Question about Sony FD Trinitron WEGA KV-32HS420 32" TV
I have a sony MODEL 32hs420 h240 Sept 2004 Chassis d44. When turned on, I have sound for 3 or 4 seconds, no picture, then shutoff with 6 blinks. I need diagnosis, part(s) and possibly instructions. Thanks, Don.
  • 10,594 Answers
I can provide you required info, can you replace parts in circuit board that requires soldering work.
Thanks.
Posted on Apr 01, 2011
Sony FD Trinitron WEGA KV-32HS420 32" TV.....Turns
Sounds like a diode may have burnt up or if your really lucky it might just be the fuse.!!! You might want to get a secound opinion .But if you know what to look for , which is any component on the motherboard that appears as if had caught fire sader it out amd replace with exact same component which can be ubtained at radio shack.GOOD LUCK TOO YOU!!!!!!!!!
Dec 23, 2010 | Sony FD Trinitron WEGA KV-32HS420 32" TV
Sony tv model kv 32hs420 turn on hear relay kick then shutdown no picture no sound and no red light I replaced 2 IC MCZ3001d
You may have a problem with the capacitor. Normally the ones on the power supply circuit are the first ones to go out. Have it inspected for leaks or swelling. Also check out the unit for burnt resistors.
Dec 10, 2009 | Sony FD Trinitron WEGA KV-32HS420 32" TV
Tube does not turn on
If TV model is Sony KV-32HS420 then mostly it requires to replace 2 ICs on DZ board, let me know if you can replace ICs on circuit board and know about TV repair to provide you more technical info.
Thanks.
Sep 16, 2009 | Sony FD Trinitron WEGA KV-32HS420 32" TV
I have a Sony ' Wega " about 6 years old 36 HD.. I turned it on and the stand by light blinks NO PICTURE.. OR SOUND AT FIRST IT MADE SOUND AND I THOUGHT PICTURE WAS GOING TO GO ON IT SHUT OFF...CAN YOU...
Please intimate exact model of Sony TV and how many times LED blinks as there would be 3 second pause between blinks so count blinks and let me know. This LED blink is an error code that will tell me problem section in TV.
Thanks.
Sep 07, 2009 | Sony Televison & Video
Blinking/standby timer
Sony Trinitron TV. Worked well last evening. Now picture won't go on. When power is turned on, standby/timer red light flashes, but picture or sound does not work.
Jul 01, 2009 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
Sony FD Trinitron Model: KV-32HS420. Turns on for 3 sec.
Its a problem with the capacitors on the main board. If you open it up you will notice that 1 or maybe two of them have puffed at the tops. Sony will fix this for you for about 200 buxs or if your able to, pull the capacitors yourself and take them to radioshack. You might spend 15 bux tops.
Jul 01, 2009 | Sony FD Trinitron WEGA KV-32HS510 32" TV
Mitsubishi WS-65511 Turning off
Good Day;
Your chassis V21, 2002 model TV has a problem, but to determine what, try this; press the 'input' and 'menu' buttons on the TV"s front panel for at least 10 seconds. Count the blinks (after releasing); eg blink, blink pause 6 blinks = code 26. The code will repeat 3 x's. The most common problem is the convergence IC's are bad or fluid on the boards.
Good Luck, Day let me know, Big Irish.
Jun 18, 2008 | Mitsubishi WS-65513 65" Rear Projection...
Blinking Standby Light
KV32hs500 tv won't turn on. Standby light blinks 7 times, stops and then 7 more times, etc.. The tv will usually come on after about 2 hours or so of being off. Plays fine when on but once it gets turned off the problem happens again. Any suggestions? T.V. is 5 years old.
I have a similar problem . mine blinks 6 times or 7 sometimes also,and comes on with sound ,no picture for about 2 seconds then shuts off. Anything?
Jan 31, 2008 | Televison & Video
Sony FD Trinitron WEGA KV-32HS420 32" TV Logo
48 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
