I have a Akai pdp4206ea and the dtv works fine but when i try to add a game system through the av connection or the s-cable the screen scrolls like a old tv getting a bad signal .........how do i fix this? is the a vertical control some where?
  • 635 Answers
I think you are having a color system problem or frame rate difference.
Where did you get the game from. Check if it has the same color system as the TV.
PAL(UK/Germany ) which has 50 frames per second and NTSC(USA/Japan) which has 60 frames per second. This difference in frames can start the picture rolling if you do not have a multi system TV.
Posted on Apr 01, 2011
Akai PDP4206EA lost tuner and video inputs
Mine died after a brown out. It turned out to be the main board. They're pretty hard to find.
JE
Aug 14, 2009 | Akai PDP4206EA Television
AKAI PDP4206EA 42" DARK PICTURES ON COMP 1 AND 2. BLACK AND WHITE unstable vhold ON COMPOSITE. TUNER NOT TUNNING CABLE CHANNELS. ONLY LOOKS GOOD THROUGH VGA. WHAT COULD THE PROBLEM BE?
I had the same problem... It's the main board. Unfortunately they're pretty scarce these days. You can try to get a Viore mainboard, but you're either have to make a 3.3v ttl serial cable, or desolder the flash from the akai board and put it on the viore board (the two tv's use different pdp's). The 1st option is a little less intense.
May 04, 2009 | Akai PDP4206EA Television
AKAI PDP4206EA 42" DARK PICTURES ON COMP 1 AND 2. BLACK AND WHITE ON COMPOSITE. TUNER NOT TUNNING CABLE CHANNELS. ONLY LOOKS GOOD THROUGH VGA. WHAT COULD THE PROBLEM BE?
this is a shot in the dark but as the set been dropped? have you tried tapping around the case to see if this ulters the brightness. you might have a hairlined crack in the main pcb or dry joints.good luck .farr64
Apr 29, 2009 | Akai PDP4206EA Television
Part Number for AKAI PDP4206EA
Here are some links for most of the boards for this Akai model # PDP4206EA from a major parts distributor:
Akai PDP4206EA Replacement Part ATSC Digital / HD Tuner Board
Akai PDP4206EA Replacement Part Main Board Assembly
Akai PDP4206EA Replacement Part NTSC Analog Tuner Board
Please note: The X-SUS and Y-SUS boards and power supply board are no longer available and the video board is part of the main board assembly. Hope this information helps.
Feb 04, 2009 | Samsung HLR5067WX 50" Rear Projection HDTV
Tv built-in dvd player wont play thru surround sound
use your t/v audio out with RCA cables to your reciever input like(vcr in, dvd in, dtv in)
Dec 20, 2008 | Yamaha HTR-5930 Receiver
PS3 will play on AV but will not in HDMI
  1. Connect via AV and turn on the system.
  2. Go to Setting and then Display setting
  3. Select the connector type on your TV.
  4. After you selected connector your TV screen may go staid black. Try to hook your HD cable while the system is still on. (This step should be done in 30 sec. If not, will go back to previous screen)
  5. Your TV Screen should be on via HD cable
Dec 09, 2008 | Sony Playstation 3 (PS3) Console
My tv picture is bouncing up and down
may be there is a problem in setting of ur colours
Jun 07, 2008 | Akai PDP4206EA Television
A WONDERFUL MAN NAMED LARRY AT 251-479-3567 HELPED ME WHEN AKAI WOULD NOT CALL HIM.
Apr 14, 2007 | Akai PDP4206EA Television
Televison & Video Logo
44 people viewed this question
Top Televison & Video Experts
