Will these remotes work for the vcr that is connected to the tv?
  • 635 Answers
Many of the modern remotes have no codes for VCR only CD/DVD. The VCR generation is supposed to be dead as no big players are making them anymore. One can purchase Digital Video recorders which will record on Hard Disc or directly on CD/DVD's with out any loss of picture quality.And some of the recorders can record more than 500 hours of High Quality videos !!!
Posted on Apr 01, 2011
HOW DO I DO CONNECTIONS OF INCOMING CABLE AND DIGITAL ADAPTER TO TV, VCR, AND DVD PLAYER?
Without seeing the exact connections for each device, i'm going to have to guess. But you should be able to connect your VCR to either your tv directly or to your DVD player. Remember you will need to use the "input" button on your TV or DVD player remote to switch from cable tv to your VCR and back.
May 02, 2014 | Emerson Televison & Video
How to change sylvania tv to video without remote
I was able to get the Sylvania TV to accept a different input (the remote was lost) by connecting the DVD to a Sony VCR using composite RCA jacks then connecting that to the TV. You'll need two 3-jack (yellow, white, red composite) cables - cheap at any store. Here;s how:
1. Connect RCA output jacks from the DVD to the input female receptacles of the VCR (first cable).2. Connect output jacks from VCR to the female input jacks on TV (second cable). 3. Turn on all equipment (VCR, DVD, TV)4. Switch the VCR to "Line 1" (for my Sony VCR, this shows up as "L1") by pressing the TV/VCR button on the VCR remote (which I did have).
Your system should now work.
The principle is to "fool" the TV into thinking that it's primary input is through the RCA composite A/V jacks rather than the cable connection. No need to disconnect the cable at any time. Any functioning VCR should work well as long as you have the remote for that device. Remember, connect output on the DVD to the input on the VCR, then the output on the VCR to the input jacks on the back of the TV. If you have the connectors on the TV, VCR, and DVD, component cables should work as easily. Remember, output from the DVD goes to the input of the VCR. Theoutput from the VCR (for which you DO have the remote) goes to the input side of the TV.
Apr 07, 2012 | Sylvania Televison & Video
I need to know if I can purchase a new remote for my vcr, and I need to know if this vcr is compatible with an HD TV?
You could try Curry's Partmaster website for the remote. As for the TV it will depend on the TV's imput sockets if you can connect it. Most VCR will only have a scart or S-Video connection. If the TV has these it will work. However even if you can the VCR will not record the HD signals or playback in HD. Though some HD TV's have what's called upscalling. Even so no vcr will ever be as good as a Blue-Ray. And those can record in HD.
Nov 25, 2010 | Sanyo VWM-700 VCR
All my problems are with the hookup of tv and dvd/vcr combo. Just can't do it. Is there anyone I can call tv repairman? I hear the Geeks only work on computers.
Simple matter. The Yellow cable will connect from Video Out of VCR to VIDEO IN of TV. Red cable will connect from AUDIO OUR (R) of VCR to AUDIO IN (R) of TV and AUDIO OUT (L) of VCR will connect to AUDIO IN (L) of TV. Play VCR or DVD and select AV1 or AV2 of TV using TV remote control.This button may also be labelled as TV/VIDEO on your TV's Remote Control
Jun 09, 2009 | Sony Televison & Video
Daewoo DVN-14F6N
Same problem...Went to Goodwill Store, they usually have a large basket of remotes. I found a Daewoo remote for a TV only, HOWEVER on the bottom it has a AIR/CABLE button. The remote doesn't say Daewoo on it only..."Remote Controller R-25B03". The rest of the button of course work with the TV portion of the DVN-14F6N.
Sep 17, 2008 | Daewoo DVN-14F6N 13" TV
VCR/Cable TV Connection
I guess you are using the cable TV feed looped through the VCR to the TV set.
Make sure you did not confuse the in and out loop of the VCR.
In the VCR menu, or on the remote there is usually a button called TV/VCR (Video). Make sure it is in the TV mode to watch the cable. In the VCR (Video) mode, the TV must be on the VCR's designated channel to watch the VCR, and the VCR tuner is used to watch the cable channels.
Jerry G.
May 24, 2008 | Televison & Video
RCA F27242GY TV when connected VCR does not recognize it
Are you connecting the VCR to the audio/video inputs to the TV? If so you need to switch the "input" for the TV to these jacks. There should be a button on the remote . Usually labeled "input"
Nov 19, 2007 | RCA F27242GY 27" TV
Connecting my tv and vcr so i can use the vcr remote control
You can always push "03" on a universal remote programmed to work your TV. A better solution is to connect the devices properly. You shouldn't use the tuner inputs for a VCR/DVD player, or you will get a poorer picture and no stereo sound. See the instruction manual for your player and TV. Use a stereo audio/video cable to connect them and select the proper input. The instructions will hopefully clarify this.
Oct 16, 2007 | Philips Magnavox 27MS343S 27" TV
Connecting VCR/DVD combo
If you are able to you can connect to the RF connector (F Type Conncetor) on the TV. This should work. The layout is from the VCR (RF to TV) to the TV antenna F type connector from your Cable box to the Antenna in of the VCR that way you have cable through the VCR, and access to you VCR and DVD all controlled by the Cable and VCR remotes (set TV to Channel 3, set VCR to Channel 3) and use the Cable box as the tuner, Use the TV remote to switch between Cable and VCR inputs then use the VCR remote to switch between the VCR and DVD input.
Sep 20, 2007 | GE 25GT516 TV
Set up with daytron TV
Have you tried hooking up the VCr and TV using RCA cables? You must connect Video out from VCR to Video IN of Tv and Audio out of VCR to Audio IN of TV.
Jun 01, 2007 | RCA VR546 S-VHS VCR
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
