Question about Singer CE-100 Futura Computerized Sewing Machine
Needle no longer picks up cotton from bobbin - Singer CE-100 Futura Computerized Sewing Machine
    Novelist:
  • 233 Answers
Generally, this is because the needle is inserted wrong orbecause it's bent. In the first case, the top of the needle (called the shank)has a flat side-this has to be inserted so it faces the back or away from you.
In the second case, when a bent needle stops the top thread from picking up thebobbin thread. Even if you think your needle is fine, change it to see if thissolves the problem.
Posted on Apr 27, 2011
  • Beth Millar Apr 28, 2011
    I take it this didn't solve your problem. Can you give some more of a description as to what is or isn't happening? If you turn the wheel by hand with no fabric in the machine, can you see the top thread loop around the bobbin through the clear plastic window? Is the top thread catching on something?
  • richard_rack Apr 28, 2011
    Thanks for your efforts but it's now had tobe mended professionally, and at great expence! The small fly wheel situated below the needle plate, adjacent to the shuttle race was broken. This is made of plastic and is apparently it is quite a common fault, and very difficult to get at so labour intensive. We have got it repaired here in France, but my daughter, who has had the same problem with her maching in UK had been told that it was irrepairable, and the machine would have to be replaced. Obviously better service here! Thank you again for attempting to assist
My 532 wont pick up cotton from bobbin
First, install a brand new needle. Used/worn/bent needles will sometimes fail to pick up the bobbin thread.
Make sure the bobbin is installed correctly in the bobbin case.
If it still will not pick up the bobbin thread, most likely the machine is out of time (the needle arrives at the incorrect time to intercept the bobbin thread). Take it for service or search the internet for web sites or videos dealing with sewing machine timing.
Sep 03, 2016 | Sewing Machines
When thread cotton. Cotton don't pick up bobbin cotton please help bernette65
Be sure to use a brand new needle. A bent/damaged needle may have difficulty picking up the bobbin thread.
Verify that both upper and bobbin threads are threaded correctly. If so, and it still fails to pick up the bobbin thread, most likely there is needle/hook timing issue. Take it for service.
Aug 19, 2016 | Sewing Machines
I have a brother ls-2150 I can't pick cotton up from the bobbin
Try installing a brand new needle (verify it is installed correctly). If it still does not pick up the bobbin thread, the needle/hook may be out of time, requiring service.
Sewing Machine Needle Not Catching Thread
Sewing machine won pick up bobbin thread hook timing fix
May 15, 2016 | Brother Sewing Machines
I am looking at this machin for a freind it wont pick up bobbin thread got me stumped
probably needle/ hook timing is out or needle in incorrectly
the groove faces the cotton , the cut in faces the hook of the bobbin case
the eye of the needle has to be just below the hook in the going up position so that it picks the needle thread up to run it around the bobbin case that is to say that at the point when the hook is at the needle , the eye of the needle should be just above than the eye so the hook gets the thread
anyway by seeing both sides of where the needle goes you will see the action
Nov 30, 2015 | Sewing Machines
Upper cotton not picking up bobbin cotton
Most likely a timing issue. the needle hook and needle are not aligned correctly.
Jan 30, 2015 | Brother Sewing Machines
My Bernina Deco 340 does not pick the bobbin thread but keeps saying the top thread is broken
Check the needle timing. Go to bernina on the web and download the service manual for your model. The eye of the needle should be at the pick arm of the bobbin case Too early or late and it will miss the cotton.
May 30, 2013 | Sewing Machines
I'm new to sewing, have threaded my bobbin, installed it in its casing, and threaded my machine. But when I take the needle down to pick up the bobbin thread, nothing happens. I've taken the bobbin out...
I am having the same problem !! was sewing fine then it stopped, have changed the cotton, needle, took case out and put back in , checked tension on all settings but still not picking up the cotton . Motor works fine and every thing all seems ok but cannot figure out why its not picking up the thread.All i can think is needle is not going down far enough to make contact but took needle out and lowed it but still nothing. Hope some one can help !!!!!!!!!!!!!! PLEASE
Jan 15, 2011 | Singer 1507
Needle will not pick up bobbin thread
Chances are you will need to retime it if you have checked everything else, if you email me with your make and model I can attach instructions
Mar 26, 2010 | Sewing Machines
Needle won,t pick up bobbin cotton
You may need to retime the machine, email me and I will attach instructions drivewithken@blueyonder.co.uk
Mar 08, 2010 | Kenmore Drop-In Bobbin 16231 Mechanical...
Singer CE-100 Futura Computerized Sewing Machine Logo
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
