Question about Intel PENTIUM-4 865GV CHIP MOTHER BOARD (MBP4I65GV) Motherboard
My usb ports do not working.When I put my mouse in it, the mouse lights become on but in the desktop the pointer is on its place and no hardware are found.I check 3 more mouse and key boards but the problem is same.What can I do Now. I have intel d865 hp compaq board.
  • Intel Master
  • 4,338 Answers
Follow the steps given below to refresh USB ports.
1. Right-click My Computer icon on the desktop, and then select Properties.
2. Click the Hardware tab.
3. Click the Device Manager button.
4. Click the plus (+) sign to the left of Universal Serial Bus controllers.
5. Right-click the device listed under Universal Serial Bus controller and select Uninstall.
6. Click OK to confirm the removal of the device.
Please note, repeat Steps 5 and 6 until all the devices under Universal Serial Bus Controller are removed.
7. Shut down the computer.
CAUTION: Ensure that the Shut Down option is selected, instead of the Restart option.
8. Wait for 5 seconds and then restart the computer. When the computer restarts, a "Windows has detected new or added hardware" message window will open.
The above steps will refresh the USB ports.
Now connect the USB devices like mouse, video camera, your external usb hard disk...usb hubs...whatever you like and the drivers should install automatically.
Tip: It is always recommended to connect the main usb devices at the rear end usb port, as they require more power to initiate.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
Posted on Apr 01, 2011
I have a gear head mouse, it's a lighted optical mouse model no OM3500U and I can't figure out how to change the batteries to see if that is the problem with it. It won't work at all and it...
There are no batteries in this mouse as it is a wired mouse. Wireless mice require batteries, not wired.Try removing the mouse from the USB port it is in and move it to another available port. It should work right away (after it detects the new device)but you may need to restart the computer after you move it to the new USB port. If that does not work, than it died.
In case of a problem or clarification or my solution was insufficient, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Jun 05, 2011 | Computers & Internet
Just installed MS 3000 wireless mouse. Won't run. no light on mouse. Have put new battery in and still no light. Flash drive has light. What to do now? Yes, I pushed the connection pins on both.
click start control panel mouse you should see 4 tabs buttons,pointers,pointer options and hardware under hardware you can troubleshoot also you can select properties under driver you will have the options update driver,rollback driver or uninstall and under hardware you can troubleshoot
in xp
click start right click on my computer select properties device manager control scroll to mice and pointing devices you might see a yellow question mark? right update driver in
make sure the battery is good (has full charge)also you might test the usb device for the mouse is inserted correctly into the usb port (if applicable)
Windows 7
hope this helps
don
Feb 24, 2011 | Microsoft Wireless Notebook Optical Mouse...
Trackman wheel logitech mouse stops working randomly and sometimes when i put the mouse in the slot it says usb device not recognize what do i do
you might have to uninstall the mouse then restart your computer then reinstall the mouse and its drivers
make sure the lead from the mouse has a secure seating and the lead is not bad/faulty
((if applicable))
click start control panel mouse you should see 4 tabs buttons,pointers,pointer options and hardware make sure you have the correct mouse selected also under hardware you can troubleshoot also you can select properties under driver you will have options to update driver,rollback driver or uninstall and under hardware you can troubleshoot
in xp
hope this helps
Feb 09, 2011 | Logitech Trackman Wheel 904353-0403...
My mouse jumps all over the place when trying to use it.
click start control panel mouse you should see 4 tabs buttons,pointers,pointer options and hardware under hardware you can troubleshoot also you can select properties under driver you will have options to update driver,rollback driver or uninstall and under hardware you can troubleshoot
in xp
hope this helps
Feb 03, 2011 | Televison & Video
My wireless mouse just quit working. I have a new battery in it so it must be the usb port. What can I do if anything?
in xp
hope this helps
Feb 02, 2011 | Logitech Cordless Mouse
I see red light at bottom of mouse but i mouse is still not working properly...can you help me connect this mouse..
in xp
hope this helps
Jan 23, 2011 | HP Wireless Optical Mouse
Mouse lights up when plugged in but doesnt work.installed all the appropriate drivers but still no result. help ?
if applicable
in xp
hope this helps
Jan 21, 2011 | A4tech SWOP-3 Mouse
After several days of working the mouse no longer communicates with the USB receiver. Or at least the "connect" light no longer comes on on the USB receiver. The batteries are fresh, the...
you might have to uninstall the mouse then restart you computer then reinstall the mouse and its drivers
in xp
hope this helps
Jan 14, 2011 | Computers & Internet
I have an older HP desktop and just added a new HP wirewless optical mobile mouse with usb. They seemed to work fine initially but then I needed to move the computer so everything was shut down and moved...
click start control panel mouse you should see 4 tabs buttons,pointers,pointer options and hardware under hardware you can troubleshoot also you can select properties under driver you can update driver,rollback driver or uninstall and under hardware you can troubleshoot
in xp
hope this helps
Jan 13, 2011 | HP Wireless Optical Mouse
My USB mouse does not work I've tried using 3 different ones, My keyboard works fine in same USB ports
make sure the mouse lead is seated correctly and is not faulty also
make sure that the right type of mouse is selected it will be in the hardware tab or
control panel mouse you should see 4 tabs buttons,pointers,pointer options and hardware under hardware you can troubleshoot or select properties under driver you can update driver,rollback driver or uninstall and under hardware you can troubleshoot
hope this helps
Nov 30, 2010 | Dell Dimension XPS 400 PC Desktop
Intel PENTIUM-4 865GV CHIP MOTHER BOARD (MBP4I65GV) Motherboard Logo
89 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
