What is a 350 code on a savin 8045 copier - Office Equipment & Supplies
  • 192 Answers
This code can be reset be turning off the main power (orange rocker switch) for about 10-seconds and then turning the machine back on. If the error comes back up, then there is a definite problem with the machine and it should be looked at by a train service technician.
SC350:
ID sensor pattern test error
One of the following ID sensor output voltages was detected twice consecutively when checking the ID sensor pattern.
1) Vsp ? 2.5V
2) Vsg ? 2.5V
3) Vsp = 0V
4) Vsg = 0V
Possible Causes:
• ID sensor defective
• ID sensor connector defective
• Poor ID sensor connector connection
• I/O board (IOB) defective
• High voltage supply board defective
• ID sensor dirty
• Defect at ID sensor pattern writing area of the drum
Posted on Apr 01, 2011
E03-25 error code panasonic 8045
Check the big white gear behind the flywheel to see if is broken where the gear mates with the pin on the shaft.
Oct 21, 2014 | Panasonic Dp-8045 Copier
Savin 8035 8045
which printer are you using Godlove.
Mar 06, 2014 | Office Equipment & Supplies
Savin 8045 sc544
error 544 is associated with the fuser, call aechnician to change the thermisters and thermofuse of the fuser and the problem is solved
goodluck
Feb 05, 2014 | Gestetner Office Equipment & Supplies
Savin copier drum cleaning blade for 8045
Service call is cheaper than you damaging the drum
Dec 19, 2012 | Savin Office Equipment & Supplies
My Panasonic 8045 machine is showing an error code E03-25. Please give me a solution.
What i have seen is the big white gear behind the flywheel is broken where the gear mates with the pin on the shaft.
Apr 28, 2011 | Panasonic DP-8045 Grayscale Copier
Hello. I need drivers for Panasonic DP-8045 to Windows 7. Thank.
Drivers for that model of panasonic can be found on driverupdate us. Take a look. cheers
Mar 10, 2011 | Panasonic DP-8045 Grayscale Copier
I have a savin 8045. I am getting an error code sc545. I just replaced the roller is the code related to this and how can i fix it.
The Thermistor (the heat sensor that rides on the teflon coated roller) is out of position or is unplugged.
Once it is repositioned or replaced the code must be reset. To reset it, push the Clear Modes key, then 1, then 0, then 7, and then hold down the Clear/Stop button until the screen changes. Once it changes select the System SP mode (the top one). Now turn off the main power switch. The code will be reset once you power the copier back on. Leave the front door open when you power it on. This will tell you if it reset the code. If the code is still there you did not reset it correctly.
Mar 09, 2011 | Savin 8035e Copier
Savin error code E-547 error code?
Fusing unit trouble.Clean the thermofuse and thermistors,check the heater lamp.After ,enter in the service mode turn the power switch OFF unplugged the crd.Wait 10 sec. plugg the cords and turn ON the machine.I think the Savin is based the Ricoh copiers machine.The service enter code is : Press the toral clear key - 1 - 0 - 7 -hold down the C key more 3 sec.
Aug 17, 2009 | Savin Office Equipment & Supplies
123 people viewed this question
jasbo
jasbo
