Question about Roland Microcube Guitar Amplifier
Roland micro cube dosnt power up - Roland Microcube Guitar Amplifier
  • 3 more comments
  • Anonymous Mar 24, 2014
    Battery function on my Micro Cube Amp is not working
    Micro Cube Battery powered Roland Amp battery function not working
    Not working on batteries
    Roland micro cube will work fine with dc but not with batteries
    Roland micro cube will power on and work on DC but not on batteries
  • 575 Answers
Check the fuses. There is probably one on the outside of the amp and some inside the circuit board.
Posted on Apr 30, 2011
My Roland Street cube amplifier has a bad speaker- where can I find a replacement speaker?
Rubber cement is an excellent for minor speaker cone damage but if you feel that a replacement is required, try MCM Electronics online. They carry lots-o-speaker replacements. Be sure to match wattage and impedance (ohms) of the speaker though as these are important spec's.
May 21, 2014 | Roland Cube-st Battery Powered Amp Cube...
Roland Micro Cube Amp fuse blew out. How do you fix it?
have a look here:
http://www.ehow.com/how_8698510_fix-roland-cube.html
although it doesn't mention the fuse you will probably find it. Sometimes there is a fuse access on the outer case.
Jan 11, 2012 | Roland Micro Cube Battery Powered Amp...
Roland micro cube fuse replacement
If the fuse blew, it is for a reason requiring repair. Troubleshoot and use a 40 watt lamp in series to limit current until cause of fuse blowing is found and repaired.
Jul 14, 2011 | Roland Microcube Guitar Amplifier
Hello my roland street cube won't power on, either with dc or batteries....adapter working .could a fuse be blown inside circuitboard? thanks
That is the first thing to check. They are most likely inside the circuit board. Remember to replace them with the same voltage and amperage ratings.
Feb 13, 2011 | Roland Cube-st Battery Powered Amp Cube...
I need to replace the power push button, but do not know what part number it is. Trying to get it ordered through Mouser, but there are too many listed. All I know is that it's an Alps switch, and it reads...
HI,
I've just had a Roland Micro Cube amplifier in for repair and it uses the same type of Alps switch you mention. ( It's also broken )
This is a simple single-pole latching push-button switch, so electrically, almost anything rated for an amp will be good enough.
Alps no longer make the same part, so you'll need to find something which looks the same and fits the original hole.
My repair is easier, because the replacement part doesn't have to match anything.
Graham.
Jan 27, 2011 | Roland CM30 CUBE Monitor Speaker PA...
Roland Microcube Guitar Amplifier Logo
539 people viewed this question
Top Roland Music Experts
Michial Gueffroy
Alex McGaughan
Alex McGaughan
Level 1 Expert
Are you a Roland Music Expert? Answer questions, earn points and help others
