Question about Bunn CDBCF 15 APS Coffee Maker
I just replaced the main water control valve. The one i took out was part number 28750. The replacement part is 41579. I am not getting good water pressure through the new valve.
  • mike67389 Apr 02, 2011
    I have done some more trouble shooting and i have good water flow all the way to the boiler but no flow to the hot water valve on the front of the brewer and very low water flow into the brew basket. Water just dribbles out.
    President:
  • 1,618 Answers
Check the strainer filter (biggest fitting) on the back of the tank, that might be causing the flow problem.
Posted on Apr 01, 2011
Electrolux washer error code 35
There is a water fill sensor issue - 1. Is the water level above 4.5 inches? Yes, go to step (2). No, go to step (4). 2. Does the water enter the washer continuously? Yes, go to step (3). No, replace the Main Control Board. 3. Remove power from the washer. Does the water stop coming in? No, replace water valve assembly. Yes, check wiring to valve assembly for shorts. If wiring is good, replace the Main Control Board. 4. Replace the pressure sensor switch. Did this correct the problem? Yes, problem solved. No, replace the Main Control Board.
Aug 18, 2012 | Electrolux AW1202W Front Load Washer
Continuous flow from water dispenser
With GE it could be a bad water valve, bad microswitch that actuates the water or could be a bad main control board. You can diagnose the valve by simply pulling the wire harness off and turning the water on. If the water starts to flow with the power removed from the valve then the valve is stuck and needs replacing. If the water stopped with the power removed, check the valve's wire harness with a volt meter and see if 115vac is being applied. If so then the switch or the board are bad. You can check the switch by setting your meter to continuity and checking the com part of the switch to either the no or nc part. One should test good for continuity, the other not and with the switches buttong depressed the exact opposite. If the switch test good then the board is bad.
May 27, 2012 | GE Refrigerators
KitchenAid Superba KRA22ILBL00 water dispenser not working
When the dual water control valve is worn out they tend to buzz, hum and sometimes melt plastic housing around coil. Some even have the plunger stuck inside. Best thing to do is replace. I was not able to find a model KRA22ILBL00 in the US database but if that is your model number I would replace the water control valve, Thanks Sea Breeze
2_16_2012_1_49_00_am.jpgPoint and Click
Feb 13, 2012 | KitchenAid Refrigerators
GE Model WCVH6800J Error Code 04. I do not have list of codes for this model, so I need translation.
TROUBLESHOOTING CHART
Codes Description Action
22,23 Fill problems
• Ensure manual water valves are fully open.
• Check if water strainers on solenoid valve assembly are clogged.
• Check for obstructions inside inlet water hoses.
• Ensure solenoid valves do not leak when the valves are de-energized and the washer is powered down. • Measure coil resistance for both valves; if outside range (1000-1250 ohms at room temp.), replace solenoid valve
assembly.
IF ABOVE STEPS DO NOT CLEAR THE PROBLEM, OR FOR ERROR CODE 23:
• Replace solenoid valve assembly.
30, 31 Drain problems
• Ensure pump strainer is clean and free of debris.
• Check for obstruction inside the drain hose.
• Check pump impeller blades and bearing; if evidence of blade damage or seized bearings are present, replace the pump.
• Check electrical connections at the pump motor and harness.
• Measure pump motor resistance; if outside range (9-14 ohms at room temp.), replace the pump.
38,39 Dispenser problems
• Check for obstruction in dispenser mechanism and linkages.
• Check electrical connections at dispenser motor feedback switch and in the harness.
IF ABOVE STEPS DO NOT CLEAR THE PROBLEM:
• Replace dispenser motor assembly.
42,45, 49 Motor Drive operation above design limits
• Ensure all 4 shipping bolts have been properly removed.
• Remove all foreign objects that may be lodged between inner and outer basket.
• Look for signs of seized bearing(s) on basket and drum motor, replace components as necessary.
• Inspect condition and mounting of door gasket, replace and re-mount as necessary.
• Ensure inner basket (drum) can rotate freely.
• Replace motor drive or drum motor.
43,4A, 4B,4C, Motor Drive internal problems
4E,4F, 50,52,
53,54
• Measure AC outlet voltage, ensure correct range (102V to 132V AC).
• Check electrical connections at the drum motor, motor drive.
• Check harness integrity between main control and motor drive.
• Unplug the unit, wait 30 seconds, restart the unit.
• If the fault persists and re-appears -replace the motor drive.
problems
57,58,71 Main Control internal problems
• Unplug the unit, wait 30 seconds, re-start the unit.
• If the fault persists and re-appears -replace the main control.
60,61,63,64, DOOR LOCK assembly problems
• Check integrity of wiring and connections between main control and DOOR LOCK mechanism.
• Investigate DOOR-LOCK mechanism, check door microswitch operation, lock and unlock solenoid continuity, contact integrity;
replace DOOR LOCK mechanism if necessary.
• Replace the main control.
65 Water Level Sensor problems
• Check integrity of wiring and connections between main control and Water Level Sensor.
• Check integrity of Water Level Sensor, replace if necessary.
66,67 Water Temperature Sensor problems
• Check integrity of wiring and connections between main control and HeaterfThermistor Assembly.
• Using ohmmeter, measure Thermistor resistance; if outside expected range, replace HeaterfThermistor Assembly.
70 "Stuck" key
• Press each key. There should be mechanical "click" feedback with every press.
• Enter Service mode, use 104 test to check key operation. Press every key. Every keypress should generate audible
"beep." Press "Power" key last to avoid premature exit from t04 test.
• Separate control and control housing from the front panel; clean and remove all foreign matter and debris from keys,
front panel and control housing, re-assemble. Ensure all keys can be operated freely without "sticking."
IF ABOVE STEP DOES NOT CLEAR THE PROBLEM:
62 System Contact Failure
• Check integrity of wiring and connections, look for insulation breakdown and short circuit conditions on the harness, replace
harness if necessary.
• Check integrity and electrical connections of all loads (heater, pump, pressure switch, door lock, solenoid valves,
dispenser motor), replace respective components if necessary.
Jun 23, 2011 | General Electric WCVH6800J Front Load...
Our icemaker had a red blinking light and wasn't working. We took out the bin and let it defrost - cleaned it out (turned it off). Then after it was clean put it back in the freezer - we switched it to...
The bimetal thermostat embedded inside your ice maker is what tells the water control valve to open on rear of refrigerator near floor where the water supply enters the refrigerator. That water valve has two sides. One for the water dispenser and other for ice maker. I will try to make this simple and in my words because Whirlpool now owns Maytag and its related brand names. They do not allow me to provide the service manual any longer so I need to place my on work here. Even with what I believe is the problem you may have a technician or someone that is comfortable working with electricity test the dual water control valve on back and near floor.
Test for continuity and resistance on both sides with power disconnected from dual water control valve. Both sides should show very close to the same amount of resistance. Use care testing water control valve because of the risk of shock especially if wet. Click Here=>
MZD2766GES Ice Maker Parts Break Down
Number 13 in that photo is the Ice Makers thermostat Part Number=> Pin Style Icemaker Thermostat 627985
The dual Water Control valve is Part Number=> 61005626 Dual Water Control Valve
Another way of testing ice maker is to fill with tap water and turn on. If ice freezes and drops then the dual water control valve needs to be replaced. If not working then you have two options and that is a complete Ice Maker Assembly Part Number=> D7824706Q or replace parts.
sea_breeze_24.jpg If you still have questions please feel free to ask, Thanks, Sea Breeze
D7824706Q
Ice Maker Module
Dec 12, 2010 | Maytag MZD2766GES Side by Side...
Cannot get water to dispenser or to ice maker. Water valve has been replaced twice and no luck.
have you check the power from either a control board to the water valves or the main power cord.make sure your water supply line is good and producing water
Mar 12, 2010 | Refrigerators
I was not getting any cold water to my washing machine. i checked the hose, screen (both clear- theyre new hoses) when pulling the knob with the cold water setting water would start to fill the basin and...
Ok, generally, the issue will be between the valve, or the main control sector. You have replaced the valve, so the only component that can cause this will be the actual main control sector. The control sector can be a timer module, or a control board. I recommend to replace the control sector, asap. The price range for this type of control device will be around the $195.00 mark. Possibly less, depending on where you purchase the device,
Dec 09, 2009 | Amana ALW880WH Top Load Washer
Built in water dispenser drips/leaks (fridge model
It is very possible that the water control valve on the rear of your refrigerator needs replaced. It would also be a good idea to install a pre-filter before the water gets to the water control valve. I believe the side of the valve that controls the water dispenser is stuck open slightly allowing water to drip. You can test by disconnecting the wires to the dispenser side and see if the drip stops. When you press dispense water the dual water control valve opens completely on the rear for the water to flow. If the seal inside is defective it will leak. Here are a couple places to finds the Dual Water control Valve
http://servicepartstec.blogspot.com/
http://appliancepartsse.blogspot.com/
Just enter your part number or model number or click on the photo on the second site listed. They are both good suppliers. Let me know if this is helpful or if you need more help Thanks, Sea Breeze
appliancepartsoutheast@live.com
Aug 10, 2009 | Maytag Refrigerators
Geo metro transmission
main dealer is your best bet but get all the details of what model it is and chassi number as the parts vary from different models replace all gaskets and all valves not just one or two or you will be doing it again shortly change the oil these parts do wear but cheap oil is the biggest problem yates210456
Aug 04, 2008 | 1993 Geo Metro
Bunn CDBCF 15 APS Coffee Maker Logo
48 people viewed this question
Top Bunn Coffee Makers & Espresso Machines Experts
Kelley Hopper
Jim Y
Jim Y
pawnpower
Are you a Bunn Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
