Question about Aurora Electronics Office Equipment & Supplies
How do you set a compact scientific calculator SC220 to scientific calculation
  • 333 Answers
SOURCE: instruction manual for Casio fx -991 Scientific calculator
There are plenty of casio 991 manuals here. Take your pick!
http://safemanuals.com/zearch_160.php
Dom't forget to leave feedback if it solves your problem. 'fixya'!
Posted on May 01, 2008
SOURCE: How do you put the fourth root into scientific calculator
Do whatever the number is then ^(1/4)
Posted on Jun 02, 2009
  • 7993 Answers
SOURCE: Inputing scientific notation into my calculator
1. To convert a number to scientific equation, use [2nd][Sci]
Exemples 12345 [=] screen shows 12345 Then [2nd][Sci] coverts it to 1.2345 ^04 to the power 4.
2. To enter directly a number in scientific notation (e.g. -1.2345 X10^(-65) a very small number) you use the [EE] key 1.2345[+ /-][EE][+/-]65 shows as -1.2345 -65
1.6X10^(-19) 1.6[EE][+/-]19 shows as 1.6 -19
Hope it helps
Posted on Sep 17, 2009
  • 7993 Answers
SOURCE: is the CAsio Scientific calculator fx-82TL a
Sorry to disappoint you: This calculator is not programmable.
Good luck.
Posted on Nov 30, 2009
Testimonial: "Very much appreciated, quick response etc. "
  • 7993 Answers
SOURCE: I bought a Kenko KK-82TL Scientific Calculator but no manual
I have found the company site for you. Here it is. You can send an inquiry to them.
But from the looks of it, I believe this calculator is rebranded Casio FX-82. An even if I am wrong, you should still be able to make good use of the Casio FX-82 manual to understand how your calculator works. Scientific calculators do not differ much from one another.
Here is the link to the Casio FX-82 manuals.
Posted on Jul 23, 2010
Can the scientific calculator solve all maths questions
It depends on your application? I had one on a construction site and it was wonderful. Look up the particular model and see if it applies to you Obiri. Thank you and leave some feedback for I'm a newbie!
Jul 13, 2016 | Scientific Calculator Office Equipment &...
Casio FX83ES Scientific Calculator 83gt, calculator back to normal settings?
Clear the calculator.
Press [SHIFT][9] (CLR) or [SHIFT][MODE] (Setup) 8:Norm and choose Norm1 or Norm 2. Select the number of digits.
Dec 11, 2013 | Casio FX83ES Scientific Calculator
I have casio fx-82MS scientific calculator.which display 'd' letter on the screen.after i switched off the calculator even it wont delete.how do i get rid of that?and is it cause my reaguler...
Most likely you set the angle unit to degree. As long as you do not calculate trigonometric ratios you won't get incorrect results. Switch the angle mode to radian if that is what your calculations require.
Aug 21, 2013 | Casio FX-82MS Scientific Calculator
How to I stop my sharp EL-531X calculator from rounding when converting from decimal to scientific notation?
You need to select the number of decimal places you would like, or if you would like the calculator to behave as normal. Press SET UP and select FSE (press 1) . You now have 5 options.
0: FIX means you can choose a fixed number of decimal places for every calculation.
1: SCI means scientific notation and choose the number of significant values you would like to deal with.
2: ENG means engineering and the power goes up in multiples of 3.
3: NORM1 and 4: NORM2 are the usual or normal settings on the calculator. Most school calculations will use NORM1 mode.
Aug 28, 2012 | Sharp El-531x Scientific Calculator Green...
When calculating trignometric values i always get a wrong answer what can i do to reset or delete memory for a casio fx82ms scientific calculator plz help
It is most likely that the angle unit is not set to correspond to the angle unit you are using in your problems. If your problems call for angle unit in degrees, set the calculator to do its calculations in degrees. If your problems require the radian angle unit, set your calculator accordingly.
Jan 12, 2012 | Casio FX82MS Scientific Calculator
How do I change from having the answers displayed in scientific notation to normal number display?
You can set your display mode to FIX or NORMAL ( 1 or 2) if you have them. However if the result is too small ( less then 0.001) or too large the calculator will use the scientific format. Generally if there are not enough display positions to show your result, the calculator uses scientific notation.
Jul 04, 2011 | Casio FX-260 Calculator
Scientific notation when not wanted.
Unfortunately, you don't. For numbers whose magnitudes differ too greatly from 1, the calculator automatically switches to scientific (or engineering) notation. You can press MODE and change the display settings, but there is no setting that will force the calculator to show this number without an exponent.
Feb 25, 2010 | Texas Instruments TI-83 Plus Calculator
416 people viewed this question
Top Aurora Electronics Office Equipment & Supplies Experts
Jim Keysor
chargerhp
chargerhp
Are you an Aurora Electronics Office Equipment and Supply Expert? Answer questions, earn points and help others
