memory, that operates at a maximum frequency rate of 1066MegaHertz.
(1066MHz)
It is PC2-8500 that is SO-DIMM.
The Maximum TOTAL Amount of ram memory is 1GB.
There is 1 ram memory slot.
Regards,
joecoolvette
[ Mega = Approximately 1 Million
Hertz = Cycles per Second
The above ram memory, can operate Up To 1066 Million Cycles per Second, frequency rate. ('Speed')
Dec 11, 2011 | Gateway Computers & Internet
Need to reattach the W key on my Fujitsu Lifebook P7230
You may have broken a plastic "hinge", more like a tab or clip. Try taking it off again and examine the underside of the key. If it looks ok, try putting it back on. If a plastic tab/clip is broken on the left side, you should be able to go to a small computer repair shop and get a replacement key for it. That way you don't have to replace the keyboard.
Jan 04, 2010 | Fujitsu LifeBook P7230 PC Notebook
When I close the mirrors they immediatly open again
There are micro switches located in the mirrors. A metal tab is broken on one of the mirrors micro switches. Take off the painted cover to your side mirrors and remove a black plastic cover that has wires coming out. The switch will come out with the cover. Inspect for damage. If the metal tab is broken off then a new side mirror will need to be purchased. Could be the drivers side or the passengers side, caution when removing the painted covers, the tabs break if your not careful with them.
Jun 19, 2009 | 2005 BMW X5
REPAIR
1) Be sure the load of clothes is not lop-sided. If the tub becomes unbalanced, it may spin erratically or not at all. Sometimes you can just open the lid and reposition the clothes. This automatically resets an off-balance shut-off switch. Just close the lid and retry.
2) Check the lid switch and the tab on the lid that strikes it. If the plastic tab is broken, the washer may halt during the spin cycle. If the switch doesn’t click when you press and release it, it’s probably broken. If you’re experienced at home repair, you can remove the switch, test it, and replace it if needed; otherwise, call an appliance repairperson.
3) The belt may be loose, worn, or broken. If you’re fairly handy, tighten or replace the belt; otherwise call an appliance repairperson.
4) There may be a problem with the controls; in this case, call an appliance repairperson.
please give me a good rating if solution works for u
Thanks for using FixYa.
Jan 05, 2009 | LG Washing Machines
How to Open a Winbook Si Laptop
The keyboard is fairly easy to get off. At the top there is a plate that covers the switches; on the left there is a tiny hole that you use a paper clip to push down gently and unlock a catch (like on a CD-ROM drive door). While gently pushing down, slide the entire cover to the right, and then lift it out. This will loosen the top edge of the keyboard; lift from the top edge and push toward the screen, and the tabs at the bottom edge will slide out of their sockets. The keyboard mylar flat cable will have some sticky stuff on it, so be careful when lifting the keyboard not to tear the keyboard cable.
Once you get the keyboard off, you can also remove the CD-ROM drive (two screws, silver and black).
To get at the hard drive, which comes out of the top of the case, from under the keyboard palm rest, you take out the battery, and the three screws on the bottom side of the case nearest the front edge. Then you can pop off the black keyboard palm rest below the keyboard. Be careful to not damage the cable connecting the touchpad to the mobo; it has a little plastic connector. The HD has three screws holding it in, including one on the adapter that attaches the IDE connector to the mobo.
Hope that helps
Aug 13, 2008 | Micro Electronics WinBook Si Notebook
Samsung v20 disassembly
After removing the screws, lift the keypad by releasing the two latches just below the ALT key and WINDOWS key. Two more screws are hidden beneath the keyboard. Hope this helps
Sep 03, 2007 | Samsung V20 XVC 2400 Notebook
Broken on-off switch on Rio 600
They are Hex head screws. You need a small (1.3MM or .050) Hex head bit or Allen wrench. After removing the two screws the case will split. However the problem I'm having is figuring out how to re-attach the switch. It's a very odd connection.
Apr 29, 2007 | Rio 600 MP3 Player
Computers & Internet Logo
18 people viewed this question
David Payne
David Payne
